Letsencrypt Let's encrypt will work on subdomain using a Cname record?
Discussion in 'Domains, DNS, Email & SSL Certificates' started by pamamolf, Jul 3, 2019.
    4,130
    12:57 AM
    16:  include /usr/local/nginx/conf/ssl_include.conf;
    19:  #ssl_client_certificate /usr/local/nginx/conf/ssl/cloudflare/cdn.mydomain.com/origin.crt;
    20:  #ssl_verify_client on;
    24:  ssl_ciphers TLS13-AES-128-GCM-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-CCM-8-SHA256:TLS13-AES-128-CCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
    25:  ssl_prefer_server_ciphers   on;
    35:  ssl_buffer_size 1369;
    36:  ssl_session_tickets on;
    41:  #ssl_stapling on;
    42:  #ssl_stapling_verify on;
    and:
    -rw-r--r-- 1 root root  424 Dec 25  2018 dhparam.pem
    -rw-r--r-- 1 root root 1.7K Jul  2 23:24 cdn.mydomain.com.key
    -rw-r--r-- 1 root root 1.1K Jul  2 23:24 cdn.mydomain.com.csr
    -rw-r--r-- 1 root root 1.4K Jul  2 23:24 cdn.mydomain.com.crt
    drwxr-xr-x 7 root root 4.0K Jul  4 20:32 ..
    -rw-r--r-- 1 root root 1.7K Jul  4 22:09 cdn.mydomain.com-acme.cer
    -rw------- 1 root root 1.7K Jul  4 22:09 cdn.mydomain.com-acme.key
    drwxr-xr-x 2 root root 4.0K Jul  4 22:09 .
    -rw-r--r-- 1 root root 3.6K Jul  4 22:09 cdn.mydomain.com-fullchain-acme.key
    -rw-r--r-- 1 root root  749 Jul  4 22:24 cdn.mydomain.com.crt.key.conf
    60,475
    12,620
    8:57 AM
    besides uncommenting these 2 for OCSP stapling
    #ssl_stapling on;
    everything looks in order for it to work
  3. pamamolf
    4,130
    12:57 AM
    I uncomment the two values and try to restart Nginx but i got the same error :(
    Starting nginx: nginx: [emerg] SSL_CTX_use_PrivateKey("/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key") failed (SSL: err...alues mismatch)
    There is a missmatch with a private key and something related to:
    Don't know why and what i can try :(
    60,475
    12,620
    8:57 AM
    output for command
    ls -lahrt /root/.acme.sh/cdn.mydomain.com/
    have you previously used acmetool.sh, centmin.sh menu option 2, 22 or nv commands to create cdn.mydomain.com so that previous letsencrypt ssl certificate has been issue ?
    check acme.sh's version of the private key /root/.acme.sh/cdn.mydomain.com/cdn.mydomain.com.key is same as acme.sh installed one at /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key
    output for command
    diff -q /root/.acme.sh/cdn.mydomain.com/cdn.mydomain.com.key /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key
    if returns to prompt with no message = same
    otherwise diff will report the 2 files differ
  5. pamamolf
    4,130
    12:57 AM
    -rw-r--r--  1 root root 1.7K Jul  2 23:33 cdn.mydomain.com.key
    drwx------ 10 root root 4.0K Jul  4 21:27 ..
    -rw-r--r--  1 root root  220 Jul  4 21:27 cdn.mydomain.com.csr.conf
    -rw-r--r--  1 root root 1005 Jul  4 21:27 cdn.mydomain.com.csr
    -rw-r--r--  1 root root 3.6K Jul  4 21:28 fullchain.cer
    -rw-r--r--  1 root root 1.7K Jul  4 21:28 ca.cer
    drwxr-xr-x  3 root root 4.0K Jul  4 21:36 .
    -rw-r--r--  1 root root    0 Jul  4 21:36 cdn.mydomain.com.cer
    drwxr-xr-x  2 root root 4.0K Jul  4 21:36 backup
    -rw-r--r--  1 root root 1.1K Jul  4 22:09 cdn.mydomain.com.conf
    Yes i create using menu 2 the subdomain first with self signed certificate and then i try to use Let's encrypt as usual (only HTTPS live) but as i didn't had the A record it was failed. Probably fall back to self signed again as Nginx was working after that....
    output nothing so the same...
    Then i did all the above following your instructions.
    Thank you
    60,475
    12,620
    8:57 AM
    strange from ls output key is 2 days older than rest of letsencrypt issued/installed files via acme.sh
    try renaming /usr/local/nginx/conf/ssl/cdn.mydomain.com/ directory and emptying it out and doing acme.sh install command again
    4 cmds to run
    cd /usr/local/nginx/conf/ssl/
    cp -a /usr/local/nginx/conf/ssl/cdn.mydomain.com/ /usr/local/nginx/conf/ssl/cdn.mydomain.com.old/
    rm -rf /usr/local/nginx/conf/ssl/cdn.mydomain.com/*
    /root/.acme.sh/acme.sh --installcert -d cdn.mydomain.com --certpath /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer --keypath /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key --capath /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer --reloadCmd /usr/bin/ngxreload --fullchainpath /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-fullchain-acme.key
    ngxrestart
  7. pamamolf
    4,130
    12:57 AM
    Ok i did it and i got this:
    [Fri Jul  5 21:50:33 UTC 2019] Installing cert to:/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer
    [Fri Jul  5 21:50:33 UTC 2019] Installing CA to:/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer
    [Fri Jul  5 21:50:33 UTC 2019] Installing key to:/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key
    [Fri Jul  5 21:50:33 UTC 2019] Installing full chain to:/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-fullchain-acme.key
    [Fri Jul  5 21:50:33 UTC 2019] Run reload cmd: /usr/bin/ngxreload
    Reloading nginx configuration (via systemctl):  Job for nginx.service invalid.
