mysqladmin_shell.sh error mysql not installed
Discussion in 'Add Ons' started by PhoenixDown, Sep 9, 2016.
  1. PhoenixDown
    PhoenixDown New Member
    11
    10:00 PM
    I'm trying to use this to create a new user and database and am getting the following error, any ideas? Thanks!
    [[email protected] tools]# chmod +x mysqladmin_shell.sh
    [[email protected] tools]# /root/tools/mysqladmin_shell.sh setuserdb
    Basic MySQL Admin - create mysql user & databases
     Do you want to create a new MySQL username (type = y) or
     Add a new database name to existing MySQL username (type = n) ?
     Enter y or n: y
    Create MySQL username:
     Enter new MySQL username you want to create: removed
     Enter new MySQL username's password: removed
    Create MySQL database:
     Enter new MySQL database name: amplifydb
    ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
    Error: command was unsuccessful
    37,720
    8,257
    1:00 PM
    check if mysql is running and try restarting mysql server first
  3. PhoenixDown
    11
    10:00 PM
    wasn't sure how to do that (typing mysql gives the same error) so I restarted the droplet. No luck.
  4. pamamolf
    3,156
    304
    5:00 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    just type:
    mysqlrestart
    and try again after that :)
  5. PhoenixDown
    11
    10:00 PM
    Thanks -- I wish i learned unix instead of dos. Still no go. Maybe I need to reinstall mysql/mariadb
    [[email protected] ~]# mysqlrestart
    Redirecting to /bin/systemctl restart mysql.service
    Failed to restart mysql.service: Unit mysql.service failed to load: No such file or directory.
  6. pamamolf
    3,156
    304
    5:00 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    Mysql seems to not be installed but don't try to do it by yourself as Centminmod for sure take care of it and never fail for it so i think you do something wrong...
    You may post more info on what OS do you use and how did you install Centminmod and what version?
  7. PhoenixDown
    11
    10:00 PM
    Sure - its a fairly new digital ocean droplet using CentOS 7.2 x64 and latest and greatest download. I really have nothing on it so if its easier to delete everything and start over I can do that -- just don't want to destroy the droplet and lose my ip.
  8. pamamolf
    3,156
    304
    5:00 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    How did you install Centminmod?
  9. PhoenixDown
    11
    10:00 PM
    CLI - standard instructions. I am sure I screwed up something somewhere :)
    37,720
    8,257
    1:00 PM
    split your posts to own thread to troubleshoot
    probably best to just do a fresh reload of centos os and re-install fresh centmin mod installation again
    should be able to keep droplet and reinstall i believe with DO
    on destroy droplet section
