Journalctl logs rotation or clean up
Discussion in 'System Administration' started by pamamolf, Feb 7, 2020.
    3,807
    369
    9:04 AM
    Nginx-1.17.x
    Hello :)
    Does Centminmod has any mechanism to clear the Journalctl logs?
    As i can see at:
    /etc/systemd/journald.conf
    value:
    SystemMaxUse=
    is disabled....
    Isn't better to have there a limit to clear or rotate or both ?
    44,426
    10,144
    4:04 PM
    Centmin Mod currently doesn't do any changes to the default for systemd for CentOS 7 journald.conf and Linux Logging with Systemd - The Ultimate Guide To Logging
    you can check size
    du -sh /run/log/journal/
    50M     /run/log/journal/
    and
    journalctl --disk-usage
    Archived and active journals take up 48.3M on disk.
