Master Branch add addons/ruby.sh in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Dec 25, 2018.
    6:09 AM
    - Add ruby version manager (rvm) based ruby installer https://rvm.io/. Allows you to install ruby versions newer than CentOS distro provided versions - CentOS 6 uses ruby 1.8.3 and CentOS 7 uses 2.0.0 while latest right now is 2.5.3. Some gem installs require ruby version >1.9 which CentOS 6 systems are not able to satisfy without installing new ruby version via rvm. This addons/ruby.sh allows CentOS 6 systems to installer ruby version newer than the default 1.8.3 via yum packages.
    - After running ruby.sh install, will need to exit your SSH session and re-login one time to get the correct ruby version PATH detected.
