Install more_set_headers y/n setting not being considered
Discussion in 'Install & Upgrades or Pre-Install Questions' started by noly, Sep 29, 2017.
  1. noly
    noly Member
    93
    13
    Germany
    3:32 PM
    1.13.x
    10.x
    • Nginx Version Installed: 1.13.5
    • PHP Version Installed: 7.0.24
    • MariaDB MySQL Version Installed: 10.1.26
    • When was last time updated Centmin Mod code base ? : just did
    • Persistent Config:
    • NGXDYNAMIC_NGXPAGESPEED='y'
      NGINX_PAGESPEED='y'
      LETSENCRYPT_DETECT=’y’
      ACMEDEBUG='y'
      PUREFTPD_DISABLED=y
      NGINX_LIBBROTLI='y'
      NGINX_MP4='y'
      ZOPCACHEDFT='y'
      PHPGEOIP_ALWAYS='n'
      PHPDEBUGMODE='n'
      PHPFINFO='n'
      NGINX_VHOSTSSL='y'
      PHP_VERSION='7.0.24'
      AUTO_GITUPDATE='n'
      PHP_PGO='y'
      NGINX_HTTP2='y'
      NGINX_IPV='n'
      ENABLEMOTD='n'
      WPCLI_SUPERCACHEPLUGIN='y'
      NGINX_CACHEPURGE='y'
      ORESTY_HEADERSMORE='n'
      CLANG='y'
      NGINX_MAXERRBYTELIMIT='4096'
    • Hello Houston, issue here in space...
      just upgraded on the production server from nginx 1.13.3 to 1.13.5 and even though i am setting in my persistent config file: ORESTY_HEADERSMORE='n' i get the following error
      nginx -t
      nginx: [emerg] unknown directive "more_set_headers" in /usr/local/nginx/conf/nginx.conf:35
      Server is down.
      EDIT:
      Setting ORESTY_HEADERSMORE='y' and recompiling nginx and we are running again.
      I guess..
      more_set_headers "Server: nginx centminmod";
      more_set_headers "X-Powered-By: centminmod";
      ..is added to nginx.conf no matter if ORESTY_HEADERSMORE is et to "n"
    37,710
    8,254
    12:32 AM
    if you disable headers more nginx module, comment out
    FYI, headers more is also used for letsencrypt integration in addons/acmetool.sh and also in wordpress centmin.sh menu option 22's redis nginx level caching so best to leave it enabled.
  3. noly
    noly Member
    93
    13
    Germany
    3:32 PM
    1.13.x
    10.x
    Thanks for the hint. (y)
    37,710
    8,254
    12:32 AM
    If you just want to remove the server headers, you do not need to disable headers more. Just override the headers as per docs at https://github.com/openresty/headers-more-nginx-module
    i.e. don't remove the first 2 as centmin mod checks to see if they're missing and re-adds them anyway
    more_set_headers "Server: nginx";
    more_clear_headers "X-Powered-By";
    might add those last 2 to default nginx.conf template commented out so folks can uncomment to enable.
    curl -I localhost
    HTTP/1.1 200 OK
    Date: Fri, 29 Sep 2017 03:07:08 GMT
    Content-Length: 3801
    Last-Modified: Tue, 04 Apr 2017 07:34:43 GMT
    Connection: keep-alive
    Vary: Accept-Encoding
    ETag: "58e34c93-ed9"
    Server: nginx
    Accept-Ranges: bytes
    This will then keep other centmin mod features which rely on headers more nginx module working
    Server header can be whatever you want they it follows the format above "Server: whatever".
  5. noly
    noly Member
    93
    13
    Germany
    3:32 PM
    1.13.x
    10.x
    Do these entries in the custom_config.inc...
    ...modify the default more_set_headers name?
    37,710
    8,254
    12:32 AM
    no those no longer needed, just do what is outlined in 4th post of this thread
  7. noly
    noly Member
    93
    13
    Germany
    3:32 PM
    1.13.x
    10.x
    Doing so. Thank you! Just trying to understand everything. :)
