Letsencrypt Letsencrypt failed ssl renewal
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Jon Snow, Nov 12, 2017.
    11:15 PM
    I've installed it but I usually delete this directory "/root/centminlogs/" every after exiting SSH.
    I re run centmin to create it then all works now.
  2. rdan
    11:15 PM
    Although it was noted:
    But didn't work when I try:
    1:15 AM
    not recommended to delete as centmin.sh menu every option writes a log to that directory for debugging
    wrong order of commands
  4. Jon Snow
    Jon Snow Active Member
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    @eva2000
    One last problem I encountered. On only one of my servers, I'm running into an invalid cert error :
    ===Starting cron===
    Renew: 'domain.com'
    Skip invalid cert for: domain.com
    ===End cron===
    Using ./acmetool.sh reissue blah blah blah fails too and my site goes down until I re-upload the previous vhost file and restart nginx. wpsecure.conf isn't in the vhost and the site runs on the SSL certificate fine atm. I commented out drop.conf from the vhost + restarted nginx then ran the renew and it still didn't work.
    All of my other servers including fresh installs are fine. It's just this one server but it doesn't have anything different from the others so I'm not sure why it's happening to this specific one.
    It only has the ssl vhost config. Should I try making a non-ssl version?
    1:15 AM
    you should have a debug log for that run, post contents to pastebin.com or gist.github.com
    How was the initial letsencrypt ssl certificate obtained ? Which method ?
    • Was the domain nginx vhost alreadying created prior or new domain nginx vhost site setup for first time ?
    • Via centmin.sh menu option 2, 22, /usr/bin/nv ?
    • If you ran centmin.sh menu option 2 or 22, which letsencrypt option did you select from
      Setup full Nginx vhost + Wordpress + WP Plugins
      Enter vhost domain name you want to add (without www. prefix): acme3.domain1.com
      You have 4 options:
      1. issue staging test cert with HTTP + HTTPS
      2. issue staging test cert with HTTPS default
      Enter option number 1-4: 1
    • Via addons/acmetool.sh ? which specific command ? examples
      ./acmetool.sh issue acme.domain.com
      ./acmetool.sh issue acme.domain.com live
      ./acmetool.sh issue acme.domain.com d
      ./acmetool.sh issue acme.domain.com lived
    • What was order of steps you did ? Did you run centmin.sh menu option 2 first with letsencrypt ? Then did you run addons/acmetool.sh afterwards ?
    Troubleshooting
      ls -lahrt /root/centminlogs
      ACMEDEBUG='y'
    If acme.sh auto renewals didn't happen, check output for the following commands
    grep acme /var/log/cron* | sed -e "s|$(hostname -s)|host|g"
  6. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    After running the command? Because that was everything on the screen from the post above. Only when I use the reissue command, I think something gets logged.
    Do I need to enable acmetool.sh debug mode in persistent config file first?
    I think through :
    Then I moved the website files to the server.
    I'll post the outputs in a bit for the last three commands from your post.
    1:15 AM
    the live flag makes http + https site available versus ending flag lived which is for https default only site.
    not needed as by default now debug mode is set so just the log file contents
  8. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
  9. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    /var/log/cron:Dec 18 00:30:01 host CROND[24385]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron:Dec 19 00:30:01 host CROND[28562]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron:Dec 20 00:30:02 host CROND[15806]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron:Dec 21 00:30:01 host CROND[431]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron:Dec 22 00:30:02 host CROND[23266]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 21 00:30:02 host CROND[18002]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 22 00:30:01 host CROND[31934]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 23 00:30:01 host CROND[14427]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 24 00:30:01 host CROND[27637]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 25 00:30:02 host CROND[8257]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171126:Nov 26 00:30:02 host CROND[23439]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Nov 27 00:30:01 host CROND[4575]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Nov 28 00:30:01 host CROND[18426]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Nov 29 00:30:02 host CROND[32543]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Nov 30 00:30:01 host CROND[15234]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Dec  1 00:30:01 host CROND[30257]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Dec  2 00:30:02 host CROND[11891]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Dec  3 00:30:01 host CROND[26173]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171204:Dec  4 00:30:01 host CROND[9322]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec  5 00:30:01 host CROND[24488]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec  6 00:30:01 host CROND[6947]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec  7 00:30:02 host CROND[22592]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec  8 00:30:02 host CROND[5752]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec  9 00:30:02 host CROND[20525]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171210:Dec 10 00:30:01 host CROND[2795]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 11 00:30:02 host CROND[18102]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 12 00:30:01 host CROND[336]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 13 00:30:01 host CROND[16127]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 14 00:30:02 host CROND[31684]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 15 00:30:01 host CROND[14633]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 16 00:30:01 host CROND[29005]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    /var/log/cron-20171217:Dec 17 00:30:01 host CROND[10991]: (root) CMD ("/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null)
    The site works fine, but just can't renew the SSL certificate because it gives an invalid error.
