Multi-thread compression Possible Issue
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Jimmy, Nov 2, 2018.
  1. Jimmy
    365
    7:50 AM
    1.17.x
    • Nginx Version Installed: i.e. 1.15.5
    Tried to run #17 and got this error. Wasn't sure if this was normal or not.
    Enter option [ 1 - 24 ] 17
    * pigz install
    Error: pigz-2.3.3.tar.gz not found!!!  Downloading now......
    --2018-11-02 01:41:00--  https://zlib.net/pigz/pigz-2.3.3.tar.gz
    Resolving zlib.net... 68.66.224.164
    Connecting to zlib.net|68.66.224.164|:443... connected.
    HTTP request sent, awaiting response... 404 Not Found
    2018-11-02 01:41:01 ERROR 404: Not Found.
    tar (child): pigz-2.3.3.tar.gz: Cannot open: No such file or directory
    tar (child): Error is not recoverable: exiting now
    tar: Child returned status 2
    tar: Error is not recoverable: exiting now
    inc/compress.inc: line 26: cd: pigz-2.3.3: No such file or directory
    make: *** No rule to make target `clean'.  Stop.
    make: *** No targets specified and no makefile found.  Stop.
    cp: cannot stat ‘pigz’: No such file or directory
    cp: cannot stat ‘unpigz’: No such file or directory
    -rwxr-xr-x.   2 root root    114K Mar 24  2017 pigz
    -rwxr-xr-x.   2 root root    114K Mar 24  2017 unpigz
    pbzip2 already installed
    lbzip2 already installed
    lzip already installed
    plzip already installed
    p7zip already installed
    45,201
    10,280
    9:50 PM
    thanks for the heads up - bug has been fixed and centmin.sh menu option 17 routine has been improved including adding 2 other compression tools for zstd and lz4 :)
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Install/Re-Install
    24). Exit
    Multi-thread compression Install
    The following compression tools will be installed
      1. pigz
      2. pbzip2
      3. lbzip2
      4. plzip
      5. zstd
      6. lz4
    pigz already installed
    zstd already installed
    lz4 already installed
