Discussion in 'VPS Provider Network Status' started by eva2000, Sep 29, 2017.
    39,245
    8,656
    10:54 AM
    Sep 28, 20:30 UTC
    Investigating - Linode has received several Xen Security Advisories (XSAs) that requires us to perform updates to our legacy Xen host servers. In order to apply the updates, hosts and the Linodes running on them must be rebooted. The XSAs will be publicly released by the Xen project team on October 12th. We must complete this maintenance before then.
    These updates are required to protect the security and safe operations of not only our infrastructure but yours as well. We understand that a disruption with such limited notice is inconvenient, and we hope you understand that we have no control over the disclosure date of this XSA. As such, we must adhere to this strict timeline to ensure the security of both our customers and platform. We strongly recommend you read through our Reboot guide, which will help you prepare your Linode for these reboots. The Reboot guide is available here:
    Each Linode's maintenance window will be communicated to you via email and will also be visible within the Linode Manager. Unfortunately, unless you’re able to upgrade to KVM, due to the logistical demands of this effort your assigned maintenance windows are not changeable and the host reboots are mandatory. KVM is currently not available in Tokyo 1, which means Linodes in Tokyo will have to undergo maintenance on-schedule.
    During the maintenance window, Linode instances will be cleanly shut down while we perform the updates. Your Linode will be inaccessible during this time. A two-hour window is allocated, however, the actual downtime should be much less. After the maintenance, each Linode will then be returned to its last state (running or powered off).
