IP.Board Mysql gone away during conversion from utf8 to utf8mb4
Discussion in 'Forum software usage' started by jair, Feb 12, 2017.
  1. jair
    jair Member
    48
    7
    2:31 PM
    I am using IP.Board and I am trying to convert my database from utf8 to utfmb4 for the purpose of using emoji. There is a built in option in the admin panel that I like to use, because as I read manual conversion is not very straightforward:
    Unfortunately after about a minute the conversion process is stopped. I have extracted this from the error log:
    2017/02/06 04:13:50 [error] 27657#27657: *24088 FastCGI sent in stderr: "PHP message: PHP Fatal error:  Uncaught IPS\Db\Exception: MySQL server has gone away in /mnt/volume-fra1-01/348/system/Db/Db.php:502
    Stack trace:
    #0 /mnt/volume-fra1-01/348/system/Db/Db.php(839): IPS\_Db->preparedQuery('/*IPS\\Session\\_...', Array)
    #1 /mnt/volume-fra1-01/348/system/Session/Admin.php(113): IPS\_Db->replace('core_sys_cp_ses...', Array)
    #2 [internal function]: IPS\Session\_Admin->write('4v7okt1ld0dti4c...', 'forcedWrite|i:1...')
    #3 [internal function]: session_write_close()
    #4 {main}
      thrown in /mnt/volume-fra1-01/348/system/Db/Db.php on line 502" while reading response header from upstream, client: 87.120.221.130, server: devtest.magelanci.com, request: "GET /admin/?adsess=4v7okt1ld0dti4ct6b748avgn5&app=core&module=support&controller=utf8mb4&mr=106&csrfKey=386f1d99ac0901d7f72c85d1ea7cbe46&adsess=4v7okt1ld0dti4ct6b748avgn5 HTTP/2.0", upstream: "fastcgi://127.0.0.1:9000", host: "devtest.magelanci.com", referrer: "https://devtest.magelanci.com/admin/?adsess=4v7okt1ld0dti4ct6b748avgn5&app=core&module=support&controller=utf8mb4"
    2017/02/06 04:13:51 [error] 27657#27657: *24088 FastCGI sent in stderr: "PHP message: PHP Fatal error:  Uncaught IPS\Db\Exception: Connection refused in /mnt/volume-fra1-01/348/system/Db/Db.php:206
    Stack trace:
    #0 /mnt/volume-fra1-01/348/system/Db/Db.php(117): IPS\_Db::_establishConnection('IPS\\Db', 'localhost', 'XXX', 'dgUIiN1Ug...', 'XXX', NULL, NULL, false)
    #1 /mnt/volume-fra1-01/348/system/Session/Admin.php(103): IPS\_Db::i()
    #2 [internal function]: IPS\Session\_Admin->write('4v7okt1ld0dti4c...', '')
    #4 {main}
    This is the error dump:
    object(IPS\Db\Exception)#98 (9) { ["query"]=> NULL ["binds"]=> array(0) { } ["message":protected]=> string(18) "Connection refused" ["string":"Exception":private]=> string(0) "" ["code":protected]=> int(2002) ["file":protected]=> string(40) "/mnt/volume-fra1-01/348/system/Db/Db.php" ["line":protected]=> int(206) ["trace":"Exception":private]=> array(7) { [0]=> array(6) { ["file"]=> string(40) "/mnt/volume-fra1-01/348/system/Db/Db.php" ["line"]=> int(117) ["function"]=> string(20) "_establishConnection" ["class"]=> string(7) "IPS\_Db" ["type"]=> string(2) "::" ["args"]=> array(8) { [0]=> string(6) "IPS\Db" [1]=> string(9) "localhost" [2]=> string(4) "XXX" [3]=> string(16) "dgUIiN1Ug" [4]=> string(9) "XXX" [5]=> NULL [6]=> NULL [7]=> bool(false) } } [1]=> array(6) { ["file"]=> string(46) "/mnt/volume-fra1-01/348/system/Login/Login.php" ["line"]=> int(92) ["function"]=> string(1) "i" ["class"]=> string(7) "IPS\_Db" ["type"]=> string(2) "::" ["args"]=> array(0) { } } [2]=> array(6) { ["file"]=> string(46) "/mnt/volume-fra1-01/348/system/Login/Login.php" ["line"]=> int(244) ["function"]=> string(8) "handlers" ["class"]=> string(10) "IPS\_Login" ["type"]=> string(2) "::" ["args"]=> array(0) { } } [3]=> array(6) { ["file"]=> string(72) "/mnt/volume-fra1-01/348/applications/core/modules/admin/system/login.php" ["line"]=> int(43) ["function"]=> string(5) "forms" ["class"]=> string(10) "IPS\_Login" ["type"]=> string(2) "->" ["args"]=> array(2) { [0]=> bool(true) [1]=> string(108) "YWRzZXNzPTR2N29rdDFsZDBkdGk0Y3Q2Yjc0OGF2Z241JmFwcD1wb2ludHMmbW9kdWxlPXBvaW50cyZjb250cm9sbGVyPWN1cnJlbmNpZXM=" } } [4]=> array(6) { ["file"]=> string(56) "/mnt/volume-fra1-01/348/system/Dispatcher/Controller.php" ["line"]=> int(96) ["function"]=> string(6) "manage" ["class"]=> string(36) "IPS\core\modules\admin\system\_login" ["type"]=> string(2) "->" ["args"]=> array(0) { } } [5]=> array(6) { ["file"]=> string(56) "/mnt/volume-fra1-01/348/system/Dispatcher/Dispatcher.php" ["line"]=> int(129) ["function"]=> string(7) "execute" ["class"]=> string(26) "IPS\Dispatcher\_Controller" ["type"]=> string(2) "->" ["args"]=> array(0) { } } [6]=> array(6) { ["file"]=> string(39) "/mnt/volume-fra1-01/348/admin/index.php" ["line"]=> int(14) ["function"]=> string(3) "run" ["class"]=> string(15) "IPS\_Dispatcher" ["type"]=> string(2) "->" ["args"]=> array(0) { } } } ["previous":"Exception":private]=> NULL }
    The two bolded parts are my mysql password (not my real password, just an example). Could it be somehow related that in the first instance it appends ... to the password? The password itself does not have ... as seen in the dump.
