mysqladmin_shell.sh Shell based Addon
Discussion in 'Add Ons' started by eva2000, Jun 23, 2014.
  1. hendry
    hendry Member
    59
    14
    4:44 PM
    nginx/1.11.4
    MariaDB 10
    Sorry, @eva2000 it was my mistake, I run it from tools directory, when I run from addons directories it works.
    12,578
    7:44 PM
    yes has to be run from addons/ directory :)
  3. hendry
    hendry Member
    59
    14
    4:44 PM
    nginx/1.11.4
    MariaDB 10
    Many thanks @eva2000, hope you can make a simple command like this if we want to add many domain, so we can easily to remember it. I mean not like below command.;)
    while read -r d s f; do echo "nv -d $d -s $s -u $f"; nv -d $d -s $s -u $f; done < /home/vhostlist.txt
    12,578
    7:44 PM
    ah but excercising your memory is good for you :D
  5. hendry
    hendry Member
    59
    14
    4:44 PM
    nginx/1.11.4
    MariaDB 10
    hahaha.. forget it :hungover:
  6. RB1
    RB1 Active Member
    292
    75
    California
    2:44 AM
    MariaDB 10.1.x
    What about ./mysqladmin_shell.sh deldb
  7. hendry
    hendry Member
    59
    14
    4:44 PM
    nginx/1.11.4
    MariaDB 10
    You can use this simple command without entering your mysql or phpmyadmin:
    mysql -e "DROP DATABASE dbname;"
  8. RB1
    RB1 Active Member
    292
    75
    California
    2:44 AM
    MariaDB 10.1.x
    I know :)
  9. pamamolf
    4,128
    12:44 PM
    It will be good to have some remove/delete users option and for database empty/delete options also from mysqladmin tool :)
    For example if i want to recover a database i do not have to delete my existing database and re create it as i can just empty it by deleting all tables of it :)
    12,578
    7:44 PM
    yes deletion and other user removal choices are to come :)
  11. pamamolf
    4,128
    12:44 PM
    What about a menu so we will not have to remember all parameters of it?
    12,578
    7:44 PM
    just type mysqladmin_shell.sh without parameters should give you help output with such :)
    12,578
    7:44 PM
    mysqladmin_shell.sh createuserdb Added
    New mysqladmin_shell.sh option has been added for createuserdb option. This allows unattended creating of a mysql database + mysql username + mysql password without any question prompts. Suited for scripted setups where you want to create mysql database, user and password on the command line.
    Full addons/mysqladmin_shell.sh options
    ./mysqladmin_shell.sh {multidb|setglobaluser|setuserdb|setpass|createuserdb|deluser|showgrants}
    multidb - multiple mysql databse/user creation mode passing a file name containing db, user, pass 3 column entries
    setglobaluser - create a mysql username with access to all databases on server without SUPER ADMIN privileges (non-root)
    setuserdb - create individual mysql username and databases or assign a new database to an existing mysql username
    setpass - change mysql username password
    createuserdb - unattended create individual mysql username & databases fields required are dbname dbuser dbpass
    deluser - delete a mysql usernames
    showgrants - show existing mysql username granted privileges
    Example for createuserdb run where you pass on command line the database name, mysql username and mysql password - in this example db name = xdb1, db user = xdbuser1 and db pass = xdbpass1
    ./mysqladmin_shell.sh createuserdb xdb1 xdbuser1 xdbpass1
    Basic MySQL Admin - create mysql user & databases
    Grants for xdb1@localhost
    GRANT USAGE ON *.* TO 'xdb1'@'localhost' IDENTIFIED BY PASSWORD '*6D7525873C093916CA45CF6A9F12142EFC4C5F38'
    GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES, EXECUTE ON `createuserdb`.* TO 'xdb1'@'localhost'
    Ok: MySQL user: xdb1 MySQL database: createuserdb created successfully
    This is opposed to using the old setuserdb command which creates the mysql database name, db user and db pass with question prompts interactively below example created mysql dbname = ydb1, db user = ydbuser1 and db pass = ydbpass1
    ./mysqladmin_shell.sh setuserdb
     Do you want to create a new MySQL username (type = y) or
     Add a new database name to existing MySQL username (type = n) ?
     Enter y or n: y
    Create MySQL username:
     Enter new MySQL username you want to create: ydbuser1
     Enter new MySQL username's password: ydbpass1
    Create MySQL database:
     Enter new MySQL database name: ydb1
    Grants for ydbuser1@localhost
    GRANT USAGE ON *.* TO 'ydbuser1'@'localhost' IDENTIFIED BY PASSWORD '*34CE4FFBB62702263F1970A79FB0BA6CF651489B'
    GRANT SELECT, INSERT, UPDATE, DELETE, CREATE, DROP, INDEX, ALTER, CREATE TEMPORARY TABLES, LOCK TABLES, EXECUTE ON `ydb1`.* TO 'ydbuser1'@'localhost'
    Ok: MySQL user: ydbuser1 MySQL database: ydb1 created successfully
  14. Jimmy
    5:44 AM
    This is a wonderful addition to CMM. Just started using it.
  15. Jimmy
    5:44 AM
    If using multidb with a database file with special characters in the password, do the passwords need to be in single quotes? Or can we omit the single quotes?
    dbm1 dbmuser1 'dbmpa$$1'
    dbm2 dbmuser2 'dbmpa$$2'
    12,578
    7:44 PM
  17. Jimmy
    5:44 AM
    Without single quotes:
    -bash: !,UEzeJH8c[: event not found
    Doesn't work with single quotes either.
  18. Jimmy
    5:44 AM
    Using this:
    ./mysqladmin_shell.sh createuserdb art7er33u29wwe art3u7qu 'wT`YuFTp?eN)o>3QR~!,UEzeJH8c[:g:h@D9Hq6f2(^KMwA(p"%EH.GJMeUw&NHFc#K"T*F-&}F'
    It created a database called, createuserdb.
    MariaDB [(none)]> show databases;
    | Database           |
    | createuserdb       |
    | information_schema |
    | mysql              |
    | performance_schema |
    | pgo_train          |
    12,578
    7:44 PM
    Yeah you single quote and back ticks are causing problems for password in ssh I'd use less special characters that have single quotes,questions marks, back ticks, dollars signs, asterisk, curly braces, square brackets as they have special meaning for shell
  20. Jimmy
    5:44 AM
    I figured as much. I'll use less characters. :)
