mysqladmin_shell.sh Shell based Addon
Discussion in 'Add Ons' started by eva2000, Jun 23, 2014.
    12,578
    8:07 PM
    if you use https://strongpasswordgenerator.com/ you can generate passwords with advanced options to avoid punctuation used in programming languages
  2. Jimmy
    6:07 AM
    12,578
    8:07 PM
    Yeah use that online generator whenever i need to for stuff :)
  4. noly
    noly Member
    106
    16
    Germany
    12:07 PM
    1.18.x
    10.2.x
    Hmmm...strange...
    cd /usr/local/src/centminmod/addons/
    ./mysqladmin_shell.sh createuserdb xdb1 xdbuser1 xdbpass1
    creates a db named "createuserdb" instead of xdb1.
    Syntax or Bug?
    12,578
    8:07 PM
    could be a bug, will look into it :)
  6. noly
    noly Member
    106
    16
    Germany
    12:07 PM
    1.18.x
    10.2.x
    Oh....i just recognized that my fresh phpmyadmin throws these messages...
    The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. Find out why.
    Or alternately go to 'Operations' tab of any database to set it up there.
    Configuration of pmadb... not OK
    General relation features Disabled
    12,578
    8:07 PM
    bug fixed in 123.09beta01 Beta Branch - fix addons/mysqladmin_shell.sh createuserdb option bug
    ./mysqladmin_shell.sh createuserdb xdb2 xdbuser2 xdbpass2
    Basic MySQL Admin - create mysql user & databases
    Grants for xdbuser2@localhost
    GRANT USAGE ON *.* TO 'xdbuser2'@'localhost' IDENTIFIED BY PASSWORD '*3399103BC71C868431660AC2C4B2128D4002C5BB'
    GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES, EXECUTE ON `xdb2`.* TO 'xdbuser2'@'localhost'
    Ok: MySQL user: xdbuser2 MySQL database: xdb2 created successfully
  8. noly
    noly Member
    106
    16
    Germany
    12:07 PM
    1.18.x
    10.2.x
    Thank you @eva2000 .
    Can't really tell you how to exactly reproduce it but during testing sometimes it worked flawless and sometimes i got an error when adding, deleting and adding a user again:
    ERROR 1396 (HY000) at line 1: Operation CREATE USER failed for 'dbuser'@'localhost'
    Error: command was unsuccessful
    Here is a possible solution:
    ERROR 1396 (HY000): Operation CREATE USER failed for 'jack'@'localhost'
    12,578
    8:07 PM
    yes FLUSH PRIVILEGES is needed after deleting. Known procedure :)
    mysqladmin_shell.sh already does this
    12,578
    8:07 PM
    Reminder when creating database names make sure you do not use hyphens on invalid identifier characters in the names. For database names and tables, hyphens aren't really a valid mysql identifiers allowed MySQL :: MySQL 5.6 Reference Manual :: 9.2 Schema Object Names. Underscores yes, hyphens no.
  11. rdan
    6:07 PM
    No feature for?
    • List Database
    • List Users
    • Delete Database
    12,578
    8:07 PM
    none right now those some of it's available in my own mysqlmymonlite.sh script at mysqlmymonlite.sh Addon
    /root/tools/mysqlmymonlite.sh dblist
    mysql performance_schema
    and dbbackup.sh MariaDB - dbbackup.sh - quick mysql database backups for Centmin Mod stack
    /root/tools/dbbackup.sh dblist
    | Database           |
    | db1                |
    | db2                |
    | db3                |
    | db4                |
    | db5                |
    | db6                |
    | information_schema |
    | mysql              |
    | performance_schema |
    /root/tools/dbbackup.sh dbinfo
                             db1 [idx: 0.00 MB data: 0.00 MB]
                             db2 [idx: 0.00 MB data: 0.00 MB]
                             db3 [idx: 0.08 MB data: 0.11 MB]
                             db4 [idx: 1.72 MB data: 7.52 MB]
                             db5 [idx: 0.25 MB data: 1.52 MB]
                             db6 [idx: 0.78 MB data: 5.52 MB]
      verylongdbnameexampletested [idx: 0.00 MB data: 0.00 MB]
  13. yunos
    yunos Member
    130
    12:07 PM
    1.8.0
    could this be added on centmin.sh menu option once users install addon on their own? would allow for much easier access
    like have a menu showing addons and the submenu can list all the addons users have installed
    12,578
    8:07 PM
    that could be a possibility eventually :)
    12,578
    8:07 PM
  16. happyhacking
    happyhacking Member
    111
    5:07 AM
    1.22.0
    MariadDB 10.4.25
    I truly love this tool, but i would like to report a bug, when using the deluser option i changed my mind, left the user blank then used ctrl+c and after that i pressed enter and the following occurred:
    [/CODEB]
    Delete MySQL username:
    Enter MySQL username you want to delete: ^C
    Ok: Deleting ''@'localhost' was successful
    [/CODEB]
    Perhaps the script should force a non empty answer before executing the command. Just my opinion.
    12,578
    8:07 PM
    fixed in latest 130.00beta01 update :)
    new exit keyword
    ./mysqladmin_shell.sh deluser
     Enter MySQL username you want to delete (type exit to abort): exit
     Aborted: No MySQL username entered
    empty input
  18. happyhacking
    happyhacking Member
    111
    5:07 AM
    1.22.0
    MariadDB 10.4.25
    thank you so much that was fast !! btw do you think that deleted user: ''@'localhost' should exist ?
  19. Jon Snow
    Jon Snow Active Member
    933
    192
    7:07 AM
    Nginx 1.13.9
    MariaDB 10.1.31
    Does setpass still work?
    12,578
    8:07 PM
    setpass should work for all MySQL usernames except MySQL root user.
