Featured mysqlmymonlite.sh Addon
Discussion in 'Add Ons' started by eva2000, May 26, 2014.
  1. quicksalad
    quicksalad Member
    228
    14
    5:55 PM
    thanks and noted ;)
    12,579
    10:25 PM
    mysqlmymonlite.sh 0.5.4 has been released. You can download from here. Install video here.
    Changes of note are:
    • update for defaults-extra-file support for mysql 5.6
    • update mysqltuner.pl 1.5.1 mod version with MariaDB 10 and Aria Engine support. I no longer need to patch mysqltuner.pl for Aria Engine support as upstream master has added support for it alone with other goodies. There's still some mods I added for warning/messages to clarify them a bit more i.e. memory usage :)
    Examples for mysqlmymolite.sh 0.5.4 mysqlreport and mysqltuner outputs
     ./mysqlmymonlite.sh
    please see help for all options available
    ./mysqlmymonlite.sh --help
    install mysqlmymonlite.sh at /root
    chmod +x mysqlmymonlite.sh
    ./mysqlmymonlite.sh check
    ./mysqlmymonlite.sh run
    ./mysqlmymonlite.sh mysql
    ./mysqlmymonlite.sh vmstat
    ./mysqlmymonlite.sh showcreate
    ./mysqlmymonlite.sh showindex
    ./mysqlmymonlite.sh vbshowtables
    ./mysqlmymonlite.sh dblist
    ./mysqlmymonlite.sh mysqlreport
    ./mysqlmymonlite.sh mysqlfullreport
    ./mysqlmymonlite.sh mysqltuner
    ./mysqlmymonlite.sh psmem
    ./mysqlmymonlite.sh pschema
    System MySQL monitoring stats
    mysqlmymonlite.sh - 0.5.4 mysqlmymon.com
    compiled by George Liu (eva2000) vbtechsupport.com
    Report Generated:
    Tue Aug 25 14:30:16 UTC 2015
    mysqlreport output
    MariaDB 10.0.21-MariaDB     uptime 14 17:58:6   Tue Aug 25 14:30:17 2015
    __ Key _________________________________________________________________
    Buffer used    60.00k of   32.00M   %Used:   0.18
      Current       5.85M              %Usage:  18.28
    Write hit      58.86%
    Read hit       99.64%
    __ Questions ___________________________________________________________
    Total           1.32k       0.0/s
      DMS             971       0.0/s  %Total:  73.45
      -Unknown        275       0.0/s           20.80
      QC Hits         246       0.0/s           18.61
      Com_            222       0.0/s           16.79
      COM_QUIT        158       0.0/s           11.95
    Slow 1 s            0         0/s            0.00  %DMS:   0.00 Log:
    DMS               971       0.0/s           73.45
      SELECT          788       0.0/s           59.61         81.15
      UPDATE          144       0.0/s           10.89         14.83
      INSERT           34       0.0/s            2.57          3.50
      DELETE            5       0.0/s            0.38          0.51
      REPLACE           0         0/s            0.00          0.00
      show_fields      60       0.0/s            4.54
      show_status      32       0.0/s            2.42
      set_option       29       0.0/s            2.19
    __ Rows ________________________________________________________________
    Rows           17.72k       0.0/s
      Using idx       610       0.0/s  %Index:   3.44
    Rows/question   13.40
    __ SELECT and Sort _____________________________________________________
    Scan              159       0.0/s %SELECT:  20.18
    Range               2       0.0/s            0.25
    Full join           0         0/s            0.00
    Range check         0         0/s            0.00
    Full rng join       0         0/s            0.00
    Sort scan          16       0.0/s
    Sort range          3       0.0/s
    Sort mrg pass       0         0/s
    __ Query Cache _________________________________________________________
    Memory usage   17.15k of   16.00M  %Usage:   0.10
    Block Fragmnt 100.00%
    Hits              246       0.0/s
    Inserts           365       0.0/s
    Insrt:Prune     365:1       0.0/s
    Hit:Insert     0.67:1
    __ Table Locks _________________________________________________________
    Waited              0         0/s  %Total:   0.00
    Immediate         711       0.0/s
    __ Tables ______________________________________________________________
    Open               82 of   2048    %Cache:   4.00
    Opened             29       0.0/s
    __ Connections _________________________________________________________
    Max used            1 of    300      %Max:   0.33
    Total             160       0.0/s
    __ Created Temp ________________________________________________________
    Disk table         60       0.0/s   %Disk:  44.12
    Table             136       0.0/s    Size:  32.0M
    File                6       0.0/s
    __ Threads _____________________________________________________________
    Running             1 of      1
    Created             1       0.0/s
    Slow                0         0/s
    Cached              0 of     64      %Hit:  99.38
    __ Aborted _____________________________________________________________
    Clients             0         0/s
    Connects            0         0/s
    __ Bytes _______________________________________________________________
    Sent            1.04M       0.8/s
    Received      388.59k       0.3/s
    __ InnoDB Buffer Pool __________________________________________________
    Usage           2.48M of   47.98M  %Usage:   5.18
    Read hit       73.77%
    Pages
      Free          2.91k              %Total:  94.82
      Data            159                        5.18  %Drty:   0.00
      Misc              0                        0.00
      Latched           0                        0.00
    Reads             610       0.0/s
      From disk       160       0.0/s   %Disk:  26.23
      Ahead Rnd         0         0/s
    Writes              1       0.0/s
    Wait Free           0         0/s   %Wait:   0.00
    Flushes             1       0.0/s
      LRU               0         0/s  %Flush:   0.00
    __ InnoDB Lock _________________________________________________________
    Waits               0         0/s
    Current             0
    Time acquiring
      Total             0 ms
      Average           0 ms
      Max               0 ms
    Trx history          0
    __ InnoDB Data, Pages, Rows ____________________________________________
    Data
      Reads           173       0.0/s
      Writes            5       0.0/s
      fsync             5       0.0/s
      Pending
        Reads           0
        Writes          0
        fsync           0
    Pages
      Created           0         0/s
      Read            159       0.0/s
      Written           1       0.0/s
    Rows
      Deleted           0         0/s
      Inserted          0         0/s
      Read              0         0/s
      Updated           0         0/s
    __ Aria Pagecache ______________________________________________________
    Buffer used    16.00k of    8.00M   %Used:   0.20
      Current     336.00k              %Usage:   4.10
    Write hit     100.00%
    Read hit       88.06%
    Report Complete:
    Tue Aug 25 14:30:17 UTC 2015
    Report Generated:
    Tue Aug 25 14:30:27 UTC 2015
    mysqltuner output
    >>  MySQLTuner 1.5.1 - Major Hayden <major@mhtx.net>
    >>  Bug reports, feature requests, and downloads at http://mysqltuner.com/
    >>  Modified by George Liu (eva2000) at http://vbtechsupport.com/
    >>  Run with '--help' for additional options and output filtering
    [OK] Currently running supported MySQL version 10.0.21-MariaDB
    [OK] Operating on 64-bit architecture
    -------- Storage Engine Statistics -------------------------------------------
    [--] Status: +ARCHIVE +Aria +BLACKHOLE +CSV +FEDERATED +InnoDB +MRG_MyISAM
    [!!] InnoDB is enabled but isn't being used
    [OK] Total fragmented tables: 0
    -------- Security Recommendations  -------------------------------------------
    [OK] There is no anonymous account in all database users
    [OK] All database users have passwords assigned
    [!!] There is not basic password file list !
    -------- Performance Metrics -------------------------------------------------
    [--] Up for: 14d 17h 58m 16s (1K q [0.001 qps], 175 conn, TX: 1M, RX: 392K)
    [--] Reads / Writes: 81% / 19%
    [--] Binary logging is disabled
    [--] Total buffers: 152.0M global + 1.0M per thread (300 max threads)
    [OK] Maximum reached memory usage: 153.0M (14.94% of installed RAM)
    [OK] Maximum possible memory usage: 461.4M (45.06% of installed RAM)
    [OK] Slow queries: 0% (0/1K)
    [OK] Highest usage of available connections: 0% (1/300)
    [OK] Aborted connections: 0.00%  (0/175)
    [OK] Query cache efficiency: 23.6% (246 cached / 1K selects)
    [OK] Query cache prunes per day: 0
    [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 19 sorts)
    [!!] Temporary tables created on disk: 40% (60 on disk / 147 total)
    [OK] Thread cache hit rate: 99% (1 created / 175 connections)
    [OK] Table cache hit rate: 282% (82 open / 29 opened)
    [OK] Open file limit used: 0% (58/8K)
    [OK] Table locks acquired immediately: 100% (711 immediate / 711 locks)
    -------- MyISAM Metrics -----------------------------------------------------
    [!!] Key buffer used: 18.3% (6M used / 33M cache)
    [OK] Key buffer size / total MyISAM indexes: 32.0M/122.0K
    [OK] Read Key buffer hit rate: 99.6% (1K cached / 7 reads)
    [!!] Write Key buffer hit rate: 58.9% (457 cached / 188 writes)
    -------- InnoDB Metrics -----------------------------------------------------
    [--] InnoDB is disabled.
