PHP-FPM Issues with installing php/updating and mcrypt.h not found.
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by derpyhooves, Oct 25, 2014.
  1. derpyhooves
    derpyhooves New Member
    22
    2:34 AM
    55,400
    12,255
    2:34 AM
    problem is libmcrypt YUM package failed to install due to EPEL YUM repo failure to install or download issue
    [1;32;40m* CentOS 6.x detected installing EPEL Repo
    (B[m*************************************************
    Error: epel-release-6-8.noarch.rpm not found !!! Download now......
    2014-10-25 09:30:52 URL:http://epel.mirror.constant.com/6/x86_64/epel-release-6-8.noarch.rpm [14540/14540] -> "epel-release-6-8.noarch.rpm" [1]
    [1;33;40mDownload done.
    (B[mError: Cannot retrieve metalink for repository: epel. Please verify its path and try again
    [1;32;40mError: problem with epel-release-6-8.noarch.rpm install.
    Processing package: libmcrypt
    Error: No matching Packages to list
    [1;33;40mInstalling libmcrypt
    (B[m----------------------------------------------------------------------------------
    could be temporarily EPEL mirror download issue which cascaded to prevent EPEL YUM repo install, thus preventing libmcrypt and thus PHP compile/install failed.
    what happens when you manually try to download via wget on your server the EPEL RPM file http://epel.mirror.constant.com/6/x86_64/epel-release-6-8.noarch.rpm ? I confirmed I can download from that url
    I'd do a fresh CentOS 6.5 64bit OS reload and try again initial install
  3. derpyhooves
    22
    2:34 AM
    So a fresh 6.5 install, then wget the epel rpm file and then re-do the centminmod install?
    55,400
    12,255
    2:34 AM
    fresh install and redo install - no need to wget get as EPEL failed download might have been a one off thing
  5. derpyhooves
    22
    2:34 AM
    Managed to get it to work, had to wget as well cause I tried several times and the EPEL failed download always showed up. Now everything seems to be working fine. I enabled all the caching options and such on my xenforo install as well as did the SEO friendly url thing, is there anything else I need to configure? Such as the caches themselves or would how it is right now be enough?
    RLPV Test forum
    55,400
    12,255
    2:34 AM
    55,400
    12,255
    2:34 AM
    hmm i am not finding constant.com mirror in EPEL's active mirror listing anymore so might need to change the url
    edit: updated both .07 stable and .08 beta builds with updated EPEL download urls. Centmin Mod .08 beta updated the EPEL dynamic mirror check feature extending it to CentOS 5 and 6 as well as CentOS 7.
    .07 stable commit update inc/downloadlinks.inc EPEL 5 & 6 mirror download changes for .07 ... · ba7178b · centminmod/centminmod · GitHub
    .08 beta commit update inc/downloadlinks.inc EPEL 5, 6, 7 dynamic mirror override · 72abd95 · centminmod/centminmod · GitHub
  8. derpyhooves
    22
    2:34 AM
    Excuse my stupidity, but how would I visit those links from my webbrowser exactly?
    55,400
    12,255
    2:34 AM
    as outlined at PHP Opcode and Memcached statistics pages | Centmin Mod Community
  10. derpyhooves
    22
    2:34 AM
    55,400
    12,255
    2:34 AM
  12. derpyhooves
    22
    2:34 AM
    55,400
    12,255
    2:34 AM
    looks good to me :)
  14. derpyhooves
    22
    2:34 AM
    Alright, waiting for the dns to update then. I'm asking cause I have another main forum that's running on centminmod but it wasn't set up by me, when I try to check the cache stats there using my server name followed by the domain name etc it's not showing up either, not sure if he actually configured that record. But yeah, thank you so much for all your help, i'm sorry for being such a bother!
    55,400
    12,255
    2:34 AM
    you're welcome.. everyone learns by asking :)
    Just pay it forward with assistance and help to other new Centmin Mod users on the forums once you're more familiar with Centmin Mod :D ;)
  16. derpyhooves
    22
    2:34 AM
    I will surely do that! i'm glad that I was able to help somewhat with the whole epel issue that's going on, sounds like I wasn't the only one.
  17. derpyhooves
    22
    2:34 AM
    Alright one more issue, not all caches show up (as in, the files are not in the ftp.)
    memcache works.
    xcache works.
    Apc gives me this issue: No cache info available. APC does not appear to be running.
    Zend OPcache is not there.
    Does this mean that APC and zend Opcache are currently not being used by my xenforo?
    This is my xenforo config:
    $config['superAdmins'] = '1'; #$config['cache']['enabled'] = true; #$config[ - Pastebin.com
    I'm also unsure of what I need to look at on those cache pages to see what needs tweaking.
    55,400
    12,255
    2:34 AM
    what does output of SSH command output below ?
    php --ri apc
    if APC Cache is installed should output
     php --ri apc
    apc
    APC Support => enabled
    Version => 3.1.13
    APC Debugging => Disabled
    MMAP Support => Enabled
    MMAP File Mask =>
    Locking type => pthread mutex Locks
    Serialization Support => php, igbinary
    Revision => $Revision: 327136 $
    Build Date => Oct 26 2014 02:08:08
    apc.enabled => On => On
    apc.shm_segments => 1 => 1
    apc.shm_size => 32M => 32M
    apc.shm_strings_buffer => 4M => 4M
    apc.include_once_override => Off => Off
    apc.num_files_hint => 4096 => 4096
    apc.user_entries_hint => 4096 => 4096
    apc.gc_ttl => 3600 => 3600
    apc.ttl => 7200 => 7200
    apc.user_ttl => 7200 => 7200
    apc.mmap_file_mask => no value => no value
    apc.filters => no value => no value
    apc.cache_by_default => On => On
    apc.file_update_protection => 2 => 2
    apc.enable_cli => On => On
    apc.max_file_size => 1M => 1M
    apc.stat => On => On
    apc.canonicalize => On => On
    apc.stat_ctime => Off => Off
    apc.write_lock => On => On
    apc.slam_defense => Off => Off
    apc.report_autofilter => Off => Off
    apc.rfc1867 => Off => Off
    apc.rfc1867_prefix => upload_ => upload_
    apc.rfc1867_name => APC_UPLOAD_PROGRESS => APC_UPLOAD_PROGRESS
    apc.rfc1867_freq => 0 => 0
    apc.rfc1867_ttl => 3600 => 3600
    apc.coredump_unmap => Off => Off
    apc.preload_path => no value => no value
    apc.file_md5 => Off => Off
    apc.use_request_time => On => On
    apc.lazy_functions => Off => Off
    apc.lazy_classes => Off => Off
    apc.serializer => igbinary => igbinary
    if not, then APC Cache failed to install, so run centmin.sh and select menu option 7 to reinstall APC Cache and check again to see if APC Cache is installed
    As to knowing what to look for and optimisation and tuning of caches, you're on your own there as Centmin Mod is provided as is. So google-fu for tuning tips ;) However, other members are free to offer suggestions and tips if they want
  19. derpyhooves
    22
    2:34 AM
    Wasn't installed, now it is. Though the file still isn't showing on the ftp, do I need to restart something?
    It's also showing this error:
    PHP Warning: Cannot load module 'XCache' because conflicting module 'apc' is already loaded in U nknown on line 0
    55,400
    12,255
    2:34 AM
    where you looking in ftp ? the file is usually at /usr/local/nginx/html
    if it didn't show up, try centmin.sh menu option 9 to install APC Cache it should populate the missing apc.php file
    menu option 9 in centmin.sh should take care of both errors
