Memcached Memcrashed - Major amplification attacks from UDP port 11211
Discussion in 'Other Centmin Mod Installed software' started by pamamolf, Feb 28, 2018.
    3:29 AM
    Centmin Mod CSF or non-Centmin Mod ? memcached listening on localhost/127.0.0.1 ? or not ? If listening locally then it isn't possible for the memcached server to be apart of the attack AFAIK ? Probably need to ask Hivelocity for the actual proof and how they detected a publicly open memcached server. Unless they also mistakenly used nmap and saw open|filtered state and came to the wrong conclusion that the state means = open when it fact it means = closed.
    3:29 AM
    DDOS attack size record has been broken with Memcrashed at 1.7Tbps DDOS Attack World's biggest DDoS attack record broken after just five days
  3. pamamolf
    4,128
    8:29 PM
    3:29 AM
    thanks for heads up - but wow even worse that first though
    3:29 AM
    curious if you ended up figuring out if memcached 11211 UDP ports were actually open or if Hivelocity's checks were mistaken ?
    3:29 AM
    hmmm Memcached DDoS Exploit Code and List of 17,000 Vulnerable Servers Released
  7. Matt
    Matt Well-Known Member
    937
    415
    Rotherham, UK
    6:29 PM
    1.5.15
    MariaDB 10.2
    My customers asked the question, but I've not received a response. I know for a fact the port was closed on the firewall.
    3:29 AM
    Thanks Matt seems some web hosts are just throwing everything into the Memcrashed pile. I had one web host say my cpu load was due to Memcrashed, when it was in fact the VPS running out of disk space causing load issues heh.
    3:29 AM
    OVH write up https://www.ovh.com/ca/en/news/arti...de?xtor=ES-11-[news]-20180320-[memcached.cta]
