MariaDB MariaDB doesn’t work properly for fresh install
Discussion in 'Install & Upgrades or Pre-Install Questions' started by pdinh97qng, Nov 27, 2019.
  1. pdinh97qng
    pdinh97qng Member
    90
    9:50 AM
    i just setup a new VPS (Digitalocean) for a test website with some configurations. After the installation, I run the command “mysql” to make sure that MariaDB is installed. Yup it’s install but after the reboot, MariaDB doesn’t seem to start. Even I run a command to start MariaDB but useless. MariaDB is failed to start with the error unit not found. Since it’s new VPS, no data so I reinstalled everything again... same.
    Centos 7 64 bit
    MariaDB 10.4.x
    Nginx 1.17.6
    PHP 7.3.12.
    @eva2000 I have sent a message with VPS information so you can gather as much as logs you need.
    44,804
    10,217
    2:50 AM
  3. pdinh97qng
    pdinh97qng Member
    90
    9:50 AM
    Install logs: centminmod_123.09beta01.b330_261119-215123_install.log
    Custom:
    CRYPTO_DEVTOOLSETGCC='y'
    DEVTOOLSETEIGHT='y'
    DISABLE_TLSONEZERO_PROTOCOL='y'
    DUALCERTS='y'
    GCC_FALIGN_FUNCTION='y'
    GENERAL_DEVTOOLSETGCC='y'
    LETSENCRYPT_DETECT='y'
    MARCH_TARGETNATIVE='y'
    MARIADB_INSTALLTENFOUR='y'
    NGINX_BROTLIDEP_UPDATE='y'
    NGINX_DEVTOOLSETGCC='y'
    NGINX_DYNAMICTLS='y'
    NGINX_IPV='y'
    NGINX_HPACK='y'
    NGINX_LIBBROTLI='y'
    NGINXPATCH='y'
    NGXDYNAMIC_BROTLI='y'
    PHP_ARGON='y'
    PHP_BROTLI='y'
    PHP_LZFOUR='y'
    PHP_LZF='y'
    PHP_ZSTD='y'
    PHP_PGO='y'
    PHPFINFO=y
    #PHPPGO_INDEXPATH=''
    #PHPPGO_INDEXPATH_TWO=''
    PRIORITIZE_CHACHA_OPENSSL='y'
    PUREFTPD_DISABLED=y
    SELFSIGNEDSSL_C=US
    SELFSIGNEDSSL_L=Sacramento
    SELFSIGNEDSSL_ST=California
    SWITCH_PHPFPM_SYSTEMD='y'
    ZONEINFO=Asia/Singapore
    ZSTD_LOGROTATE_NGINX='y'
    ZSTD_LOGROTATE_PHPFPM='y'
    44,804
    10,217
    2:50 AM
    I removed the link to your install log as you didn't mask the login details and credentials. You'd want to do a fresh Centmin Mod install just to be safe with new login details/credentials.
    As to initial log all looks good MariaDB 10.4 was installed properly it seems as you opted to set
    MARIADB_INSTALLTENFOUR='y' in persistent config file at /etc/centminmod/custom_config.inc
    What output do you get for these commands ?
    alias to mariadb service
    service mysqld status | sed -e "s|$(hostname)|hostname|g"
    service mariadb status | sed -e "s|$(hostname)|hostname|g"
    systemctl status mariadb | sed -e "s|$(hostname)|hostname|g"
    ls -lah /etc/systemd/system/
    ls -lah /etc/systemd/system/multi-user.target.wants/
    44,804
    10,217
    2:50 AM
