Xenforo Issue with Xenforo and ImageMagick avatar uploads
Discussion in 'Forum software usage' started by brainlet2000, May 8, 2020.
  1. brainlet2000
    brainlet2000 Member
    42
    8:35 PM
    1.17.7
    10.3.21
    I've had Imagemagick PECL extension enabled in the Xenforo attachment settings for months.
    Now suddenly out of nowhere avatars can no longer be uploaded with ImageMagick with the following error:
         RuntimeException: Failed to save image to temporary file; image may be corrupt or check internal_data/data permissions src/XF/Service/User/Avatar.php:263
    When I use PHP built-in GD image library as the default image processor instead it works fine, but GIFs can't be uploaded for avatars.
    I already chmoded 777 internal data and data folders(as root). Any idea what is wrong here?
    55,458
    12,257
    4:35 AM
    Try running cmupdate command and then run centmin.sh menu option 15 to update imagick PHP extension + yum packages due to Remi ImageMagick yum changes Beta Branch - Update REMI YUM ImageMagick6 package name obsoleting in 123.09beta01
    But the error does look like internal_data/data permissions related - ensure directory and files are owned by nginx user/group.
    When you log in via pure-ftpd virtual ftp user, files uploaded are already nginx user/group permission based. But if you upload files via root user via SFTP, they're root user owned. Getting Started Guide step 2 outlines vhost setup and file permissions which are nginx/nginx user and group and how to set them if you uploaded via root SFTP.
    chown -R nginx:nginx /home/nginx/domains/newdomain.com/public
  3. brainlet2000
    brainlet2000 Member
    42
    8:35 PM
    1.17.7
    10.3.21
    Yep, these steps solved it. You're a god damn genius like always. I think it was just ImageMagick glitching out somehow, not sure. Maybe because I updated centminmod and nginx. No idea.
    Thank you, @eva2000.