    1:15 AM
    so the command below is empty with no listed ssl certs ?
    that would suggest somehow you lost the acme.sh config files for your domain's ssl certs that cronjob reads for auto renewals. They should have files at /root/.acme.sh/yourdomain.com/
    i.e. for my mysqlmymon.com site the vhost web root path and auto renewal method is listed in /root/.acme.sh/mysqlmymon.com/mysqlmymon.com.conf config file
    ls -lah /root/.acme.sh/mysqlmymon.com/
    total 40K
    drwxr-xr-x 2 root root 4.0K Feb 11  2017 .
    drwx------ 6 root root 4.0K Feb 11  2017 ..
    -rw-r--r-- 1 root root 1.7K Nov 13 00:00 ca.cer
    -rw-r--r-- 1 root root 3.4K Nov 13 00:00 fullchain.cer
    -rw-r--r-- 1 root root 1.8K Nov 13 00:00 mysqlmymon.com.cer
    -rw-r--r-- 1 root root  955 Nov 13 00:00 mysqlmymon.com.conf
    -rw-r--r-- 1 root root  980 Nov 13 00:00 mysqlmymon.com.csr
    -rw-r--r-- 1 root root  213 Nov 13 00:00 mysqlmymon.com.csr.conf
    -rw-r--r-- 1 root root 1.7K Sep  2  2016 mysqlmymon.com.key
    -rw-r--r-- 1 root root  212 Nov 22  2016 mysqlmymon.com.ssl.conf
    what's contents of your /root/.acme.sh/mysqlmymon.com/yourdomain.com.conf
  11. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Le_Keylength='2048'
    Le_Domain='domain.com'
    Le_Alt='www.domain.com'
    Le_Webroot='/home/nginx/domains/domain.com/public'
    Le_PreHook=''
    Le_PostHook=''
    Le_RenewHook=''
    Le_API='https://acme-v01.api.letsencrypt.org/directory'
    The contents of /root/.acme.sh/domain.com/ :
    ls -lah /root/.acme.sh/domain.com/
    total 24K
    drwxr-xr-x 2 root root 4.0K Nov 13 01:58 .
    drwx------ 6 root root 4.0K Dec 21 03:05 ..
    -rw-r--r-- 1 root root  237 Dec 21 03:05 domain.com.conf
    -rw-r--r-- 1 root root  985 Dec 21 03:05 domain.com.csr
    -rw-r--r-- 1 root root  215 Dec 21 03:05 domain.com.csr.conf
    -rw-r--r-- 1 root root 1.7K Dec 21 03:05 domain.com.key
    1:15 AM
    you seem to be missing alot of entries in /root/.acme.sh/mysqlmymon.com/yourdomain.com.conf ?
    what's output for
    "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" --debug
  13. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    [Sat Dec 23 03:25:46 UTC 2017] Lets find script dir.
    [Sat Dec 23 03:25:46 UTC 2017] _SCRIPT_='/root/.acme.sh/acme.sh'
    [Sat Dec 23 03:25:46 UTC 2017] _script='/root/.acme.sh/acme.sh'
    [Sat Dec 23 03:25:46 UTC 2017] _script_home='/root/.acme.sh'
    [Sat Dec 23 03:25:46 UTC 2017] Using config home:/root/.acme.sh
    https://github.com/Neilpang/acme.sh
    v2.7.6
    [Sat Dec 23 03:25:46 UTC 2017] ===Starting cron===
    [Sat Dec 23 03:25:46 UTC 2017] _stopRenewOnError
    [Sat Dec 23 03:25:46 UTC 2017] di='/root/.acme.sh/domain.com/'
    [Sat Dec 23 03:25:46 UTC 2017] d='domain.com'
    [Sat Dec 23 03:25:46 UTC 2017] DOMAIN_PATH='/root/.acme.sh/domain.com'
    [Sat Dec 23 03:25:46 UTC 2017] Renew: 'domain.com'
    [Sat Dec 23 03:25:46 UTC 2017] Skip invalid cert for: domain.com
    [Sat Dec 23 03:25:46 UTC 2017] Return code: 0
    [Sat Dec 23 03:25:46 UTC 2017] ===End cron===
    1:15 AM
  15. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Didn't work, unfortunately :( Same invalid cert error with no log file.
