mysqladmin_shell.sh Shell based Addon
Discussion in 'Add Ons' started by eva2000, Jun 23, 2014.
  1. ModeltogTossen
    313
    97
    Denmark
    12:07 PM
    1.9.12
    10.0.23
    Oh - did not read up - so the question was in use of @eva2000 mysqladmin_shell.sh script. That I have not used.. But the other idea works..
  2. ModeltogTossen
    313
    97
    Denmark
    12:07 PM
    1.9.12
    10.0.23
  3. pamamolf
    4,128
    1:07 PM
    I prefer the more simple way like:
    /root/tools/mysqladmin_shell.sh database1 12345 userdata1 showgrants
    But i am not sure if syntax is correct and if it is ok for the user to get privileges on the db.....
    12,578
    8:07 PM
  5. pamamolf
    4,128
    1:07 PM
    Ok i read it again :)
    If i got it running only:
    /root/tools/mysqladmin_shell.sh setuserdb
    I will get prompts to create a database and a user and a password for this user and it will automatically add privileges also for this user in the database?
    12,578
    8:07 PM
    yup
  7. pamamolf
    4,128
    1:07 PM
    Is it exactly the same as this (same permissions for user?):
    create database1;
    grant all privileges on database1.* to datauser1@'%' identified by '123456';
    flush privileges;
    quit;
    The '%' does that the datauser1 is allowed from everywhere.
    12,578
    8:07 PM
    no one user to one database pairing see again from 1st post example
  9. pamamolf
    4,128
    1:07 PM
    How can i adjust the above commands to get the same result one user to one database pairing? :)
    12,578
    8:07 PM
    that's what it does when you run
  11. pamamolf
    4,128
    1:07 PM
    Yea but i just asking to know how can i do it manually also by adjusting the:
    12,578
    8:07 PM
    best to read up on Getting Started Guide step 11 linked into if you want command client grants or https://community.centminmod.com/posts/24985/
  13. pamamolf
    4,128
    1:07 PM
    Does it ask when it creates a new database if i want to set it for example to utf8_general_ci ?
    12,578
    8:07 PM
    no it doesn't as that usually is done at server global and table levels
    see characterset and collation setting/change guide on official site MariaDB MySQL - CentminMod.com LEMP Nginx web stack for CentOS
  15. pamamolf
    4,128
    1:07 PM
    Phpmyadmin is giving that option when you try to create a database and is super easy.....not need to run so many commands :(
    Isn't good if it is possible to ask what collation the database will be at creation time using mysqladmin shell?
    12,578
    8:07 PM
    you don't need phpmyadmin, if you set default character set in mysql /etc/my.cnf any databases created automatically are UTF8 and matching collation
  17. pamamolf
    4,128
    1:07 PM
    Ok but setting this:
    character-set-server=utf8
    It can be any utf8 general or unicode or ..... :(
    Can i set it as:
    character-set-server=utf8_general_ci
    12,578
    8:07 PM
    read MySQL :: MySQL 5.7 Reference Manual :: 10.1 Character Set Support
    utf8 is character set and utf8_general_ci is the collation they are a pair. When you set UTF-8 default at server level, all databases have uft8 character set and uft8_general_ci collation.
