mysqladmin_shell.sh Create database using "-" or "_' doesn't work
Discussion in 'Add Ons' started by pamamolf, Jan 4, 2017.
    4,101
    428
    8:41 PM
    Nginx-1.26.x
    • Nginx Version Installed:1.11.8
    • PHP Version Installed:7.0.14
    • MariaDB MySQL Version Installed:10.1.20
    • When was last time updated Centmin Mod code base ? : A few minutes....
    Hello :)
    Using :
    /usr/local/src/centminmod/addons/mysqladmin_shell.sh setuserdb
    I was not able to create a database name with "-" or "_' inside like my-database :(
    Didn't keep the exact error bu it was very clear that the problem is the special character :(
    Any ideas?
  2. pamamolf
    4,101
    428
    8:41 PM
    Nginx-1.26.x
    Also the user doesn't seem to exist checking from Phpmyadmin :(
    Is not at the list of users at all...
    Don't know if something change and mysqladmin needs some adjustments ......
    And i try to create the user from Phpmyadmin i am getting this error:
    An account already exists with the same username but possibly a different hostname.
    PS: Creating a database and a user from Phpmyadmin and all working great now :)
    It seems that there was an issue with mysqladmin script :(
    55,239
    12,253
    3:41 AM
    indeed !
    ./mysqladmin_shell.sh setuserdb
    Basic MySQL Admin - create mysql user & databases
     Do you want to create a new MySQL username (type = y) or
     Add a new database name to existing MySQL username (type = n) ?
     Enter y or n: y
    Create MySQL username:
     Enter new MySQL username you want to create: newmysqluser1
     Enter new MySQL username's password: newmysqlpass1
    Create MySQL database:
     Enter new MySQL database name: my-database
    ERROR 1064 (42000) at line 1: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '-database' at line 1
    Error: command was unsuccessful
    will check it out
    55,239
    12,253
    3:41 AM