    Using this gets a log file though :
    cd /usr/local/src/centminmod/addons
    ./acmetool.sh reissue domain.com lived
    acmetool.sh is in beta testing phase
    please read & provide bug reports &
    feedback for this tool via the forums
    https://centminmod.com/acmetool
    continue [y/n] ? y
    updating acme.sh client...
    It is recommended to install socat first.
    We use socat for standalone server if you use standalone mode.
    If you don't use standalone mode, just ignore this warning.
    Installing to /root/.acme.sh
    Installed to /root/.acme.sh/acme.sh
    Installing alias to '/root/.bashrc'
    OK, Close and reopen your terminal to start using acme.sh
    Installing alias to '/root/.cshrc'
    Installing alias to '/root/.tcshrc'
    Installing cron job
    30 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
    Good, bash is found, so change the shebang to use bash as preferred.
    OK
    v2.7.6
    acme.sh updated
    backup & remove /usr/local/nginx/conf/conf.d/domain.com.conf
    [self-signed ssl cert check] required by acmetool.sh
    [self-signed ssl] /usr/local/nginx/conf/ssl/domain.com/dhparam.pem exists
    [self-signed ssl] /usr/local/nginx/conf/ssl/domain.com/domain.com.crt exists
    [self-signed ssl] /usr/local/nginx/conf/ssl/domain.com/domain.com.key exists
    [sslvhostsetup] create /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
    [non-wp] backup & remove /usr/local/nginx/conf/conf.d/domain.com.conf
    cat /usr/local/nginx/conf/ssl/domain.com/domain.com.crt.key.conf
    ssl_dhparam /usr/local/nginx/conf/ssl/domain.com/dhparam.pem;
    ssl_certificate      /usr/local/nginx/conf/ssl/domain.com/domain_com.crt;
    ssl_certificate_key  /usr/local/nginx/conf/ssl/domain.com/domain_com.key;
    ssl_trusted_certificate /usr/local/nginx/conf/ssl/domain.com/domain.com-trusted.crt;
    cp -a /usr/local/nginx/conf/conf.d/domain.com.ssl.conf /usr/local/nginx/conf/conf.d/domain.com.ssl.conf-nonwp2
    cat /usr/local/nginx/conf/conf.d/domain.com.ssl.conf-nonwp1 /usr/local/nginx/conf/conf.d/domain.com.ssl.conf-nonwp2 > /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
    Reloading nginx configuration (via systemctl):  [  OK  ]
    setting HTTPS default in /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
    sed -i 's|^##x# HTTPS-DEFAULT|#x# HTTPS-DEFAULT|g' /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
    grep 'root' /usr/local/nginx/conf/conf.d/domain.com.ssl.conf
            fastcgi_param   SCRIPT_FILENAME $document_root$fastcgi_script_name;
    reissue & install letsencrypt ssl certificate for domain.com
    /root/.acme.sh/acme.sh --force --createDomainKey -d domain.com -d www.domain.com -k 2048 --useragent centminmod-centos7-acmesh-webroot
    Creating domain key
    [Sat Dec 23 04:04:14 UTC 2017] The domain key is here: /root/.acme.sh/domain.com/domain.com.key
    testcert value = lived
    /root/.acme.sh/acme.sh --force --issue -d domain.com -d www.domain.com --days 60 -w /home/nginx/domains/domain.com/public -k 2048 --useragent centminmod-centos7-acmesh-webroot --log /root/centminlogs/acmetool.sh-debug-log-231217-040403.log --log-level 2
    Multi domain='DNS:www.domain.com'
    Getting domain auth token for each domain
    Getting webroot for domain='domain.com'
    Getting new-authz for domain='domain.com'
    The new-authz request is ok.