    [!!] InnoDB Storage engine is disabled. InnoDB is the default storage engine
    -------- AriaDB Metrics -----------------------------------------------------
    [--] AriaDB is disabled.
    -------- Replication Metrics -------------------------------------------------
    [--] No replication slave(s) for this server.
    [--] This is a standalone server..
    -------- Recommendations -----------------------------------------------------
    General recommendations:
        Add skip-innodb to MySQL configuration to disable InnoDB
        When making adjustments, make tmp_table_size/max_heap_table_size equal
        Reduce your SELECT DISTINCT queries without LIMIT clauses
    Variables to adjust:
        tmp_table_size (> 32M)
        max_heap_table_size (> 32M)
    Report Complete:
  3. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    2:25 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Installed.
    Working good, very good job as allways @eva2000 .
    For mysqltuner only recommendation is to optimise fragmented tables, but on innodb I do not know is that have any effect at all
  4. rdan
    8:25 PM
    Feature request, Can you please add an option to only backup database schema?
    like dblist option.
    I'm on the process of comparing my current DB structure to default XF, and seems I have something weird differences :(.
    12,579
    10:25 PM
    that's why i created my mysqlmymonlite.sh script mysqladmin_shell.sh Shell based Addon | Centmin Mod Community the showcreate option allows you to view all database table's create statements and/or save to individual text files which you can use file comparison tools to compare 2 different database's schemas i.e. https://community.centminmod.com/posts/136/
    showindex https://community.centminmod.com/posts/137/
    example for showcreate display to screen
    What is your mysql database name ? wp20447db_21269
    Do you want to display all wp20447db_21269 tables' schema (how table was created) ? [y/n]y
    Do you want save output to text file ? Answering no will output only to screen. [y/n]n
    *************************** 1. row ***************************
           Table: 2555_commentmeta
    Create Table: CREATE TABLE `2555_commentmeta` (
      `meta_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `comment_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      `meta_key` varchar(255) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
      `meta_value` longtext COLLATE utf8mb4_unicode_ci,
      PRIMARY KEY (`meta_id`),
      KEY `comment_id` (`comment_id`),
      KEY `meta_key` (`meta_key`(191))
    ) ENGINE=MyISAM DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
           Table: 2555_comments
    Create Table: CREATE TABLE `2555_comments` (
      `comment_ID` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `comment_post_ID` bigint(20) unsigned NOT NULL DEFAULT '0',
      `comment_author` tinytext COLLATE utf8mb4_unicode_ci NOT NULL,
      `comment_author_email` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_author_url` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_author_IP` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `comment_date_gmt` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `comment_content` text COLLATE utf8mb4_unicode_ci NOT NULL,
      `comment_karma` int(11) NOT NULL DEFAULT '0',
      `comment_approved` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '1',
      `comment_agent` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_type` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_parent` bigint(20) unsigned NOT NULL DEFAULT '0',
      `user_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      PRIMARY KEY (`comment_ID`),
      KEY `comment_post_ID` (`comment_post_ID`),
      KEY `comment_approved_date_gmt` (`comment_approved`,`comment_date_gmt`),
      KEY `comment_date_gmt` (`comment_date_gmt`),
      KEY `comment_parent` (`comment_parent`),
      KEY `comment_author_email` (`comment_author_email`(10))
    ) ENGINE=MyISAM AUTO_INCREMENT=2 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
           Table: 2555_links
    Create Table: CREATE TABLE `2555_links` (
      `link_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `link_url` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_name` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_image` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_target` varchar(25) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_description` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_visible` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'Y',
      `link_owner` bigint(20) unsigned NOT NULL DEFAULT '1',
      `link_rating` int(11) NOT NULL DEFAULT '0',
      `link_updated` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `link_rel` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `link_notes` mediumtext COLLATE utf8mb4_unicode_ci NOT NULL,
