MariaDB MariaDB not starting
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Sep 22, 2017.
    3,169
    304
    10:12 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    • Nginx Version Installed:1.11.10
    • PHP Version Installed: 7.0.15
    Hello :)
    MariaDB 10.1.26 is not starting:
       Active: failed (Result: exit-code) since Fri 2017-09-22 13:13:54 UTC; 15min ago
      Process: 12228 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
      Process: 11994 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
      Process: 11991 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
     Main PID: 12228 (code=exited, status=1/FAILURE)
       Status: "MariaDB server is down"
    Sep 22 13:13:49 server.mydomain.com mysqld[12228]: 2017-09-22 13:13:49 140249171196160 [ERROR] Plugin 'InnoDB' init function returned error.
    Sep 22 13:13:49 server.mydomain.com mysqld[12228]: 2017-09-22 13:13:49 140249171196160 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    Sep 22 13:13:49 server.mydomain.com mysqld[12228]: 2017-09-22 13:13:49 140249171196160 [Note] Plugin 'FEEDBACK' is disabled.
    Sep 22 13:13:49 server.mydomain.com mysqld[12228]: 2017-09-22 13:13:49 140249171196160 [ERROR] Unknown/unsupported storage engine: InnoDB
    Sep 22 13:13:49 server.mydomain.com mysqld[12228]: 2017-09-22 13:13:49 140249171196160 [ERROR] Aborting
    Sep 22 13:13:54 server.mydomain.com mysqld[12228]: Error in my_thread_global_end(): 1 threads didn't exit
    Sep 22 13:13:54 server.mydomain.com systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
    Sep 22 13:13:54 server.mydomain.com systemd[1]: Failed to start MariaDB database server.
    Sep 22 13:13:54 server.mydomain.com systemd[1]: Unit mariadb.service entered failed state.
    Sep 22 13:13:54 server.mydomain.com systemd[1]: mariadb.service failed.
    Any ideas?
    The mycnf is the default generated one with a few numeric simple values adjustments....
    It was working but after restart i got this :(
    Maybe to reinstall MariaDB?
    Thank you
  2. rdan
    rdan Premium Member Premium Member
    4,501
    1,079
    4:12 PM
    I think this is still CentOS 7.4 Bug :/.
    Yay!
  3. rdan
    4,501
    1,079
    4:12 PM
  4. pamamolf
    3,169
    304
    10:12 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    Yes it's not that bug :)
    One database was crash and i enable force recovery and it was start and then i delete it and re import it and all was fine again :)
    I am just wondering for any other possible better fixe for this:
    38,037
    8,356
    6:12 PM
    What web app using mysql ? what PHP version ? Did you just recently update PHP or PHP extensions ? Or restart php-fpm service too ?
    You got the above errors after you enabled force recovery or before ? Which of the 6 levels 1-6 of innodb_force_recovery did you enable ? You do know the higher levels can result in database data corruption too.
    Might also want to post output for mysql log to pastebin.com or gist.github.com
    CentOS 7 logs to journalctl
    journalctl -u mariadb --no-pager
  6. pamamolf
    3,169
    304
    10:12 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    It was after a server reboot:)
    Latest php 7.0.x version and Invision forums...
    The issue was that a script was running at the same time that the server rebooted and got corrupted...
    I was use level 1 as I know that up to level 3 is ok and then the issues may be bigger...
    Anyway all good now !
    38,037
    8,356
    6:12 PM
    Always flush your tables and logs before restarting mysql/server on a busy database server ;)