    Getting webroot for domain='www.domain.com'
    Getting new-authz for domain='www.domain.com'
    Verifying:domain.com
    domain.com:Verify error:Fetching https://domain.com/.well-known/acme-challenge/utHeY9zmAsh_LvptTgU0tGFMHT7SEKSn_TYipjJ8ORs: Connection reset by peer
    Please check log file for more details: /root/centminlogs/acmetool.sh-debug-log-231217-040403.log
    LECHECK = 1
    log files saved at /root/centminlogs
    -rw-r--r-- 1 root root  37K Dec 23 04:04 acmetool.sh-debug-log-231217-040403.log
    -rw-r--r-- 1 root root 4.8K Dec 23 04:04 acmesh-reissue_231217-040403.log
    What's different about this error is that it says "Connection reset by peer".
    1:15 AM
    post contents of /root/centminlogs/acmetool.sh-debug-log-231217-040403.log to pastebin.com or gist.github.com
  17. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    1:15 AM
    when you setup temp non-https nginx vhost, did you replicate nginx rules from your https based nginx vhost ?
    Please post the contents of /usr/local/nginx/conf/conf.d/newdomain.com.conf and /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf wrapped in CODE tags (outlined at How to use forum BBCODE code tags)
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  19. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Results :
    HTTP/1.1 200 OK
    Connection: keep-alive
    Vary: Accept-Encoding
    Set-Cookie: xf_session=59f3366ff35d8871e4a5025fb2d28a0c; path=/; secure; httponly
    X-Frame-Options: SAMEORIGIN
    X-Xss-Protection: 1
    Server: Nginx
    X-Powered-By: Nginx
    Date: Sat, 23 Dec 2017 05:44:18 GMT
    X-Page-Speed: 1.13.35.1-0
    Cache-Control: max-age=0, no-cache
    HTTP/1.1 200 OK
    Set-Cookie: xf_session=6aa562904a5417ebaaf533f1200a2df1; path=/; secure; httponly
    X-Xss-Protection: 1
    Server: Nginx
    X-Powered-By: Nginx
    Date: Sat, 23 Dec 2017 05:44:46 GMT
    HTTP/1.1 200 OK
    Set-Cookie: xf_session=4b3b30ef4ef2ab002fba37139bff13b0; path=/; secure; httponly
    X-Xss-Protection: 1
    Server: Nginx
    X-Powered-By: Nginx
    Date: Sat, 23 Dec 2017 05:45:11 GMT
    HTTP/1.1 200 OK
    Set-Cookie: xf_session=23aee0ed038607aa2cb76266ac293abe; path=/; secure; httponly
    X-Xss-Protection: 1
    Server: Nginx
    X-Powered-By: Nginx
    Date: Sat, 23 Dec 2017 05:45:27 GMT
    Posting the vhost contents in the following post.
  20. Jon Snow
    933
    192
    12:15 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Non-SSL :
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=5m;
    location /install/ {
        auth_basic "Private";
        allow 127.0.0.1;
        deny all;
    location /install/data/ {
        internal;
        allow 127.0.0.1;
        deny all;
    location /install/templates/ {
        internal;
        allow 127.0.0.1;
        deny all;
    location /internal_data/ {
        internal;
        allow 127.0.0.1;
        deny all;
    location /library/ {
        internal;
        allow 127.0.0.1;
        deny all;
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_pass    127.0.0.1:9000;
        include         fastcgi_params;
      #include /usr/local/nginx/conf/drop.conf;
    SSL :
      listen 443 ssl http2;
      # ssl_dhparam /usr/local/nginx/conf/ssl/domain.com/dhparam.pem;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # mozilla recommended
      ssl_ciphers EECDH+CHACHA20:EECDH+CHACHA20-draft:EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA256:EECDH+ECDSA+SHA384:EECDH+aRSA+SHA256:EECDH+aRSA+SHA384:EECDH+AES128:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!RC4:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/domain.com/domain.com-trusted.crt;
      # ssi  on;
      include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
      index index.php index.html;
      #autoindex  on;
      #autoindex_localtime on;
        allow 127.0.0.1;
        deny all;
        internal;
        allow 127.0.0.1;
        deny all;
        internal;
        allow 127.0.0.1;
        deny all;
        internal;
        allow 127.0.0.1;
        deny all;
        internal;
        allow 127.0.0.1;
        deny all;
    location ~ \.php$ {
      include /usr/local/nginx/conf/pre-staticfiles-local-domain.com.conf;