      `link_rss` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      PRIMARY KEY (`link_id`),
      KEY `link_visible` (`link_visible`)
           Table: 2555_options
    Create Table: CREATE TABLE `2555_options` (
      `option_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `option_name` varchar(191) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `option_value` longtext COLLATE utf8mb4_unicode_ci NOT NULL,
      `autoload` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'yes',
      PRIMARY KEY (`option_id`),
      UNIQUE KEY `option_name` (`option_name`),
      KEY `autoload_idx` (`autoload`)
    ) ENGINE=MyISAM AUTO_INCREMENT=135 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
           Table: 2555_postmeta
    Create Table: CREATE TABLE `2555_postmeta` (
      `post_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      KEY `post_id` (`post_id`),
           Table: 2555_posts
    Create Table: CREATE TABLE `2555_posts` (
      `ID` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `post_author` bigint(20) unsigned NOT NULL DEFAULT '0',
      `post_date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `post_date_gmt` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `post_content` longtext COLLATE utf8mb4_unicode_ci NOT NULL,
      `post_title` text COLLATE utf8mb4_unicode_ci NOT NULL,
      `post_excerpt` text COLLATE utf8mb4_unicode_ci NOT NULL,
      `post_status` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'publish',
      `comment_status` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'open',
      `ping_status` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'open',
      `post_password` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `post_name` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `to_ping` text COLLATE utf8mb4_unicode_ci NOT NULL,
      `pinged` text COLLATE utf8mb4_unicode_ci NOT NULL,
      `post_modified` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `post_modified_gmt` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `post_content_filtered` longtext COLLATE utf8mb4_unicode_ci NOT NULL,
      `post_parent` bigint(20) unsigned NOT NULL DEFAULT '0',
      `guid` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `menu_order` int(11) NOT NULL DEFAULT '0',
      `post_type` varchar(20) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT 'post',
      `post_mime_type` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `comment_count` bigint(20) NOT NULL DEFAULT '0',
      PRIMARY KEY (`ID`),
      KEY `post_name` (`post_name`(191)),
      KEY `type_status_date` (`post_type`,`post_status`,`post_date`,`ID`),
      KEY `post_parent` (`post_parent`),
      KEY `post_author` (`post_author`)
    ) ENGINE=MyISAM AUTO_INCREMENT=3 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
           Table: 2555_term_relationships
    Create Table: CREATE TABLE `2555_term_relationships` (
      `object_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      `term_taxonomy_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      `term_order` int(11) NOT NULL DEFAULT '0',
      PRIMARY KEY (`object_id`,`term_taxonomy_id`),
      KEY `term_taxonomy_id` (`term_taxonomy_id`)
           Table: 2555_term_taxonomy
    Create Table: CREATE TABLE `2555_term_taxonomy` (
      `term_taxonomy_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `term_id` bigint(20) unsigned NOT NULL DEFAULT '0',
      `taxonomy` varchar(32) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `description` longtext COLLATE utf8mb4_unicode_ci NOT NULL,
      `parent` bigint(20) unsigned NOT NULL DEFAULT '0',
      `count` bigint(20) NOT NULL DEFAULT '0',
      PRIMARY KEY (`term_taxonomy_id`),
      UNIQUE KEY `term_id_taxonomy` (`term_id`,`taxonomy`),
      KEY `taxonomy` (`taxonomy`)
           Table: 2555_termmeta
    Create Table: CREATE TABLE `2555_termmeta` (
      KEY `term_id` (`term_id`),
           Table: 2555_terms
    Create Table: CREATE TABLE `2555_terms` (
      `term_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      `name` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `slug` varchar(200) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `term_group` bigint(10) NOT NULL DEFAULT '0',
      PRIMARY KEY (`term_id`),
      KEY `slug` (`slug`(191)),
      KEY `name` (`name`(191))
           Table: 2555_usermeta
    Create Table: CREATE TABLE `2555_usermeta` (
      `umeta_id` bigint(20) unsigned NOT NULL AUTO_INCREMENT,
      PRIMARY KEY (`umeta_id`),
      KEY `user_id` (`user_id`),
    ) ENGINE=MyISAM AUTO_INCREMENT=14 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
           Table: 2555_users
    Create Table: CREATE TABLE `2555_users` (
