Menu Issue
Discussion in 'Bug Reports' started by Jimmy, Jan 11, 2016.
  1. Jimmy
    390
    5:20 AM
    Found this weird issue with the Mod Menu.
    I'm currently running 1.2.3-eva2000.09
    Reproduce:
    1. #23
    2. #3
    3. Select 1.2.3-eva2000.09 and run update.
    4. #4
    5. #24 will give me the Centmin Mod Updater Sub-Menu (#23) - won't exit.
    So, after the update I can't exit out of the Centmin Mod Menu. If I hard exit out of the menu and restart the menu #24 then works again.
    It also appears to clone 09 every time vs. updating it when I'm already running 1.2.3-eva2000.09
    55,223
    12,253
    7:20 PM
    to update existing .09 you run menu option 23 submenu option 2 not submenu option 3. Submenu option 3 will also clone again as it considers it a new branch you want, submenu option 2 will do git pull update
    after running submenu option 3, you will need to run menu option 4 then 4 again to exist submenu 23 then menu 24 as it works now
  3. Jimmy
    390
    5:20 AM
    Ok. So, to exit out to the command prompt, after a #2 update, I need to go back into the sub-menu and exit out again before it will allow me to exit out via #24.
    55,223
    12,253
    7:20 PM
    think of it like mobile phone, just keeping backing out/exiting the current menu until you're out :D
  5. Jimmy
    390
    5:20 AM
    I'm not sure what you mean? My mobile phone doesn't have a menu. :ROFLMAO:
