PHP-FPM Max execution time php-fpm and nginx
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Glock, Jan 25, 2016.
  1. Glock
    Glock New Member
    15
    7
    11:45 AM
    Hi all,
    Hope everyone is well..
    Okay bit of a tricky one, but probably not for you guys.
    I am rebuilding my gallery thumbnails and watermarks - of which there are thousands!
    Anyway I constantly get max execution time exceeded 120 etc.
    As a result it's also affecting installing and removing things as the system is still trying to execute my call to clear caches and rebuild parts of the gallery.
    I thought okay so adjust php.ini - no go. So then I added lines to nginx config, still no joy.
    So I have removed all again and am a bit stuck, how do I extend the execution time, for the script and then put it back once I am finished?
    I found some guides online, but nothing exactly specific to this.
    Many thanks in advance all!
    54,868
    12,239
    9:45 PM
  3. Glock
    Glock New Member
    15
    7
    11:45 AM
    54,868
    12,239
    9:45 PM
    centmin mod php custom max execution time is 60s anyway centminmod/phpsededit.inc at 123.08stable · centminmod/centminmod · GitHub so not sure where you get 120 limit from
    or is important from name of custom php ini file has to be after the default custom php file /etc/centminmod/php.d/a_customphp.ini https://community.centminmod.com/posts/21135/
    what's output of
    php --ini
    ensure your custom php.ini file is named alphabetically so it lists after /etc/centminmod/php.d/a_customphp.ini
    if you still get 120s, then your web php app has it's own set limit you need to adjust
  5. Glock
    Glock New Member
    15
    7
    11:45 AM
    Okay I have redone it to the exact replica created b_customphp.ini with max_execution_time = 360 and restarted php and nginx
    ErrorException: Fatal Error: Maximum execution time of 120 seconds exceeded - library/XenGallery/Helper/Image.php:294
  6. Glock
    Glock New Member
    15
    7
    11:45 AM
    /etc/centminmod/php.d/b_customphp.ini,
    /etc/centminmod/php.d/mongodb.ini,
    Hmm okay, I will check the others too, as I adjusted it now to 360 and still get 120.
  7. Glock
    Glock New Member
    15
    7
    11:45 AM
    How strange, after about another 7-8 attempts to execute this, (clearing the caches) - it's done it on its own this time.
    Thank you for the help, appreciated. The execution time is still the same, but at least this completed finally.
    Many thanks!
    54,868
    12,239
    9:45 PM
    curious what php app is this ?
  9. Glock
    Glock New Member
    15
    7
    11:45 AM
    Literally, rebuilding the gallery caches for watermarks in XF. Under tools > rebuild caches > Rebuild XenForo Media Gallery Watermarks
    It went eventually but after many, many, attempts. I watched as it did almost 8k items, but when it was failing, it was always at around 5,550 -odd.
    Always the same response, max execution time succeeded.
    It's still 120 and I have no idea what is governing this now as I changed all the files that I know were mentioned in the guides, over the last few days and also following your advice. :confused:
    54,868
    12,239
    9:45 PM
    Xenforo doesn't set max_execution_time AFAIK unless the XMG does.
  11. rdan
    1,408
    7:45 PM
    On your /library/config.php, add:
    ini_set('max_execution_time', 300);