    it's shown at MariaDB MySQL - CentminMod.com LEMP Nginx web stack for CentOS too
    mysqladmin var | grep -E 'character|collation' | tr -s ' '
    | character_set_client | utf8 |
    | character_set_connection | utf8 |
    | character_set_database | utf8 |
    | character_set_filesystem | binary |
    | character_set_results | utf8 |
    | character_set_server | utf8 |
    | character_set_system | utf8 |
    | character_sets_dir | /usr/share/mysql/charsets/ |
    | collation_connection | utf8_general_ci |
    | collation_database | utf8_general_ci |
    | collation_server | utf8_general_ci |
    and
    mysql -e "show character set;"
    | Charset  | Description                 | Default collation   | Maxlen |
    | big5     | Big5 Traditional Chinese    | big5_chinese_ci     |      2 |
    | dec8     | DEC West European           | dec8_swedish_ci     |      1 |
    | cp850    | DOS West European           | cp850_general_ci    |      1 |
    | hp8      | HP West European            | hp8_english_ci      |      1 |
    | koi8r    | KOI8-R Relcom Russian       | koi8r_general_ci    |      1 |
    | latin1   | cp1252 West European        | latin1_swedish_ci   |      1 |
    | latin2   | ISO 8859-2 Central European | latin2_general_ci   |      1 |
    | swe7     | 7bit Swedish                | swe7_swedish_ci     |      1 |
    | ascii    | US ASCII                    | ascii_general_ci    |      1 |
    | ujis     | EUC-JP Japanese             | ujis_japanese_ci    |      3 |
    | sjis     | Shift-JIS Japanese          | sjis_japanese_ci    |      2 |
    | hebrew   | ISO 8859-8 Hebrew           | hebrew_general_ci   |      1 |
    | tis620   | TIS620 Thai                 | tis620_thai_ci      |      1 |
    | euckr    | EUC-KR Korean               | euckr_korean_ci     |      2 |
    | koi8u    | KOI8-U Ukrainian            | koi8u_general_ci    |      1 |
    | gb2312   | GB2312 Simplified Chinese   | gb2312_chinese_ci   |      2 |
    | greek    | ISO 8859-7 Greek            | greek_general_ci    |      1 |
    | cp1250   | Windows Central European    | cp1250_general_ci   |      1 |
    | gbk      | GBK Simplified Chinese      | gbk_chinese_ci      |      2 |
    | latin5   | ISO 8859-9 Turkish          | latin5_turkish_ci   |      1 |
    | armscii8 | ARMSCII-8 Armenian          | armscii8_general_ci |      1 |
    | utf8     | UTF-8 Unicode               | utf8_general_ci     |      3 |
    | ucs2     | UCS-2 Unicode               | ucs2_general_ci     |      2 |
    | cp866    | DOS Russian                 | cp866_general_ci    |      1 |
    | keybcs2  | DOS Kamenicky Czech-Slovak  | keybcs2_general_ci  |      1 |
    | macce    | Mac Central European        | macce_general_ci    |      1 |
    | macroman | Mac West European           | macroman_general_ci |      1 |
    | cp852    | DOS Central European        | cp852_general_ci    |      1 |
    | latin7   | ISO 8859-13 Baltic          | latin7_general_ci   |      1 |
    | utf8mb4  | UTF-8 Unicode               | utf8mb4_general_ci  |      4 |
    | cp1251   | Windows Cyrillic            | cp1251_general_ci   |      1 |
    | utf16    | UTF-16 Unicode              | utf16_general_ci    |      4 |
    | utf16le  | UTF-16LE Unicode            | utf16le_general_ci  |      4 |
    | cp1256   | Windows Arabic              | cp1256_general_ci   |      1 |
    | cp1257   | Windows Baltic              | cp1257_general_ci   |      1 |
    | utf32    | UTF-32 Unicode              | utf32_general_ci    |      4 |
    | binary   | Binary pseudo charset       | binary              |      1 |
    | geostd8  | GEOSTD8 Georgian            | geostd8_general_ci  |      1 |
    | cp932    | SJIS for Windows Japanese   | cp932_japanese_ci   |      2 |
    | eucjpms  | UJIS for Windows Japanese   | eucjpms_japanese_ci |      3 |
  19. pamamolf
    4,128
    1:07 PM
    When i am using phpmyadmin and try to create a database is asking me about the collation and the default one is utf8 general ci.....and i can select what i want from the drop down list.
    Now how can i edit my.cnf file as i want to use mysqladmin shell script to create a new database utf8 unicode ci and then to import my database ?
    12,578
    8:07 PM
    why do you need utf8 unicode ci ? be very sure what you're doing by setting the my.cnf default to utf8 unicode ci for all created mysql databases - it applies to all databases created on the server
