MariaDB MySQL remote inbound connection issues ?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by skringjer, Apr 24, 2019.
  1. skringjer
    skringjer Member
    139
    15
    12:25 AM
    Thank you very very much, i am encountering another problem, my sites cant connect to the database remotely, i have granted permissions to the database via this command
    GRANT ALL ON DB.* TO DBUSER@IP_OF_MY_CONNECTING SERVER IDENTIFIED BY 'USERPASS';
    Then i went in csf.conf and added
    TCP_OUT = "2525,465,1110,1194,9418,20,21,22,25,53,80,110,113,443,587,993,995,3306"
    At the end mysql port, but i can not connect to the database whatsoever, http://prntscr.com/nfxsd3
    Also tried in terminal, can someone help? Checked the privilages both in Phpmyadmin and in mysql, they are there http://prntscr.com/nfxsti
    44,186
    10,074
    5:25 AM
    Is remote mysql server also running Centmin Mod LEMP stack ? Did you restart CSF Firewall after making /etc/csf/csf.conf changes ?
    csf -ra
    Centmin Mod LEMP stack installs CSF Firewall out of the box, so to be able to remotely connect to external servers, you need to whitelist and allow the remote IP address see the info below:
  3. skringjer
    skringjer Member
    139
    15
    12:25 AM
    The database is hosted in this same server Centminmod, i am trying to connect from another server remotely to this database
    And yes i did restart CSF
    44,186
    10,074
    5:25 AM
    oh then you need to whitelist 3306 port on TCP_IN not TCP_OUT comma separated list to allow remote web server to connect inbound to TCP port 3306 on centmin mod/csf firewall protected server
    but better why is just to whitelist web server IP in CSF Firewall without whitelisting TCP_IN port 3306
    44,186
    10,074
    5:25 AM
  6. skringjer
    skringjer Member
    139
    15
    12:25 AM
    Issue fixed by tcp|in|d=3306|s=IP_HERE
    Thank you very much :)
  7. skringjer
    skringjer Member
    139
    15
    12:25 AM
    I have made changes to
    php-fpm.conf
    php-mycustom.conf
    my.cnf
    b_customphp.ini
    And domains nginx Vhost, will these changes be there if i upgrade centmin in the future.
    44,186
    10,074
    5:25 AM
    (y)
    I'd get in habit of post new threads for new topics in correct forums as this helps all other members and readers long term ;)
    For custom php settings read centminmod.com/phpfpm.html#customphpini. You might want to create /etc/centminmod/php.d/b_customphp.ini to override centmin mod defaults at /etc/centminmod/php.d/a_customphp.ini and restart PHP-FPM. Such changes will persist when doing centmin mod upgrades.
    Also outlined in Getting Started Guide Step 17
  9. skringjer
    skringjer Member
    139
    15
    12:25 AM
    Okay thank you very much, will post new threads for new issues :) :) :)
  10. pamamolf
    3,774
    366
    10:25 PM
    Nginx-1.17.x
    tcp|in|d=3306|s=11.22.33.44
    Can i just open a port there tcp in and out for all without specifing an ip?
    44,186
    10,074
    5:25 AM
    Not advisable security wise depending who has access to the remote source server. Just giving the server enough access to a particular port(s) is just safer especially if you're not the only person who has access to the remote source server.
  12. pamamolf
    3,774
    366
    10:25 PM
    Nginx-1.17.x
    I am asking because i am looking for an easy way to open one port not related to mysql as i am trying to create a bash script ....
    Thank you
