MariaDB 10 - mariadb10fix.sh moved posts
Discussion in 'MariaDB & General MySQL news & discussions' started by rdan, Oct 10, 2014.
    1,354
    11:02 PM
  2. rdan
    1,354
    11:02 PM
    Specifically this:
    InnoDB: Memory barrier is not used
    InnoDB: Using CPU crc32 instructions
  3. rdan
    1,354
    11:02 PM
    With this script looks like it stops nginx, Why?
    After the script is run nginx is not running.
    I have to start it manually.
    And also what temporary files/folders need to delete after running this script?
    Like /home/mysql10fix.
    49,891
    11,489
    1:02 AM
  5. rdan
    1,354
    11:02 PM
    49,891
    11,489
    1:02 AM
    It's just a note regarding whether your cpu supports crc32 instructions which started with Intel Nehalem platform and introduction of SSE4.2 support
    Virtulbox instance i used for that log output you are comparing didn't have cpu flag support for SSE4.2 hence mine says not using CPU crc32 instructions. As to memory barrier instructions it's another thing specific to my virtualbox instance. As my live KVM based VPS server with MariaDB 10 in non-virtualbox shows same as yours
    141008  3:34:08 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    141008  3:34:08 [Note] InnoDB: The InnoDB memory heap is disabled
    141008  3:34:08 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    141008  3:34:08 [Note] InnoDB: Memory barrier is not used
    141008  3:34:08 [Note] InnoDB: Compressed tables use zlib 1.2.3
    141008  3:34:08 [Note] InnoDB: Using Linux native AIO
    141008  3:34:08 [Note] InnoDB: Not using CPU crc32 instructions
    141008  3:34:08 [Note] InnoDB: Initializing buffer pool, size = 48.0M
    141008  3:34:08 [Note] InnoDB: Completed initialization of buffer pool
    141008  3:34:08 [Note] InnoDB: Highest supported file format is Barracuda.
    141008  3:34:08 [Note] InnoDB: 128 rollback segment(s) are active.
    141008  3:34:08 [Note] InnoDB: Waiting for purge to start
    141008  3:34:08 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.20-68.0 started; log sequence number 1601336
    141008  3:34:08 [Note] Plugin 'FEDERATED' is disabled.
    141008  3:34:08 [Note] Plugin 'ARCHIVE' is disabled.
    141008  3:34:08 [Note] Plugin 'FEEDBACK' is disabled.
    141008  3:34:08 [Note] Server socket created on IP: '::'.
    141008  3:34:08 [Note] Event Scheduler: Loaded 0 events
    49,891
    11,489
    1:02 AM
    no temp files besides contents of /home/mysql10fix which you may want to download as a backup just in case
  8. rdan
    1,354
    11:02 PM
    That for the clarification Eva :)
    New insights for today :)
  9. rdan
    1,354
    11:02 PM
    So far no problem on my config and the output for mysqladmin var | tr -s ' ' ? :)
    49,891
    11,489
    1:02 AM
    Looks okay as far as I can see
  11. pamamolf
    4,003
    420
    6:02 PM
    Nginx-1.17.x
    What is this fix for?
    49,891
    11,489
    1:02 AM
