MariaDB MariaDB fail to start
Discussion in 'MariaDB & General MySQL news & discussions' started by YuchiRO, Nov 10, 2016.
    60,089
    12,584
    3:33 PM
    need disk inode count too
    df -hTi
    lsof +L1
  2. YuchiRO
    YuchiRO Member
    100
    6
    12:33 PM
    5.5.4
    df -hTi
    Filesystem          Type     Inodes IUsed IFree IUse% Mounted on
    /dev/mapper/vg-root ext4        26M  967K   25M    4% /
    devtmpfs            devtmpfs   7.9M   499  7.9M    1% /dev
    tmpfs               tmpfs      7.9M     1  7.9M    1% /dev/shm
    tmpfs               tmpfs      7.9M   653  7.9M    1% /run
    tmpfs               tmpfs      7.9M    13  7.9M    1% /sys/fs/cgroup
    /dev/sda1           ext2        63K   352   63K    1% /boot
    /dev/mapper/vg-tmp  ext4        64K   64K     0  100% /tmp
    tmpfs               tmpfs      7.9M     1  7.9M    1% /run/user/0
    lsof +L1
    COMMAND   PID  USER   FD   TYPE DEVICE SIZE/OFF NLINK NODE NAME
    php-fpm 11694  root    3u   REG  253,2        0     0 8196 /tmp/.ZendSem.PXuQnR (deleted)
    php-fpm 13450 nginx    3u   REG  253,2        0     0 8196 /tmp/.ZendSem.PXuQnR (deleted)
    php-fpm 13451 nginx    3u   REG  253,2        0     0 8196 /tmp/.ZendSem.PXuQnR (deleted)
    php-fpm 13459 nginx    3u   REG  253,2        0     0 8196 /tmp/.ZendSem.PXuQnR (deleted)
    php-fpm 13460 nginx    3u   REG  253,2        0     0 8196 /tmp/.ZendSem.PXuQnR (deleted)
    60,089
    12,584
    3:33 PM
    php-fpm temp files consumed 100% of your disk inodes probably with many temp files
    try first restarting nginx + php-fpm then start mariadb
    then try removing contents in /tmp and reboot server
    rm -rf /tmp/*
    what is contents for /etc/centminmod/php.d/zendopcache.ini
  4. YuchiRO
    YuchiRO Member
    100
    6
    12:33 PM
    5.5.4
    Work like charm after clear tmp files. Is possible to increase size of tmp folder ?
    Thanks your help
    60,089
    12,584
    3:33 PM
    contents of /etc/centminmod/php.d/zendopcache.ini ?
    really depends on how much if any unallocated disk space you have on your disk not already formatted for partitions as you current /tmp is a logical volume
    edit: found exactly your exact situation Enlarging /tmp dir - CentOS
    might want to contact your web host and see what options are available to you if you do not understand what you need to do
  6. YuchiRO
    YuchiRO Member
    100
    6
    12:33 PM
    5.5.4
    Here my zenopcache
    zend_extension=opcache.so
    ;opcache.error_log=/var/log/php_opcache_error.log
    opcache.enable=1
    opcache.memory_consumption=784
    opcache.interned_strings_buffer=8
    opcache.max_wasted_percentage=5
    opcache.max_accelerated_files=16000
    ; http://php.net/manual/en/opcache.configuration.php#ini.opcache.revalidate-freq
    ; defaults to zend opcache checking every 180 seconds for PHP file changes
    ; set to zero to check every second if you are doing alot of frequent
    ; php file edits/developer work
    ; opcache.revalidate_freq=0
    opcache.revalidate_freq=180
    opcache.fast_shutdown=0
    opcache.enable_cli=0
    opcache.save_comments=1
    opcache.enable_file_override=1
    opcache.validate_timestamps=1
    ;opcache.huge_code_pages=1
    My wordpress site using redis cache + w3 totalcache.
    My server is un-manage plan, they dont support that problems.
    60,089
    12,584
    3:33 PM
    then probably best to backup data and reload OS/repartition disk if you have control over how you partitioned and allocated /tmp size
    also might want to lower opcache memory allocation from opcache.memory_consumption=784 to
    opcache.memory_consumption=256 and restart php-fpm
    60,089
    12,584
    3:33 PM
    just to elaborate on previous post when you repartition on fresh OS, don't make a /tmp partition instead let /tmp reside in / with largest disk free space
