Beta Branch LetsEncrypt issue
Discussion in 'Beta release code' started by Matt Williams, Dec 7, 2015.
    59,950
    12,556
    10:39 AM
    yup Cloudflare DNS only should work :)
  2. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    Same issue - tried a different domain this time with the development mode on for Cloudflare so im going to use namecheap DNS for one of my test domains and see if that works
    59,950
    12,556
    10:39 AM
    same error exactly ?
  4. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    yes
  5. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    Still the same thing - took the domain off Cloudflare and used Vulr DNS
    installing or updating letsencrypt client
    Cloning into 'letsencrypt'...
    Updating letsencrypt and virtual environment dependencies.......
    Running with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt --server https://acme-v01.api.letsencrypt.org/directory
    No installers are available on your OS yet; try running "letsencrypt-auto certonly" to get a cert you can install manually
    system memory profile: 587 MB available
    Mem:            993         231         152          78         608         455
    Low:            993         840         152
    Swap:             0           0           0
    letsencrypt client is installed at:
    obtaining Letsencrypt SSL certificate via webroot authentication...
    /root/.local/share/letsencrypt/bin/letsencrypt -c /etc/letsencrypt/webroot.ini --user-agent centminmod-centos7-webroot --webroot-path /home/nginx/domains/wphstest4.xyz/public -d wphstest4.xyz -d www.wphstest4.xyz certonly
    Failed authorization procedure. www.wphstest4.xyz (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.wphstest4.xyz/.well-known/acme-challenge/W6PwR_Gkn3TomgxnXJG6xOs2q_xFYKWUNMVCtA0U [108.61.119.113]: 403, wphstest4.xyz (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://wphstest4.xyz/.well-known/acme-challenge/Xz2YczxBMMTEYiz1qRZ3-hbpurbT-1IXMSLmLIeg [108.61.119.113]: 403
    IMPORTANT NOTES:
    - The following 'urn:acme:error:unauthorized' errors were reported by
       the server:
       Domains: wphstest4.xyz, www.wphstest4.xyz
       Error: [B]The client lacks sufficient authorization[/B]
  6. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    im going to start over with a fresh VPS and new IP and change to namecheap DNS
    59,950
    12,556
    10:39 AM
  8. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    im using wphstest4.xyz now :=)
    59,950
    12,556
    10:39 AM
    dig -t NS wphstest4.xyz +short
    ns2.vultr.com.
    ns1.vultr.com.
  10. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    i changed back to namecheap dns so im just waiting for everything to propagate - this process almost makes it not worth it lol! Free or no free - I could have purchased an SSL for $5, installed it in 10 minutes and called it a night lol!
    59,950
    12,556
    10:39 AM
    59,950
    12,556
    10:39 AM
  13. Matt Williams
    537
    105
    Virginia, USA
    8:39 PM
    latest
    I'm going to install the beta09le on a new customer install and see if it works on their domain, They are using cloudflare DNS so I told them ahead of time to completely bypass cloudflare cache by enabling the development mode prior to running the LE install on the VPS so we'll see if it works for them :=)
    When it asked me to "register for a lets encrypt account" can I use the same email address for all of them?
    59,950
    12,556
    10:39 AM
    You only need to register email for letsencrypt account first time and it's used for all subsequent validations and LE ssl cert issuances on the server. So all future SSL cert expiry notifications also go to this email.
    59,950
    12,556
    10:39 AM
    Update: Apparently Letsencrypt domain validation works fine for webroot authentication method just not for other authentication methods. So Centmin Mod stack's webroot authentication should work fine !
  16. Shaiffulnizam Mohamad
    Shaiffulnizam Mohamad New Member
    29
    8:39 AM
    1.7.0
    5.5
    Hi eva, sorry for interrupting this thread. But I've encounter a new problem today. My problem is
    fatal: destination path 'letsencrypt' already exists and is not an empty directory.
    Updating letsencrypt and virtual environment dependencies......Command "/root/.local/share/letsencrypt/bin/python2.7 -c "import setuptools, tokenize;__file__='/tmp/pip-build-nmljjI/cryptography/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-nF1pEX-record/install-record.txt --single-version-externally-managed --compile --install-headers /root/.local/share/letsencrypt/include/site/python2.7/cryptography" failed with error code 1 in /tmp/pip-build-nmljjI/cryptography
    setup general /etc/letsencrypt/webroot.ini letsencrypt config file
    touch: cannot touch `/etc/letsencrypt/webroot.ini': No such file or directory
    inc/letsencrypt.inc: line 78: /etc/letsencrypt/webroot.ini: No such file or directory
    grep: /etc/letsencrypt/webroot.ini: No such file or directory
    /root/.local/share/letsencrypt/bin/letsencrypt not found
    What is this error and how to get over it?
    Thanks.
    59,950
    12,556
    10:39 AM
    find you nginx addvhost log at /root/centminlogs via command to list logs in ascending date order
    ls -Alrt /root/centminlogs
    and post it's contents to pastebin.com or gist.github.com so can see the full run
    looks like letsencrypt client failed to install or there was already a /root/tools/letsencrypt directory there
    was this 1st time ever you ran the 123.09beta01le branch's add vhost for letsencrypt ssl ?
  18. Shaiffulnizam Mohamad
    29
    8:39 AM
    1.7.0
    5.5
    Actually that is after I have successfully add 1 ssl, but after trying to add another one, then it fails. Will try again if this issues come across next time.
    59,950
    12,556
    10:39 AM
    the 2nd attempt run should have a /root/centminlogs logged file too so would be help to view to troubleshoot :)
  20. Z61
    Z61 New Member
    8:39 PM
    Hi, I'm clearly new to the board and new to the mod. I'm having issues with the le branch as well.
    Here's a pastebin of running vhost (this is after installing LE.)
    Centminmod new vhost log - Pastebin.com