      `user_login` varchar(60) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_pass` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_nicename` varchar(50) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_email` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_url` varchar(100) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_registered` datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
      `user_activation_key` varchar(255) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      `user_status` int(11) NOT NULL DEFAULT '0',
      `display_name` varchar(250) COLLATE utf8mb4_unicode_ci NOT NULL DEFAULT '',
      PRIMARY KEY (`ID`),
      KEY `user_login_key` (`user_login`),
      KEY `user_nicename` (`user_nicename`)
    ) ENGINE=MyISAM AUTO_INCREMENT=142852 DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci
    if saving to to files create /home/dbschemas directory and input path when prompted where you want to save files
    mkdir /home/dbschemas
    Do you want save output to text file ? Answering no will output only to screen. [y/n]y
    Enter directory path where you want to save the text file i.e. /home/username /home/dbschemas
    saving to: /home/dbschemas/wp20447db_21269-2555_commentmeta-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_comments-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_links-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_options-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_postmeta-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_posts-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_term_relationships-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_term_taxonomy-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_termmeta-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_terms-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_usermeta-showcreate.txt
    saving to: /home/dbschemas/wp20447db_21269-2555_users-showcreate.txt
    wp20447db_21269 table schema saved at: /home/dbschemas
    Jan 10  03:39   539    wp20447db_21269-2555_commentmeta-showcreate.txt
    Jan 10  03:39   1.6K   wp20447db_21269-2555_comments-showcreate.txt
    Jan 10  03:39   1.2K   wp20447db_21269-2555_links-showcreate.txt
    Jan 10  03:39   602    wp20447db_21269-2555_options-showcreate.txt
    Jan 10  03:39   541    wp20447db_21269-2555_postmeta-showcreate.txt
    Jan 10  03:39   1.9K   wp20447db_21269-2555_posts-showcreate.txt
    Jan 10  03:39   524    wp20447db_21269-2555_termmeta-showcreate.txt
    Jan 10  03:39   481    wp20447db_21269-2555_term_relationships-showcreate.txt
    Jan 10  03:39   541    wp20447db_21269-2555_terms-showcreate.txt
    Jan 10  03:39   703    wp20447db_21269-2555_term_taxonomy-showcreate.txt
    Jan 10  03:39   544    wp20447db_21269-2555_usermeta-showcreate.txt
    Jan 10  03:39   1.1K   wp20447db_21269-2555_users-showcreate.txt
    contents of /home/dbschemas/wp20447db_21269-2555_options-showcreate.txt
           Table: 2555_options
    if you save 2 databases files to 2 separate directories, you can then use file comparison tool to compare both
    12,579
    10:25 PM
    Updated mysqltuner.pl to 1.6.4 bundle for mysqlmymonlite.sh. To update just remove old version and rerun mysqltuner option
    rm /root/mysqltuner.pl
    /root/tools/mysqlmymonlite.sh mysqltuner
    Report Generated:
    Wed Feb 3 10:36:33 UTC 2016
    mysqltuner output
    mysqltuner.pl [found]
    >>  MySQLTuner 1.6.4 - Major Hayden <major@mhtx.net>
    [--] Skipped version check for MySQLTuner script
    [OK] Currently running supported MySQL version 10.0.23-MariaDB
    [--] Data in InnoDB tables: 2G (Tables: 24)
    [!!] Total fragmented tables: 24
    [OK] There are no anonymous accounts for any database users
    [!!] There is no basic password file list!
    -------- CVE Security Recommendations  ---------------------------------------
    [--] Skipped due to --cvefile option undefined
    [--] Up for: 6h 52m 35s (491 q [0.020 qps], 188 conn, TX: 985K, RX: 52K)
    [--] Reads / Writes: 100% / 0%
    [--] Total buffers: 416.0M global + 1.0M per thread (300 max threads)
    [OK] Maximum reached memory usage: 417.0M (40.73% of installed RAM)
    [OK] Maximum possible memory usage: 725.4M (70.84% of installed RAM)
    [OK] Slow queries: 0% (0/491)
    [OK] Aborted connections: 0.53%  (1/188)
    [!!] Query cache efficiency: 0.0% (0 cached / 199 selects)
    [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 10 sorts)
    [OK] Temporary tables created on disk: 0% (0 on disk / 132 total)
    [OK] Thread cache hit rate: 99% (1 created / 188 connections)
    [OK] Table cache hit rate: 246% (106 open / 43 opened)
    [OK] Table locks acquired immediately: 100% (90 immediate / 90 locks)
    -------- MyISAM Metrics ------------------------------------------------------
    [OK] Read Key buffer hit rate: 95.0% (40 cached / 2 reads)
    -------- InnoDB Metrics ------------------------------------------------------
    [--] InnoDB is enabled.
