MariaDB MariaDB 10.1 is stable GA
Discussion in 'MariaDB & General MySQL news & discussions' started by eva2000, Oct 17, 2015.
  1. Ahmad
    Ahmad Active Member
    209
    80
    1:33 AM
    1.9.9
    10.1.10
    Yes:
    [root@server ~]# service mysql status
     ERROR! MySQL is running but PID file could not be found
    [root@server ~]# service mariadb status
    Redirecting to /bin/systemctl status  mariadb.service
    ● mariadb.service - MariaDB database server
      Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
      Drop-In: /etc/systemd/system/mariadb.service.d
      └─mdb101.conf, migrated-from-my.cnf-settings.conf
      Active: active (running) since Sa 2015-12-26 22:05:25 UTC; 26min ago
     Main PID: 9026 (mysqld)
      Status: "Taking your SQL requests now..."
      CGroup: /system.slice/mariadb.service
      └─9026 /usr/sbin/mysqld
    Dez 26 22:05:25 server.absolutehacks.com systemd[1]: Starting MariaDB database server...
    Dez 26 22:05:25 server.absolutehacks.com mysqld[9026]: 2015-12-26 22:05:25 140136908179584 [Note] /usr/sbin/m......
    Dez 26 22:05:25 server.absolutehacks.com systemd[1]: Started MariaDB database server.
    Hint: Some lines were ellipsized, use -l to show in full.
    Is the other server running CentOS 7 too or 6?
    I do not have another CentOS 7 server that runs 10.1.9, so cannot test it but I had the same issue before just not sure if it was on 10.0.x or 10.1.9.
    Found the bug report:
    [MDEV-9227] Both CentOS service names mysql and mariadb exist ? - JIRA reported for 10.1.9 and should be fixed now but it isn't apparently.
  2. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    1:33 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Upgraded from 10.0.23 to 10.1.10, all went OK
  3. Ahmad
    Ahmad Active Member
    209
    80
    1:33 AM
    1.9.9
    10.1.10
  4. negative
    negative Active Member
    415
    50
    2:33 AM
    1.9.10
    10.1.11
    60,082
    12,584
    9:33 AM
