Discussion in 'VPS Provider Network Status' started by eva2000, Jun 22, 2017.
    38,013
    8,341
    11:25 PM
    May 2, 12:23 UTC
    Resolved - We have successfully completed this maintenance before the embargo date. Please reach out to our Support team if you have any questions.
    Apr 19, 15:22 UTC
    Identified - Linode has received several Xen Security Advisories (XSAs) that require us to perform updates to our legacy Xen host servers. In order to apply these updates, hosts and the Linodes running on them must be rebooted. The XSAs will be publicly released by the Xen project team on May 2nd at 12:00 UTC. We must complete this maintenance before then.
    These updates are required to protect the security and safe operations of not only our infrastructure, but yours as well. We understand that a disruption with such limited notice is inconvenient, and we hope you understand that we have no control over the disclosure dates of these XSAs. As such, we must adhere to this strict timeline to ensure the security of both our customers and platform. We strongly recommend you read through our Reboot guide, which will help you prepare your Linode for these reboots. The Reboot guide is available here:
    Each Linode's maintenance window will be communicated to you via email and will also be visible within the Linode Manager. Unfortunately, unless you’re able to upgrade to KVM, due the logistical demands of this effort your assigned maintenance windows are not changeable and the host reboots are mandatory. All customers with Xen Linodes in our first Tokyo data center are strongly encouraged to upgrade and migrate to KVM in our new Tokyo 2 facility.
    During the maintenance window, Linode instances will be cleanly shut down while we perform the updates. Your Linode will be inaccessible during this time. A two-hour window is allocated, however the actual downtime should be much less. After the maintenance, each Linode will then be returned to its last state (running or powered off).
