MariaDB mysql problems the mysqltuner & tuning-primer
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by seopolis, Sep 12, 2014.
    4,128
    3:20 PM
    It will be great George if you can add a workaround :)
    12,579
    10:20 PM
    ah i think I found the problem, the workaround I did actually triggers before the custom my.cnf is in place and not after !
  3. pamamolf
    4,128
    3:20 PM
    Great please update latest release :)
    Also the .07 stable is installing old Nginx version ...i didn't check for Mariadb or other software also....
    It will be great if you add the latest versions as default.
    12,579
    10:20 PM
    For nginx and php-fpm just use centmin.sh menu option 4 and 5 respectively to update as that's the whole point of Centmin Mod = end users can update to whatever version they want, when they want as soon as a new version is announced without waiting on author (me) updating versions :D
  5. pamamolf
    4,128
    3:20 PM
    yes i know but i thought also the default will be great to have latest versions :)
    Ok anyway thanks George :)
