AlmaLinux Messed up my YUM settings or database
Discussion in 'System Administration' started by ElChorizo, Sep 27, 2025.
  1. ElChorizo
    ElChorizo Member
    79
    12:40 PM
    1.19.10
    10.3.28
    I installed an app on one of our CentminMod Alma 9.5 servers. Now, anytime I run centmin.sh and exit, there are never any yum updates available. I can't remember what app I installed but it changed some Yum settings... I know there are updates available because I've updated other servers with AlmaLinux 9.5 and they've had multiple updates and this one hasn't. The centmin code base will update just fine...
    What settings should I check or copy from my other working servers to fix this?
    3:40 AM
    First steps would be share what app you I installed, the steps and commands and link to apps documentation
    For clues type in SSH session
    history
    Should give you a date timestamped log of all commands you ran
    Also run
    yum history list
    You don't want to share your history fully on public forums though, just gives you an idea of what you ran and can share sanitised excerpts
  3. ElChorizo
    ElChorizo Member
    79
    12:40 PM
    1.19.10
    10.3.28
    It was this app: exosphere - A CLI / TUI for aggregated patch reporting & system status monitoring via SSH. - Terminal Trove
    It is a TUI to manage multiple servers and yum packages on those servers. There was a refresh yum database and once I ran that it started doing some updates and it's never worked after that. I have no idea what it could have done.
    I installed it on my workstation but added the server to the config, so it doesn't actually install anything on the server, but it did change the config somewhow or broke something in the centmin/yum config.
  4. ElChorizo
    ElChorizo Member
    79
    12:40 PM
    1.19.10
    10.3.28
    Update. Looks like I found it. It was a broken repo from trying to play with OpenSearch --- I removed the broken repo and it seems good now.
    3:40 AM
    Interesting app - seems would be useful along the lines of using Ansible
    Ah glad you found the issue. In future you probably could of found this issue running
    yum clean all
    yum repolist all
    that would force to sync and check all repos again where problematic ones would probably chuck an error
