Nginx Issue with NGINX
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Chris, Sep 1, 2015.
  1. Chris
    Chris Member
    51
    3:42 PM
    1.7
    [root@li108-164 centminmod]# ngxrestart
    Restarting nginx (via systemctl):  Job for nginx.service failed. See 'systemctl status nginx.service' and 'journalctl -xn' for details.
                                                               [FAILED]
    [root@li108-164 centminmod]# systemctl status nginx.service -l
    nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
       Loaded: loaded (/etc/rc.d/init.d/nginx)
       Active: failed (Result: exit-code) since Mon 2015-08-31 23:02:44 UTC; 2s ago
      Process: 3878 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=1/FAILURE)
    Aug 31 23:02:44 li108-164.members.linode.com systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Aug 31 23:02:44 li108-164.members.linode.com nginx[3878]: Starting nginx: nginx: [emerg] unknown directive "vhost_traffic_status_zone" in /usr/local/nginx/conf/vts_http.conf:1
    Aug 31 23:02:44 li108-164.members.linode.com nginx[3878]: [FAILED]
    Aug 31 23:02:44 li108-164.members.linode.com systemd[1]: nginx.service: control process exited, code=exited status=1
    Aug 31 23:02:44 li108-164.members.linode.com systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
    Aug 31 23:02:44 li108-164.members.linode.com systemd[1]: Unit nginx.service entered failed state
  2. Chris
    Chris Member
    51
    3:42 PM
    1.7
  3. rdan
    1,412
    3:42 AM
    Remove this include file "vts_http.conf" on every vhost you have, including the virtual.conf.
  4. Chris
    Chris Member
    51
    3:42 PM
    1.7
    I edited
    vts_http.conf:1 and
    /usr/local/nginx/conf/vts_mainserver.conf:5
    and it worked so far...
  5. Chris
    Chris Member
    51
    3:42 PM
    1.7
    Hi Roland...I'm a bit confused on the virtual.conf...
    I found this include
    include /usr/local/nginx/conf/vts_mainserver.conf;
  6. rdan
    1,412
    3:42 AM
    Remove that line.
    55,458
    12,257
    5:42 AM
    I'd comment them out not remove just in case.. it might be related to your other issue Nginx - Error upgrading Nginx | Centmin Mod Community in that some github hosted nginx modules didn't download properly due to DNS issues on your VPS preventing resolution of github.com domain. It maybe that other Nginx and github hosted downloads didn't download properly too. I'll reply to that thread for the rest
