Beta Branch LetsEncrypt issue
Discussion in 'Beta release code' started by Matt Williams, Dec 7, 2015.
  1. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    Installed beta09le and ran auto WP setup and selected to get the LetsEncrypt SSL ad at the end I get:
    What does it mean lacks sufficient authorization? I thought they were in public beta now?
    55,158
    12,249
    6:17 AM
    2 reasons this could happen
    1. the .well-know url isn't working properly in Centmin Mod's Nginx implementation i.e. 403 error is permission denied
    2. you're hitting LE server side rate limits set during public beta see SSL - Letsencrypt Free SSL Public Beta December 3th 6PM GMT | Centmin Mod Community
    so if wphstest3.xyz domain and subdomains total more than 5 per 7 days, you'll hit a rate limit. So if you have main wphstest3.xyz and 4 subdomains off it, you would hit 5 certs per domain limit per 7 days.
  3. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    I've only run this once. This is my first time ever trying to use LetsEncrypt so it must be option #1?
    55,158
    12,249
    6:17 AM
    try verbose manual run with -v and see
    /root/.local/share/letsencrypt/bin/letsencrypt -c /etc/letsencrypt/webroot.ini --user-agent centminmod-centos7-webroot --webroot-path /home/nginx/domains/wphstest3.xyz/public -d wphstest3.xyz -d www.wphstest3.xyz certonly -v
    see what the output shows - post to gist or pastebin
  5. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    Same thing:
    Should I just try a new Domain with a different Registration email during menu Opt. 22?
  6. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    The whole thing:
    [root@vultr ~]# /root/.local/share/letsencrypt/bin/letsencrypt -c /etc/letsencrypt/webroot.ini --user-agent centminmod-centos7-webroot --webroot-path /home/nginx/domains/wphstest3.xyz/public -d wphstest3.xyz -d wphstest3.xyz certonly -v
    2015-12-07 03:32:27,693:INFO:letsencrypt.cli:Saving debug log to /var/log/letsencrypt/letsencrypt.log
    2015-12-07 03:32:27,716:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
    2015-12-07 03:32:28,102:INFO:letsencrypt.crypto_util:Generating key (2048 bits): /etc/letsencrypt/keys/0001_key-letsencrypt.pem
    2015-12-07 03:32:28,106:INFO:letsencrypt.crypto_util:Creating CSR: /etc/letsencrypt/csr/0001_csr-letsencrypt.pem
    2015-12-07 03:32:28,108:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
    2015-12-07 03:32:28,192:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
    2015-12-07 03:32:28,322:INFO:letsencrypt.auth_handler:Performing the following challenges:
    2015-12-07 03:32:28,322:INFO:letsencrypt.auth_handler:http-01 challenge for wphstest3.xyz
    2015-12-07 03:32:28,330:INFO:letsencrypt.auth_handler:Waiting for verification...
    2015-12-07 03:32:28,337:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
    2015-12-07 03:32:31,456:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
    2015-12-07 03:32:31,539:INFO:letsencrypt.reporter:Reporting to user: The following 'urn:acme:error:unauthorized' errors were reported by the server:
    Domains: wphstest3.xyz
    Error: The client lacks sufficient authorization
    2015-12-07 03:32:31,540:INFO:letsencrypt.auth_handler:Cleaning up challenges
    Failed authorization procedure. wphstest3.xyz (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://wphstest3.xyz/.well-known/acme-challenge/jzYdRsFj6wRXsUzrQ68uISRrv1HiBdEJyt9givOGBqc [108.61.119.113]: 403
    55,158
    12,249
    6:17 AM
    you can wipe the test nginx vhost using the generated output at bottom when you created a nginx vhost, you would of gotten some rm -rf lines which remove the nginx vhost etc so you can try same domain again
    also post the output for your /usr/local/nginx/conf/staticfiles.conf file which has the .well-know url support added which allows LE validations
    i.e.
        # prepare for letsencrypt
        # https://community.centminmod.com/posts/17774/
        location ~ ^/.well-known {
            location ~ ^/.well-known/acme-challenge/(.*) {
                    default_type text/plain;
                    charset off;
    55,158
    12,249
    6:17 AM
    also post your contents in CODE tags for your /usr/local/nginx/conf/conf.d/wphstest3.xyz.ssl.conf and /usr/local/nginx/conf/conf.d/wphstest3.xyz.conf vhost config files
  9. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    Do I create a Self Signed SSL?