    [!!] InnoDB buffer pool / data size: 192.0M/2.7G
    [!!] InnoDB buffer pool <= 1G and innodb_buffer_pool_instances(!=1).
    [OK] InnoDB Used buffer: 91.67% (11263 used/ 12287 total)
    [!!] InnoDB Read buffer efficiency: 31.01% (5209 hits/ 16799 total)
    [!!] InnoDB Write buffer efficiency: 0.00% (0 hits/ 1 total)
    [OK] InnoDB log waits: 0.00% (0 waits / 1 writes)
    -------- ThreadPool Metrics --------------------------------------------------
    [--] ThreadPool stat is disabled.
    -------- AriaDB Metrics ------------------------------------------------------
    -------- TokuDB Metrics ------------------------------------------------------
    [--] TokuDB is disabled.
    -------- Galera Metrics ------------------------------------------------------
    [--] Galera is disabled.
        Run OPTIMIZE TABLE to defragment tables for better performance
        MySQL started within last 24 hours - recommendations may be inaccurate
        query_cache_limit (> 512K, or use smaller result sets)
        innodb_buffer_pool_size (>= 2G) if possible.
        innodb_buffer_pool_instances (=1)
    Report Complete:
    12,579
    10:25 PM
    Just a reminder for this useful mysqlmymonlite.sh tool I wrote which you can download from mysqlmymon.com
    or via simple command line for Centmin Mod LEMP servers
    mkdir -p /root/tools; cd /root/tools; rm -rf /root/mysqltuner.pl; rm -rf mysqlmymonlite.sh; wget http://mysqlmymon.com/download/mysqlmymonlite.zip; unzip -o mysqlmymonlite.zip; mv centos/mysqlmymonlite.sh .; rm -rf mysqlmymonlite.zip centos centos_whm debian changelog*; chmod +x mysqlmymonlite.sh
    script itself and tools will be at /root/tools
    ls -lah /root/tools/
    total 96K
    drwxr-xr-x 2 root root 4.0K May  3 12:54 .
    dr-xr-x--- 7 root root 4.0K May  3 01:06 ..
    -rw-r--r-- 1 root root  137 Apr 17  2013 cronjob logging.txt
    -rw-r--r-- 1 root root  391 May  2 11:13 ex_stats_print.c
    -rw-r--r-- 1 root root 3.5K Aug 10  2013 install.sh
    -rwxr-xr-x 1 root root  58K Jul 14  2015 mysqlmymonlite.sh
    -rw-r--r-- 1 root root  13K Aug  8  2013 readme.txt
    read first few posts of this thread for usage examples
    /root/tools/mysqlmymonlite.sh mysqlreport
    mysqlmymonlite.sh - 0.5.5 mysqlmymon.com
    compiled by George Liu (eva2000) centminmod.com
    Report Generated:
    Wed May 3 12:57:07 UTC 2017
    mysqlreport output
    MariaDB 10.1.22-MariaDB     uptime 1 2:8:26     Wed May  3 12:57:07 2017
    Buffer used     4.00k of   32.00M   %Used:   0.01
      Current       5.85M              %Usage:  18.27
    Write hit      50.00%
    Read hit       66.67%
    Total              78       0.0/s
      Com_             30       0.0/s  %Total:  38.46
      COM_QUIT         29       0.0/s           37.18
      DMS              23       0.0/s           29.49
      -Unknown          4       0.0/s            5.13
    DMS                23       0.0/s           29.49
      SELECT           22       0.0/s           28.21         95.65
      UPDATE            1       0.0/s            1.28          4.35
      DELETE            0         0/s            0.00          0.00
      INSERT            0         0/s            0.00          0.00
    Com_               30       0.0/s           38.46
      show_variab      11       0.0/s           14.10
      show_status       5       0.0/s            6.41
      show_databa       4       0.0/s            5.13
    Rows            7.13k       0.1/s
      Using idx         9       0.0/s  %Index:   0.13
    Rows/question   91.42
    Scan               24       0.0/s %SELECT: 109.09
    Range               0         0/s            0.00
    Sort scan           0         0/s
    Sort range          0         0/s
    Sort mrg pass       0         0/s
    Hits                0         0/s
    Inserts             1       0.0/s
    Insrt:Prune       1:1         0/s
    Hit:Insert     0.00:1
    Immediate          48       0.0/s
    Open               12 of   2048    %Cache:   0.59
    Opened             18       0.0/s
    Total              31       0.0/s
    Disk table          0         0/s   %Disk:   0.00
    Table              24       0.0/s    Size:  32.0M
    File                6       0.0/s
    Running             1 of      1
    Created             1       0.0/s
    Slow                0         0/s
    Cached              0 of     64      %Hit:  96.77
    Clients             0         0/s
