Memcache for the forum and APC for other requests?
Discussion in 'Forum software usage' started by pamamolf, Jul 7, 2014.
    4,101
    428
    7:11 PM
    Nginx-1.26.x
    Hi
    On a forum i was wondering if the best solution is to use at the forum configs the memcache and leave the APC to cache the rest?
    Thank you
    55,801
    12,271
    2:11 AM
    yes APC Cache or Zend OpCache for PHP files and for forum data caching memcached
  3. rdan
    1,412
    12:11 AM
    It thought APC also work for data caching?
    55,801
    12,271
    2:11 AM
    yeah it does but APC Cache for data caching has high fragmentation of cache unlike Memcached for data caching
  5. pamamolf
    4,101
    428
    7:11 PM
    Nginx-1.26.x
    Memcached always using less than 1 mb on a forum and yes i have been activated on the config file as ips wants ...
    I don't know if this is normal but seems to law if you compare it with APC usage at 70mb about :)
    Ok it is not too active forum but only 700kb about?
    55,801
    12,271
    2:11 AM
    yes because most forums don't utilise alot of data caching so memcached usage is low
    APC memory usage includes both php opcode cache + data cache, so opcode cached memory usage makes up majority for usage
  7. rdan
    1,412
    12:11 AM
    My forum is consuming data caching of memcached from 400mb to 1gb.
  8. pamamolf
    4,101
    428
    7:11 PM
    Nginx-1.26.x
    Xenforo or vbulletin?
    55,801
    12,271
    2:11 AM
    i believe @RoldanLT is talking about his Xenforo forums
    really depends on forum software and it's plugins/addons
    For vBulletin + vB Optimise Pro I have clients doing nearly 4,000 memcached requests/second and 10 billion cache hits per month with 200-600MB of cached data i.e. http://vbtechsupport.com/1526/
  10. rdan
    1,412
    12:11 AM
    Yes on my XenForo Forum.
    XenForo alone takes 300mb to 500MB of the cache and the rest is from ngx_pagespeed :)
