Beta Branch My 123.09beta01 Nginx issues
Discussion in 'Beta release code' started by apidevlab, Mar 24, 2016.
  1. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    Will do :) thanks for the help here. I am going to attach the 1st install and update logs to the gist above. I have just done as suggested:
    [root@centmod centminmod]# cd ..
    [root@centmod src]# cd ..
    [root@centmod local]# cd ..
    [root@centmod usr]# cd ..
    [root@centmod /]# cd /usr/local/src/centminmod
    [root@centmod centminmod]# git stash
    No local changes to save
    [root@centmod centminmod]# git pull
    Already up-to-date.
    That's correct yes? SO I already have the latest codebase? If that's the case then for me the issue still applies. I have will probably re-initialis(ed) the VPS and start from scratch as it's bugging me to hell :)
  2. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    Check Nginx Version:
    which: no nginx in (/usr/lib64/ccache:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin)
    can not find nginx binary.. install failed
    Starting nginx (via systemctl):  Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
    nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
      Loaded: loaded (/etc/rc.d/init.d/nginx)
      Active: failed (Result: exit-code) since Fri 2016-03-25 18:03:20 UTC; 28min ago
    I warily admit defeat here, I have spent the last 2 days trying to figure this... I may try to install stable and then upgrade via centminmod.sh[/CODE]
    59,950
    12,556
    1:41 PM
    should be
    post to gist.github.com that latest log contents as well for install log file - only way for me to see what's going on
    59,950
    12,556
    1:41 PM
    for that type output of
    nginx -t
  5. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    Command gives...
    -bash: nginx: command not found
    Will gist the logs for your perusal
  6. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    59,950
    12,556
    1:41 PM
    ah problem is you used an older version of lua-nginx-module 0.10.1rc0 instead of 0.10.2 probably you set it in /etc/centminmod/custom_config.inc ? as 123.09beta01 defaults to 0.10.2 now not 0.10.1rc0
    centmin 123.09beta01 default
    ORESTY_LUANGINXVER='0.10.2'     # openresty lua-nginx-module https://github.com/openresty/lua-nginx-module
    error in your log for failed nginx install
    -L/usr/local/lib -lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib \
    -shared
    objs/addon/src/ngx_http_lua_module.o: In function `ngx_http_lua_merge_srv_conf':
    /svr-setup/nginx-1.9.12/../lua-nginx-module-0.10.1rc0/src/ngx_http_lua_module.c:893: undefined reference to `SSL_CTX_set_cert_cb'
    objs/addon/src/ngx_http_lua_ssl_certby.o: In function `ngx_http_lua_ffi_ssl_clear_certs':
    /svr-setup/nginx-1.9.12/../lua-nginx-module-0.10.1rc0/src/ngx_http_lua_ssl_certby.c:553: undefined reference to `SSL_certs_clear'
    objs/addon/src/ngx_http_lua_ssl_certby.o: In function `ngx_http_lua_ffi_ssl_set_der_certificate':
    /svr-setup/nginx-1.9.12/../lua-nginx-module-0.10.1rc0/src/ngx_http_lua_ssl_certby.c:623: undefined reference to `SSL_add0_chain_cert'
    collect2: error: ld returned 1 exit status
    make[1]: *** [objs/nginx] Error 1
    make[1]: Leaving directory `/svr-setup/nginx-1.9.12'
    make: *** [build] Error 2
    what's output of
    grep ORESTY_LUANGINXVER /usr/local/src/centminmod/centmin.sh
    should be like
    contents of /etc/centminmod/custom_config.inc ?
    if you set ORESTY_LUANGINXVER in custom_config.inc, remove the line and recompile nginx via centmin.sh menu option 4
  8. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    I haven't set a custom_config.inc I initialised the VPS > set the hostname > (no yum update) Ran 1 liner
    Over the past few installs I tried yum update BEFORE the 1 liner, make a minimal install etc
    Output of ORESTY_LUAGINXVER
    Found in centminmod_ngxinstalltime_250316-114651.log this
    Line 6591: collect2: error: ld returned 1 exit status
       Line 6879: collect2: error: ld returned 1 exit status
    [\CODE]
    Is this a repo issue, when installing I have seen message about the 'repo more than 2 weeks old' or similar?
    Consider if it's worth me installing stable and upgrading to beta? Even if only to get some logs.
    59,950
    12,556
    1:41 PM
    strange as there's no way nginx would try compiling nginx with lua nginx 0.10.1rc0 version then
    59,950
    12,556
    1:41 PM
    Probably not as 123.08 stable doesn't support lua nginx 0.10 branch anyway, only 123.09beta01 does
    59,950
    12,556
    1:41 PM
    what does output of the following give you
    grep -Rn '0.10.1rc0' /usr/local/src/centminmod/*
    did you use installer-latest-gitlab.sh ? or one of the installer-latest.sh installs ? i see that old version is left in 123.09beta01 for those 2 versions which could be your problem - will fix it now :)
    /usr/local/src/centminmod/installer-latest-gitlab.sh:182:echo "ORESTY_LUANGINXVER='0.10.1rc0'" >> /etc/centminmod/custom_config.inc
    /usr/local/src/centminmod/installer-latest.sh:182:echo "ORESTY_LUANGINXVER='0.10.1rc0'" >> /etc/centminmod/custom_config.inc
    edit: updated 123.09beta01 and fixed a confirmed bug in installer-latest.sh and installer-latest-gitlab.sh versions at Beta Branch - fix bug in installer-latest.sh & installer-latest-gitlab.sh | Centmin Mod Community
    59,950
    12,556
    1:41 PM
  13. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    This is looking more promising now :)
    [root@centmod ~]# grep -Rn '0.10.1rc0' /usr/local/src/centminmod/*
  14. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    Yay, will post my findings. Here is a little head scratch though... I will double check but am 99% sure I used the same process on 22 March (I will double check that) and that seemed to install fine??
    Just a heads up Beta Branch - Centmin Mod .09 beta branch Testing | Centmin Mod Community still refers to betainstaller-latest.sh
    # bypass initial setup email prompt
    mkdir -p /etc/centminmod/
    echo "NGINX_PAGESPEED=y" > /etc/centminmod/custom_config.inc
    echo "ORESTY_LUANGINX=y" >> /etc/centminmod/custom_config.inc
    # echo "ORESTY_LUANGINXVER='0.10.2'" >> /etc/centminmod/custom_config.inc
    echo "1" > /etc/centminmod/email-primary.ini
    echo "2" > /etc/centminmod/email-secondary.ini
    "${INSTALLDIR}/centminmod/centmin.sh" install
    rm -rf /etc/centminmod/email-primary.ini
    rm -rf /etc/centminmod/email-secondary.ini
    59,950
    12,556
    1:41 PM
    That's fine it's commented out with hash in front
  16. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    4:41 AM
    1.11.1
    5.2.14-122
    I noticed that but was not 100% sure.
    To report I left 2 x Installs running last night and am very pleased to report they have installed successfully. I used the method 2 this time which worked :)
    I have only tested very briefly but am very grateful to the support @eva2000 has provided here. I couldn't have done it without him. You have created a thing of beauty with centminmod and I hope I'll be able to contribute back to help others here, many thanks.
    59,950
    12,556
    1:41 PM
    cheers thanks for the feedback and confirmation of the fix working :)
    More bug reports the better 123.09beta01 will be once fixed and released as stable :D