    Connects            0         0/s
    Sent          234.57k       2.5/s
    Received        7.68k       0.1/s
    Usage           2.45M of   47.98M  %Usage:   5.11
    Read hit       63.00%
    Pages
      Free          2.91k              %Total:  94.89
      Data            157                        5.11  %Drty:   0.00
      Misc              0                        0.00
      Latched           0                        0.00
    Reads             427       0.0/s
      From disk       158       0.0/s   %Disk:  37.00
      Ahead Rnd         0         0/s
    Writes              1       0.0/s
    Flushes             1       0.0/s
    Waits               0         0/s
    Current             0
    Time acquiring
      Total             0 ms
      Average           0 ms
      Max               0 ms
    Data
      Reads           175       0.0/s
      Writes            5       0.0/s
      fsync             5       0.0/s
      Pending
        Reads           0
        Writes          0
        fsync           0
    Pages
      Created           0         0/s
      Read            157       0.0/s
      Written           1       0.0/s
    Rows
      Deleted           0         0/s
      Inserted          0         0/s
      Read              0         0/s
      Updated           0         0/s
    Buffer used         0 of    8.00M   %Used:   0.00
      Current     352.00k              %Usage:   4.30
    Write hit       0.00%
    Read hit        0.00%
    Report Complete:
    Wed May 3 12:57:08 UTC 2017
    Report Generated:
    Wed May 3 13:07:52 UTC 2017
    mysqltuner output
     >>  MySQLTuner 1.7.1 - Major Hayden <major@mhtx.net>
     >>  Modified by George Liu (eva2000) at https://centminmod.com/
    [OK] Currently running supported MySQL version 10.1.22-MariaDB
    -------- Log file Recommendations ------------------------------------------------------------------
    [--] Log file: /var/log/mysqld.log(0B)
    [OK] Log file /var/log/mysqld.log exists
    [OK] Log file /var/log/mysqld.log is readable.
    [!!] Log file /var/log/mysqld.log is empty
    [OK] Log file /var/log/mysqld.log is smaller than 32 Mb
    [OK] /var/log/mysqld.log doesn't contain any warning.
    [OK] /var/log/mysqld.log doesn't contain any error.
    [--] 0 start(s) detected in /var/log/mysqld.log
    [--] 0 shutdown(s) detected in /var/log/mysqld.log
    -------- Storage Engine Statistics -----------------------------------------------------------------
    [--] Status: +Aria +CSV +InnoDB +MEMORY +MRG_MyISAM +MyISAM +PERFORMANCE_SCHEMA +SEQUENCE
    -------- Security Recommendations ------------------------------------------------------------------
    -------- CVE Security Recommendations --------------------------------------------------------------
    -------- Performance Metrics -----------------------------------------------------------------------
    [--] Up for: 1d 2h 19m 12s (214 q [0.002 qps], 83 conn, TX: 634K, RX: 21K)
    [--] Reads / Writes: 98% / 2%
    [--] Physical Memory     : 2.0G
    [--] Max MySQL memory    : 386.7M
    [--] Other process memory: 157.9M
    [--] Total buffers: 152.0M global + 801.0K per thread (300 max threads)
    [--] P_S Max memory usage: 0B
    [--] Galera GCache Max memory usage: 0B
    [OK] Maximum reached memory usage: 152.8M (7.46% of installed RAM)
    [OK] Maximum possible memory usage: 386.7M (18.88% of installed RAM)
    [OK] Overall possible memory usage with other process is compatible with memory available
    [OK] Slow queries: 0% (0/214)
    [OK] Aborted connections: 0.00%  (0/83)
    [!!] name resolution is active : a reverse name resolution is made for each new connection and can reduce performance
    [!!] Query cache may be disabled by default due to mutex contention.
    [!!] Query cache efficiency: 0.0% (0 cached / 73 selects)
    [OK] Sorts requiring temporary tables: 0% (0 temp sorts / 2 sorts)
    [OK] No joins without indexes
    [OK] Temporary tables created on disk: 1% (1 on disk / 60 total)
    [OK] Thread cache hit rate: 98% (1 created / 83 connections)
    [OK] Table cache hit rate: 93% (82 open / 88 opened)
    [OK] Open file limit used: 0% (59/262K)
    [OK] Table locks acquired immediately: 100% (52 immediate / 52 locks)
    -------- Performance schema ------------------------------------------------------------------------
    [--] Performance schema is disabled.