                                                               [FAILED]
    [Fri Jul  5 21:50:33 UTC 2019] Reload error for :
    systemctl status nginx.service
    Starting nginx: nginx: [emerg] open() "/usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com.crt.key.conf" failed (2: No such file or di...nfo.ssl.conf:15
    Line 15:
      include /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com.crt.key.conf;
    So i copy it from:
    /usr/local/nginx/conf/ssl/cdn.mydomain.com.old/cdn.mydomain.com.crt.key.conf
    and i add it to:
    Content of the folder:
    -rw-r--r--  1 root root 1.1K Jul  5 21:50 cdn.mydomain.com.conf
    Content of the file:
      ssl_dhparam /usr/local/nginx/conf/ssl/cdn.mydomain.com/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/cdn.supereventforall.info/cdn.mydomain.com-acme.key;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/cdn.supereventforall.info/cdn.mydomain.com-acme.cer;
    ngxrestart output again issue with the Private key mismatch:
    It is a test server and i can provide you login info if you want to check it....
    60,475
    12,620
    8:57 AM
    try emptying out acme.sh directory /root/.acme.sh/cdn.mydomain.com and re-run acmetool.sh cert only mode + renaming /usr/local/nginx/conf/ssl/cdn.mydomain.com/ directory and emptying it out and doing acme.sh install command again
    8 cmds to run
    cd /root/.acme.sh/
    rm -rf /root/.acme.sh/cdn.mydomain.com
    ./acmetool.sh certonly-issue cdn.mydomain.com live
    cp -a /usr/local/nginx/conf/ssl/cdn.mydomain.com/ /usr/local/nginx/conf/ssl/cdn.mydomain.com.old2/
    ngxrestart
  9. pamamolf
    4,130
    12:57 AM
    I did exactly all the above except running the acmetool.sh from /root/.acme.sh/ as i didn't have that tool there and i run it from cd /usr/local/src/centminmod/addons/
    All seems to be ok and i got this info:
    cdn.mydomain.com is already verified, skip dns-01.
    Cert success
    But at the end Nginx reload didn't work again :(
    Then i try to restart it manually using: ngxrestart and i got FAILED
    Output:
    so i create the file:
    and i add inside:
      ssl_certificate_key  /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.key;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/cdn.mydomain.com/cdn.mydomain.com-acme.cer;
    and then restart Nginx again and got FAILED but with another error this time.
    Output:
    Starting nginx: nginx: [emerg] BIO_new_file("/usr/local/nginx/conf/ssl/cdn.mydomain.com/dhparam.pem") failed (SSL: error:02001002:system library:fopen:No such file or...
    So i copy from the .old folder the dhparam.pem and place it at the correct folder.
    ls -lahrt ls -lahrt /usr/local/nginx/conf/ssl/cdn.mydomain.com/
    drwxr-xr-x 9 root root 4.0K Jul  6 13:20 ..
    -rw-r--r-- 1 root root 3.6K Jul  6 13:21 cdn.mydomain.com-acme.cer
    -rw------- 1 root root 1.7K Jul  6 13:21 cdn.mydomain.com-acme.key
    -rw-r--r-- 1 root root 3.6K Jul  6 13:21 cdn.mydomain.com-fullchain-acme.key
    -rw-r--r-- 1 root root  415 Jul  6 13:29 cdn.mydomain.com.crt.key.conf
    drwxr-xr-x 2 root root 4.0K Jul  6 13:38 .
    Then i restart Nginx and now it works !!!!!!
    WOW SUPER !!!!
    But on the site when i disable Cloudflare Ii can see the green lock and let's encrypt info there with no warnings or any problems but when i try to open homepage my images are not loading and from the inspect from Chrome i can see this error:
    Failed to load resource: net::ERR_CERT_COMMON_NAME_INVALID
    Checking on the net i found this:
    If you happened to have a self-signed certificate that was created before the change linked below the newer browsers definitely didn't like it because they now require the FQDN of the system in the SubjectAltName field of the certificate.
    Solution something like this?
    Chrome Deprecates Subject CN Matching
    Apparently the solution is to instruct openssl to generate a V3 compatible subjectAltName...
    Thank you
    60,475
    12,620
    8:57 AM
    Interesting will need to read up on this
    where are images being loaded from cdn.mydomain.com without cloudflare ? they should be served via letsencrypt ssl issued ssl cert
    60,475
    12,620
    8:57 AM
    updated 123.09beta01's self-signed ssl certificate generation routines now so future generated self-signed ssl certificates include the v3 subjectAltName fields :)
  12. pamamolf
    4,130
    12:57 AM
    Should i re do the:
    cd /root/.acme.sh/
    ngxrestart
    to test it?
    As that change is related to the previous self signed certificates ?
  13. pamamolf
    4,130
    12:57 AM
    When Cloudflare is disabled the images are coming from Wasabi Cloud....
    60,475
    12,620
    8:57 AM
    it wouldn't change it if wasabi is one serving the images though but you can try
    then that problem would be wasabi ssl certificate configuration
  15. pamamolf
    4,130
    12:57 AM
    Does that help?
    60,475
    12,620
    8:57 AM
    Wasabi needs to provide the SSL cert for your cdn.mydomain.com just like Amazon AWS Cloudfront, Sucuri Cloudproxy and Cloudflare would do for CDN accelerated files.
  17. pamamolf
    4,130
    12:57 AM
    60,475
    12,620
    8:57 AM
  19. pamamolf
    4,130
    12:57 AM
    Don't know :(
    This is what i got as a reply:
