MariaDB MySQL Keep crashing after OVH Changed MotherBoard.. Twice!
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Oxide, Aug 5, 2016.
  1. Oxide
    Oxide Active Member
    516
    29
    9:45 PM
    OVH Has changed motherboard twice on my server, the second time they also changed CPU Cooler. Now my mysql won't start..
    No idea what to do! :(
    [CODE] systemctl status mariadb.service
    ● mariadb.service - MariaDB database server
       Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
      Drop-In: /etc/systemd/system/mariadb.service.d
               └─migrated-from-my.cnf-settings.conf, protecthome.conf
       Active: failed (Result: exit-code) since Fri 2016-08-05 05:20:05 UTC; 5s ago
      Process: 5242 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
      Process: 5112 ExecStartPre=/bin/sh -c VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ] &&   systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
      Process: 5110 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
    Main PID: 5242 (code=exited, status=1/FAILURE)
       Status: "Applying batch of log records for InnoDB: Progress 0"
       CGroup: /system.slice/mariadb.service
    Aug 05 05:20:05 example.domain.net mysqld[5242]: sql/handler.cc:513(ha_initialize_handlerton(st_plugin_int*))[0x7f1d39fbb4d4]
    Aug 05 05:20:05 example.domain.net mysqld[5242]: sql/sql_plugin.cc:1408(plugin_initialize)[0x7f1d39e4c4e5]
    Aug 05 05:20:05 example.domain.net mysqld[5242]: sql/sql_plugin.cc:1685(plugin_init(int*, char**, int))[0x7f1d39e4de4a]
    Aug 05 05:20:05 example.domain.net mysqld[5242]: sql/mysqld.cc:5197(init_server_components)[0x7f1d39da63fa]
    Aug 05 05:20:05 example.domain.net mysqld[5242]: sql/mysqld.cc:5777(mysqld_main(int, char**))[0x7f1d39daa513]
    Aug 05 05:20:05 example.domain.net mysqld[5242]: /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f1d3791cb15]
    Aug 05 05:20:05 example.domain.net systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
    Aug 05 05:20:05 example.domain.net systemd[1]: Failed to start MariaDB database server.
    Aug 05 05:20:05 example.domain.net systemd[1]: Unit mariadb.service entered failed state.
    Aug 05 05:20:05 example.domain.net systemd[1]: mariadb.service failed.
    [/CODE]
    44,111
    10,045
    9:45 PM
    what version of mariadb mysql server you using ? the last 2 MariaDB 10.1.15 and 10.1.16 updates (centmin mod 123.09beta01 default 10.1 branch) have had issues for some folks if they're using Galera in 10.1.16
    So may need downgrading to MariaDB 10.1.14 if on 10.1.15 or 10.1.16 via instructions outlined here
    edit: i see screenshot says MariaDB 10.1.16, so maybe want to downgrade to MariaDB 10.1.14 ?