    [--] Memory used by P_S: 0B
    [--] Sys schema isn't installed.
    -------- ThreadPool Metrics ------------------------------------------------------------------------
    [--] ThreadPool stat is enabled.
    [--] Thread Pool Size: 2 thread(s).
    [--] Using default value is good enough for your version (10.1.22-MariaDB)
    -------- MyISAM Metrics ----------------------------------------------------------------------------
    [OK] Key buffer size / total MyISAM indexes: 32.0M/124.0K
    [!!] Read Key buffer hit rate: 81.8% (22 cached / 4 reads)
    [!!] Write Key buffer hit rate: 50.0% (8 cached / 4 writes)
    -------- InnoDB Metrics ----------------------------------------------------------------------------
    -------- AriaDB Metrics ----------------------------------------------------------------------------
    [--] AriaDB is enabled.
    [OK] Aria pagecache size / total Aria indexes: 8.0M/1B
    [OK] Aria pagecache hit rate: 98.4% (61 cached / 1 reads)
    -------- TokuDB Metrics ----------------------------------------------------------------------------
    -------- XtraDB Metrics ----------------------------------------------------------------------------
    [--] XtraDB is disabled.
    -------- RocksDB Metrics ---------------------------------------------------------------------------
    [--] RocksDB is disabled.
    -------- Spider Metrics ----------------------------------------------------------------------------
    [--] Spider is disabled.
    -------- Connect Metrics ---------------------------------------------------------------------------
    [--] Connect is disabled.
    -------- Galera Metrics ----------------------------------------------------------------------------
    -------- Replication Metrics -----------------------------------------------------------------------
    [--] Galera Synchronous replication: NO
    -------- Recommendations ---------------------------------------------------------------------------
        Configure your accounts with ip or subnets only, then update your configuration with skip-name-resolve=1
        Performance should be activated for better diagnostics
        Consider installing Sys schema from https://github.com/mysql/mysql-sys
        query_cache_size (=0)
        query_cache_type (=0)
        performance_schema = ON enable PFS
    Report Complete:
    Wed May 3 13:07:53 UTC 2017
  8. pamamolf
    4,128
    3:25 PM
    Does this tool in any way auto update mysqltuner when a new version is out or the rest tools that include?
    12,579
    10:25 PM
    mysqlmymonlite.sh isn't auto updated itself
    but only tool you need to update is usually mysqltuner.pl but it's a modified version of the official with my own mods so usually will be updated when you run the install command
    or if you run the update command in the included /root/tools/install.sh
    cd /root/tools/
    chmod +x /root/tools/install.sh
    /root/tools/install.sh update
  10. Chuong Luong
    Chuong Luong Member
    39
    7:25 PM
    Hi @eva2000
    I did the install of the script with this code:
    mkdir -p /root/tools; cd /root/tools; rm -rf /root/mysqltuner.pl; rm -rf mysqlmymonlite.sh; wget --no-check-certificate http://mysqlmymon.com/download/mysqlmymonlite.zip; unzip -o mysqlmymonlite.zip; mv centos/mysqlmymonlite.sh .; rm -rf mysqlmymonlite.zip centos centos_whm debian changelog*; chmod +x mysqlmymonlite.sh
    Code installed, everything work fine except this command:
    When running this, there is no output, this is what I received:
    [10:37][root@abc tools]# ./mysqlmymonlite.sh mysqltuner
    mysqlmymonlite.sh - 0.5.7 mysqlmymon.com
    Report Generated:
    Fri Nov 12 10:37:30 UTC 2021
    mysqltuner output
    Report Complete:
    Seem it doesn't work:
    - I installed & reinstalled & updated, no work.
    - Checked to make sure mysqltuner.pl file available in root.
    - My vps is 2 core, 2 gb ram, centos 7, centmin updated.
    - Tried to run with mysql having been running for a few days or have just started after reboot, still no work.
    - Mysql shows no error log.
    Is there any other way to make this work? Thank you.
    12,579
    10:25 PM
    Should be fixed if you try running again. Problem was on mysqlmymon.com side for mysqltuner.pl download
  12. Chuong Luong
    Chuong Luong Member
    39
    7:25 PM
    Thank you, worked again!
