MariaDB MariaDB 10.3.x and up needs another value for innodb_buffer_pool_instances?
Discussion in 'MariaDB & General MySQL news & discussions' started by pamamolf, Apr 30, 2024.
    4,100
    428
    10:35 AM
    Nginx-1.26.x
    If i am understanding correctly using MariaDB 10.3.x and up the value:
    innodb_buffer_pool_instances=12
    According to:
    https://mariadb.com/kb/en/mariadb/xtradbinnodb-server-system-variables/#innodb_buffer_pool_instances
    should be set to 1
    I just install on Almalinux using the one line installer MariaDB 10.4.x and i can i got that value as:
    Maybe we can change it for better performance on Centminmod template?
    Thank you !
    55,155
    12,249
    5:35 PM
    Nice catch! Will update the template routines. FYI, for MariaDB 10.5+ Centmin Mod automatically removes innodb_buffer_pool_instances anyway as it's deprecated variable.
