Xenforo Making the best use of Redis for Xenforo 2?
Discussion in 'Forum software usage' started by Jon Snow, Feb 4, 2019.
    59,738
    10:54 AM
    did you try just restarting the other redis server instances ?
    I am not having any problems on my test Xenforo 2.1 install with redis on the custom redis server ports even after updating main redis from 5.0.9 to 6.0.1 while custom redis server ports run 5.0.9 binary. To update custom redis server 5.0.9 binary you would need to destroy and recreate the custom redis server instances using redis generator script.
    does redis runtime directory exist ?
    ls -lah /var/run/redis
    edit: something has changed in original redis service file and/or centos systemd as restarting redis original service will create /var/run/redis runtime directory but on starting redis6479 etc service will remove the /var/run/redis runtime directory or combined with Services using the "Type=Notify" and "NotifyAccess=All" settings are vulnerable to being inadvertently shut down by other services - Red Hat Customer Portal. Will have to investigate
    edit: Looks like Plesk users have same issue with distro provided redis 6 updated servers Question - Changes to use Redis 6.0 in Plesk
    For a temp workaround, you can downgrade back to redis 5.0.9 and version lock the package so yum updates do not update to redis 6 until you version unlock it
    yum -y downgrade redis --enablerepo=remi
    yum versionlock redis
    Adding versionlock on: 0:redis-5.0.9-1.el7.remi
    versionlock added: 1
    I confirm additional redis servers start up fine when downgraded to redis 5.0.9
    when ready to update to redis 6 again, do version unlock and yum update
    yum versionlock delete redis
    yum -y update redis --enablerepo=remi
    Deleting versionlock for: 0:redis-5.0.9-1.el7.remi.*
    versionlock deleted: 1
    edit: seems changing the systemd service file's Type from notify to forking in redis6479 and redis6480 service files seems to allow redis 6 to start up
    so for /usr/lib/systemd/system/redis6480.service
    [Unit]
    Description=Redis persistent key-value database
    After=network.target
    [Service]
    ExecStart=/etc/redis6480/redis-server /etc/redis6480/redis6480.conf --supervised systemd
    ExecStop=/usr/local/bin/redis6480-shutdown
    Type=forking
    User=redis
    Group=redis
    RuntimeDirectory=redis
    RuntimeDirectoryMode=0755
    [Install]
    WantedBy=multi-user.target
    then do
    systemctl daemon-reload
    service redis6480 restart
    you can do changes via sed replacement from command line too
    sed -i 's|Type=notify|Type=forking|' /usr/lib/systemd/system/redis6479.service
    sed -i 's|Type=notify|Type=forking|' /usr/lib/systemd/system/redis6480.service
    systemctl restart redis6479 redis6480
    I've updated redis-generator.sh with the change too in commit at update redis-generator.sh for redis 6 systemd startup compatibility · centminmod/centminmod-redis@31f189b
  2. pamamolf
    4,127
    3:54 AM
    Is this something that we must edit manually ?
    I didn't notice any issues yet but it will be good to know if i have to edit anything to avoid any related issues...
  3. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    2:54 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    This error show to me when I reboot server. So if you update to redis v6, all will work OK, but first time you rbbot server it will begin throwing errors (only if you use older version for crating 2 another ports from script)
  4. Sunka
    1,150
    325
    Pula, Croatia
    2:54 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    I can confirm that after reboot everything seems fine. Using redis v6.0.1
    I used @eva2000 suggestion for manual changes
    Existing users can manually make changes i.e. for redis6479 and redis6480 services
    59,738
    10:54 AM
    Good to know, did you do the other suggested change in @redbot's thread at Redis - redis6479 & redis6480 unable to start
    59,738
    10:54 AM
    This only applies to additional redis server instances generated with my unofficial/unsupported redis-generator.sh script at centminmod/centminmod-redis. Default Redis server installed via REMI YUM repo is unaffected by the issue @Sunka reported. You can see the last 2 commits for the fixes on May 5 and 7 at centminmod/centminmod-redis.
    I've added this note to the Readme at centminmod/centminmod-redis
  7. Sunka
    1,150
    325
    Pula, Croatia
    2:54 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    # ls -lah /var/run/redis
    total 8.0K
    drwxr-xr-x  2 redis nginx  80 May  8  2020 .
    drwxr-xr-x 29 root  root  820 May  8 01:13 ..
    -rw-r--r--  1 redis nginx   4 May  8  2020 redis_6480.pid
    -rw-r--r--  1 redis nginx   4 May  8  2020 redis_6481.pid
    # cat /etc/tmpfiles.d/redis.conf
    cat: /etc/tmpfiles.d/redis.conf: No such file or directory
    # cd  /etc/tmpfiles.d/
    # rm -f  /etc/tmpfiles.d/redis.conf
    59,738
    10:54 AM
    Looks right to me :)
  9. pamamolf
    4,127
    3:54 AM
    As i am using only your Redis installation script and not the generator it should be ok for me ....
  10. pdinh97qng
    pdinh97qng Member
    121
    15
    5:54 PM
    I just installed a new server with redis using the installer and generator and can't connect to redis.
    creating redis server: redis6479.service [increment value: 0]
    redis TCP port: 6479
    create systemd redis6479.service
    cp -a /usr/lib/systemd/system/redis.service /usr/lib/systemd/system/redis6479.service
    create /etc/redis6479/redis6479.conf config file
    mkdir -p /etc/redis6479
    cp -a /etc/redis.conf /etc/redis6479/redis6479.conf
    -rw-r----- 1 redis root 81K May 17 13:31 /etc/redis6479/redis6479.conf
    -rw-r--r-- 1 root  root 332 May 20 08:36 /usr/lib/systemd/system/redis6479.service
    Job for redis6479.service failed because a timeout was exceeded. See "systemctl status redis6479.service" and "journalctl -xe" for details.
    Created symlink from /etc/systemd/system/multi-user.target.wants/redis6479.service to /usr/lib/systemd/system/redis6479.service.
    Note: Forwarding request to 'systemctl enable redis6479.service'.
    ## Redis TCP 6479 Info ##
    Could not connect to Redis at 127.0.0.1:6479: Connection refused
    creating redis server: redis6480.service [increment value: 1]
    redis TCP port: 6480
    create systemd redis6480.service
    cp -a /usr/lib/systemd/system/redis.service /usr/lib/systemd/system/redis6480.service
    create /etc/redis6480/redis6480.conf config file
    mkdir -p /etc/redis6480
    cp -a /etc/redis.conf /etc/redis6480/redis6480.conf
    -rw-r----- 1 redis root 81K May 17 13:31 /etc/redis6480/redis6480.conf
    -rw-r--r-- 1 root  root 332 May 20 08:38 /usr/lib/systemd/system/redis6480.service
    Job for redis6480.service failed because a timeout was exceeded. See "systemctl status redis6480.service" and "journalctl -xe" for details.
    Created symlink from /etc/systemd/system/multi-user.target.wants/redis6480.service to /usr/lib/systemd/system/redis6480.service.
    Note: Forwarding request to 'systemctl enable redis6480.service'.
    ## Redis TCP 6480 Info ##
    Could not connect to Redis at 127.0.0.1:6480: Connection refused
  11. elargento
    elargento Member
    353
    9:54 PM
    do you apply it to guests or users too?
    59,738
    10:54 AM
    can only be for guests