    55,158
    12,249
    6:17 AM
    yes it's required before LE can work as self-signed ssl creates ssl nginx vhost structure and config first and LE utilises that and replaces self-signed ssl cert with LE SSL cert when successful. If LE validation fails, then self-signed ssl cert is left in place
  11. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    /usr/local/nginx/conf/staticfiles.conf had this at the top:
    # For SPDY SSL Setup
    # server {
    #   server_name wphstest3.xyz www.wphstest3.xyz;
    #    return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      ssl_dhparam /usr/local/nginx/conf/ssl/wphstest3.xyz/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/wphstest3.xyz/wphstest3.xyz.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/wphstest3.xyz/wphstest3.xyz.key;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM$
      # HTTP Public Key Pinning Header uncomment only one that applies include or exclude domains.
      # You'd want to include subdomains if you're using SSL wildcard certificates
      # include subdomain
      #add_header Public-Key-Pins 'pin-sha256="Xy8HBUE2Myob4Xs7CvS2/uwBGc1OE9PCM+1p1QxhidA="; pin-sha256="iVRmyhRfMry8GSSM8d+bGh8aIzAFbfe2RtesQ0gDS0c="; max-age=86400; includeSubDomains';
      # exclude subdomains
      #add_header Public-Key-Pins 'pin-sha256="Xy8HBUE2Myob4Xs7CvS2/uwBGc1OE9PCM+1p1QxhidA="; pin-sha256="iVRmyhRfMry8GSSM8d+bGh8aIzAFbfe2RtesQ0gDS0c="; max-age=86400';
      #spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/wphstest3.xyz/wphstest3.xyz-trusted.crt;
    #server {
    #            listen   80;
    #            server_name wphstest3.xyz;
    #            return 301 $scheme://www.wphstest3.xyz$request_uri;
      # ssi  on;
      access_log /home/nginx/domains/wphstest3.xyz/log/access.log combined buffer=256k$
      error_log /home/nginx/domains/wphstest3.xyz/log/error.log;
      root /home/nginx/domains/wphstest3.xyz/public;
      #location ~ (?:^|/)\. {
      # deny all;
    include /usr/local/nginx/conf/wpsupercache_wphstest3.xyz.conf;
    #include /usr/local/nginx/conf/rediscache_wphstest3.xyz.conf;
      #autoindex  on;
      try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $ur$
      # Wordpress Permalinks
      # Nginx level redis Wordpress
        #limit_conn xwpconlimit 30;
        auth_basic "Private";
  12. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    The second run had the same output:
    letsencrypt client is installed at:
    obtaining Letsencrypt SSL certificate via webroot authentication...
    /root/.local/share/letsencrypt/bin/letsencrypt -c /etc/letsencrypt/webroot.ini --usphstest3.xyz/public -d wphstest3.xyz -d www.wphstest3.xyz certonly
    Failed authorization procedure. wphstest3.xyz (http-01): urn:acme:error:unauthorizehttp://wphstest3.xyz/.well-known/acme-challenge/O-p-5iUF1Ww9Fu9uIQQ4THoHpu_Zy3lCia1ror:unauthorized :: The client lacks sufficient authorization :: Invalid response fqz1-BsW3WB1JcnmIicfiniEHK7c [IP]: 403
    IMPORTANT NOTES:
    - The following 'urn:acme:error:unauthorized' errors were reported by
       the server:
       Domains: wphstest3.xyz, www.wphstest3.xyz
    55,158
    12,249
    6:17 AM
    did you enable drop.conf include in your vhost as that's the only other place I know with dot prefix file and directory blocking which could interfere with .well-known uri access by LE servers for validation
  14. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    It's enabled in both ssl.conf and the non conf - should I comment them then re run:
    55,158
    12,249
    6:17 AM
    yeah try that although it worked for me with drop.conf enabled
    55,158
    12,249
    6:17 AM
    You can also check /home/nginx/domains/wphstest3.xyz/log/access.log to see 403 error details too
  17. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    Same thing - very strange
  18. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    I see this:
    55,158
    12,249
    6:17 AM
    oh you're using cloudflare intoDNS: wphstest3.xyz - check DNS server and mail server health ? won't work with cloudflare in front of server!
    i added a check for that in 123.09beta01le maybe you didn't get that update yet update letsencrypt integration add cloudflare check · centminmod/centminmod@8366122 · GitHub ?
    also cloudflare note at SSL - Letsencrypt Free SSL Public Beta December 3th 6PM GMT | Centmin Mod Community
  20. Matt Williams
    537
    104
    Virginia, USA
    4:17 PM
    latest
    I turned Cloudflare off " Clicked the cloud off" but forgot to turn it completely off and only use the DNS :rolleyes:
    I'll try again in 10-15 minutes
    I'm only using the DNS on Cloudflare. You can use the DNS only right?
