[Solved] Mosh issue
Discussion in 'Bug Reports' started by MartinBratteng, Dec 29, 2015.
  1. MartinBratteng
    MartinBratteng New Member
    5
    8:40 PM
    1.9.9
    10.0.23
    Hey, so I installed Mosh before I installed Centmin, because my network connection at times drop out, and Mosh makes sure it doesn't destroy the process.
    Mosh: the mobile shell <-- A great tool for SSH access
    But after Centmin was installed, I can't seem to be able to connect to the mosh-server, which is running on UDP ports between 60000 to 61000, does Centmin block these or anything?
  2. Ahmad
    Ahmad Active Member
    209
    80
    8:40 PM
    1.9.9
    10.1.10
  3. MartinBratteng
    5
    8:40 PM
    1.9.9
    10.0.23
    Ahh, when I disabled CSF it worked, didn't realize it was installed. Never used CSF before, and not sure where to find the config file for it?
  4. Ahmad
    Ahmad Active Member
    209
    80
    8:40 PM
    1.9.9
    10.1.10
  5. MartinBratteng
    5
    8:40 PM
    1.9.9
    10.0.23
    55,156
    12,249
    4:40 AM