    I tried timing the seconds since start and the error appears around 75 second mark, which is way below than all my.cnf timeouts. Basically, I've reached a roadblock.
    IPS cannot help me as it is still test installation, so maybe someone here can give me some advice so at least I can understand the error and maybe point me in the right direction?
    Edit: I see that my bolding is removed. In the error log I have this line:
    Stack trace:
    My db password is not dgUIiN1Ug..., but only dgUIiN1Ug . Could this be the reason?
    55,906
    12,281
    9:31 PM
    https://dev.mysql.com/doc/refman/5.7/en/gone-away.html
    Depending on how much memory you have, try raising /etc/my.cnf mysql max_allowed_packet and/or wait_timeout to 512 MB and 28800 respectively just for the conversion and restarting MySQL server
    55,906
    12,281
    9:31 PM
    though there's this.. you MySQL server on same server as php files ? If not CSF Firewall maybe blocking php client server from connecting to MariaDB MySQL server
  4. jair
    jair Member
    48
    7
    2:31 PM
    Thanks for the suggestions, but they didn't help. I increased the max_allowed_packet, the timeout was already high. Php and mysql are on the same server.
    I'll keep reading, eventually I will try to convert it manually, but I am afraid this might bring even more problems in the long run if not done properly.
  5. Jimmy
    390
    7:31 AM
    How large is your db?
  6. jair
    jair Member
    48
    7
    2:31 PM
    About 800mb. But thats not the issue I believe, because as I run the script few times, already large number of tables are converted (without the columns that contain indexes though).
    Also, it breaks at between 60 to 75 seconds, which I believe shouldn't be a timeout issue, correct? If it was a timeout I assume it will always break on the exact second as before.
  7. Jimmy
    390
    7:31 AM
    The reason I asked is because I'm going to be doing that same thing on my testing server today. So, I'll see if I have the same issues as you do via running it in IPB.
    Since it's running via IPB, you might want to adjust your PHP settings... just a thought.
    If you have a testing server setup, I'd try to run the query manually via the command line and see if you're having the same issues - that it's a mysql issue or not.
  8. Revenge
    Revenge Active Member
    469
    93
    Portugal
    12:31 PM
    1.9.x
    10.1.x
    I have done that a few months ago on a 3Gb database. I didn't found any issue at that time.
  9. jair
    jair Member
    48
    7
    2:31 PM
    It could as well be problem with my 3.4 database, I remember back then I was having problems to convert from latin1 to utf8. Finally I did it the lame way - open in notepad++ and just fixed the collations there. It seems to work ok, but there are probably some side effects...
    @Jimmy : Problem is, I cannot localize on which part of the conversion this happens and I cannot replicate the problem manually. It doesn't look that complicated - change collation of database, change collation of tables, drop larger indexes, change collations on those columns, rebuild indexes. I tried looking for other scirpts, but it seems most of them don't pay attention to the rebuilding index part at all. Anyway, let me know if you have some problems.
  10. Jimmy
    390
    7:31 AM
    You're trying this on IPB 4.x right?
  11. jair
    jair Member
    48
    7
    2:31 PM
    Yes. I am converting from 3.4 first and then trying it on 4.1.
    55,906
    12,281
    9:31 PM
    on the server in directory with error log, try grepping for keyword 'FastCGI' and see what errors are outputted
    grep 'FastCGI' error.log
    that gives summary
    then to extend output to next 4 lines after FastCGI occurrence, in directory with error log
    grep -A4 'FastCGI' error.log
    Might want to use CODE tags for code How to use forum BBCODE code tags :)
