Beta Branch re-enable NGINX_MODSECURITY_MAXMIND='y' in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Mar 4, 2020.
    60,082
    12,584
    10:32 AM
    - change default from NGINX_MODSECURITY_MAXMIND='n' back to NGINX_MODSECURITY_MAXMIND='y' now that bug is fixed for outdated libmaxmindb version (update to libmaxmindb 1.4.2) Beta Branch - ModSecurity's OWASP Core Rule Set 3.2.0 in 123.09beta01
    /usr/local/bin/mmdblookup --version
      mmdblookup version 1.4.2
    ModSecurity -  for Linux
     Mandatory dependencies
       + libInjection                                  ....v3.9.2-30-gbf234eb
       + SecLang tests                                 ....c8cf2c5
     Optional dependencies
       + GeoIP/MaxMind                                 ....found
          * (MaxMind) v1.4.2
             -lmaxminddb  , -DWITH_MAXMIND -I/usr/local/include
          * (GeoIP) v1.6.12
             -lGeoIP  , -I/usr/include/
       + LibCURL                                       ....found v7.68.0
          -lcurl,  -DWITH_CURL_SSLVERSION_TLSv1_2 -DWITH_CURL
       + YAJL                                          ....found v2.0.4
          -lyajl  , -DWITH_YAJL
       + LMDB                                          ....disabled
       + LibXML2                                       ....found v2.9.10
          -lxml2 -lz -llzma -lm -ldl, -I/usr/include/libxml2 -DWITH_LIBXML2
       + SSDEEP                                        ....found
          -lfuzzy -L/usr/lib64/, -DWITH_SSDEEP -I/usr/include
       + LUA                                           ....found v501
          -llua-5.1 -L/usr/lib64/, -DWITH_LUA -DWITH_LUA_5_1 -I/usr/include
     Other Options
       + Test Utilities                                ....enabled
       + SecDebugLog                                   ....enabled
       + afl fuzzer                                    ....disabled
       + library examples                              ....enabled
       + Building parser                               ....disabled
       + Treating pm operations as critical section    ....disabled
    123.09beta01 branch
