MariaDB MariaDB 10.3.11, and MariaDB Connector/C 3.0.7, Connector/ODBC 3.0.7 and Connector/Node.js...
Discussion in 'MariaDB & General MySQL news & discussions' started by eva2000, Nov 21, 2018.
    54,361
    12,198
    12:32 AM
    The MariaDB Foundation is pleased to announce the availability of MariaDB 10.3.11, the latest stable release in the MariaDB 10.3 series, as well as MariaDB Connector/C 3.0.7 and MariaDB Connector/ODBC 3.0.7, both stable releases, and MariaDB Connector/Node.js 2.0.1, the first beta release of the new 100% JavaScript non-blocking MariaDB client for Node.js, compatible with Node.js […]
    The post MariaDB 10.3.11, and MariaDB Connector/C 3.0.7, Connector/ODBC 3.0.7 and Connector/Node.js 2.0.1 now available appeared first on MariaDB.org.
  2. Itworx4me
    Itworx4me Active Member
    301
    6:32 AM
    Nginx 1.25.X
    MariaDB 10.6.X
    There are no current yum updates for 10.3.11. Any ideas?
    Thanks,
    Itworx4me
    54,361
    12,198
    12:32 AM
    yum updates only for major branch installed at time so 10.1 in 123.09beta01 and need using centmin.sh menu option 11 to upgrade major versions from 10.1 to 10.2 and 10.2 to 10.3 but those upgrade menus disabled for private testing for now
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Install/Re-Install
    24). Exit
    Enter option [ 1 - 24 ] 11
         MariaDB MySQL Upgrade & Management Sub-Menu
    0). Regenerate New MySQL Root User Password (local server)
    1). MariaDB 5.2.x Branch Upgrade Only
    2). MariaDB 5.2.x to MariaDB 5.5 YUM upgrade
    3). MariaDB 5.5 to MariaDB 10.x YUM upgrade
    4). MariaDB 5.5 to MariaDB 10.1.x YUM upgrade
    5). MariaDB 10.x to MariaDB 10.1.x YUM upgrade
    6). MariaDB 10.1.x to MariaDB 10.2.x YUM upgrade
    7). MariaDB 10.2.x to MariaDB 10.3.x YUM upgrade
    8). Back to Main menu
    Enter option [ 0 - 8 ]
  4. Itworx4me
    301
    6:32 AM
    Nginx 1.25.X
    MariaDB 10.6.X
    Thanks for the reply. I so mis-read the version number..
    Thank You
    Itworx4me
