Maintenace whitelisting and IPB admin directory
Discussion in 'Install & Upgrades or Pre-Install Questions' started by menister, Aug 11, 2019.
  1. menister
    menister New Member
    9
    8:28 PM
    1.15.12
    10.3.15
    CentOS Version: CentOS 7 64bit ?
    Centmin Mod Version Installed: 123.09beta01
    Nginx Version Installed: 1.17.2
    PHP Version Installed: 7.2.21
    MariaDB MySQL Version Installed: 10.3.17
    When was last time updated Centmin Mod code base ? : 1 hour ago
    Persistent Config:
        AUTOHARDTUNE_NGINXBACKLOG='y'
        ZSTD_LOGROTATE_NGINX='y'
        ZSTD_LOGROTATE_PHPFPM='y'
        NGINX_LIBBROTLI='y'
        NGXDYNAMIC_BROTLI='y'
        PHP_PGO='y'
        PHP_BROTLI='y'
        PHP_LZFOUR='y'
        PHP_LZF='y'
        PHP_ZSTD='y'
        MARCH_TARGETNATIVE='n'
        LETSENCRYPT_DETECT='y'
        DUALCERTS='y'
        AUDITD_ENABLE='y'
    Hello, I am currently trying to install IPB and have a little issues with the maintenance mode and securing the admin folder.
    I have whitelisted my IPv4 to the maintenance.conf and restarted nginx/php with nprestart, but I still see the maintenance mode, even on different browsers.
             # IPs you can whitelist from maintenance mode
             geo $maint_whitelist {
                  include /usr/local/nginx/conf/sitestatus.conf;
                  127.0.0.1 0;
                  MYIPv4 0;
             map $http_host$uri $exclude_url {
                  default                                                0;
                  "~^newdomain1.com/js/jquery.fittext.js"                1;
                  "~^newdomain1.com/blog/js/jquery.fittext.js"           1;
             map $maint_whitelist$exclude_url $maintenance {
                  default        1;
                  10             1;
                  11             1;
                  00             0;
                  01             0;
    And for the IPB Admin part:
    This part is in my ssl.conf:
            # Mask fake admin directory
            # Must comment this during install.  Uncomment after you change the name of the admin directory.
             location ~^/admin/(.*)$ {
                deny all;
            # Secure real Admin Directory
            # Replace /your_admin_renamed_directory/ with your renamed directory.
             location ~ ^/RANDOMSTRING/.+\.php$ {
                allow 127.0.0.1;
                deny all;
                auth_basic "Restricted Area";
                auth_basic_user_file /usr/local/nginx/conf/htpasswd_admin_php;
                allow MYIPv4;
    I have generated the htpasswd_admin_php with:
        htpasswd -c /etc/nginx/.htpasswd username
    Thats the output from the error.log:
        2019/08/10 14:48:57 [error] 18206#18206: *8 access forbidden by rule, client: 141.101.XX.XX, server: DOMAIN.com, request: "GET /RANDOMSTRING/ HTTP/1.1", host: "DOMAIN.com"
        2019/08/10 14:49:03 [error] 18206#18206: *9 access forbidden by rule, client: 172.69.XX.XX, server: DOMAIN.com, request: "GET /RANDOMSTRING/ HTTP/1.1", host: "DOMAIN.com"
        2019/08/10 14:55:08 [error] 18206#18206: *21 access forbidden by rule, client: 141.101.XX.XX, server: DOMAIN.com, request: "GET /RANDOMSTRING/ HTTP/1.1", host: "DOMAIN.com"
    PS: none of those listed IPs in the error.log is mine o_O
    41,080
    9,188
    4:28 AM
    I assume maintenance mode via https://community.centminmod.com/threads/sitestatus-maintenance-mode.5599/ right ?
    are you behind cloudflare or a front end reverse proxy in front of Centmin Mod Nginx ? if so you need to ensure proper nginx real IP configuration is done otherwise, Centmin Mod Nginx will see visitor's IP coming from cloudflare or reverse proxy server IP and not the visitor's IP.
    • Winner Winner x 1
  3. menister
    menister New Member
    9
    8:28 PM
    1.15.12
    10.3.15
    Cloudflare, uncomment the cloudflare.conf part in the ssl.conf..working now. So blind...
    But the IPB Admin part is still bugging me.
    41,080
    9,188
    4:28 AM
    haha it's the simple stuff we overlook :)
    admin logs look right if those ips aren't yours, then the admin protection is working blocking access
  5. menister
    menister New Member
    9
    8:28 PM
    1.15.12
    10.3.15
    Yeah but I don't have access aswell :D
    Getting 403 Forbidden
    41,080
    9,188
    4:28 AM
    try placing your allow IP; directive above the deny all; and restart nginx/php-fpm
    see http://nginx.org/en/docs/http/ngx_http_access_module.html
    • Winner Winner x 1
  7. menister
    menister New Member
    9
    8:28 PM
    1.15.12
    10.3.15
    Man, eva.. you are the best!
    Its working!
    Just need to figure out why its redirecting to /admin as soon as I login and therefore giving me forbidden, since /admin is denied.
    iirc, I need to put the new admin folder somewhere in a config file or was that only for IPB 3.X?
    41,080
    9,188
    4:28 AM
  9. Jimmy
    321
    2:28 PM
    You need to add the new admin location to the constants.php file.
    \define( 'CP_DIRECTORY', 'mydirectory' );
    • Winner Winner x 1
  10. menister
    menister New Member
    9
    8:28 PM
    1.15.12
    10.3.15
    Perfect!
    It works!
    Thank you very much.
