Issue on first run of 140.000BETA
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Tracy Perry, Nov 22, 2024.
  1. Tracy Perry
    Tracy Perry Active Member
    280
    118
    Texas
    9:20 AM
    1.21.6
    MariaDB 10.3.36
    Fresh install of CentMin mode BETA (latest verson) on AlmaLinux 9 (all updates ran) on an OVH Almlalinux 9 install that has been fully updated.
    [12:12][root@ns540718.ip-192-99-15.net tracy]# centmin
    /usr/local/src/centminmod /home/tracy
    /usr/local/src/centminmod/inc/nginx_mimetype.inc: line 72: syntax error near unexpected token `}'
    /usr/local/src/centminmod/inc/nginx_mimetype.inc: line 72: `}'
    Second run after doing an EPEL update.
    [12:17][root@ns540718.ip-192-99-15.net tracy]# centmin
    /usr/local/src/centminmod/inc/nginx_mimetype.inc: line 72: syntax error near unexpected token `}'/usr/local/src/centminmod/inc/nginx_mimetype.inc: line 72: `}'
    During that second run, I also get a
    /usr/local/src/centminmod/inc/cpcheck.inc: line 1885: mimefix: command not found
    Use an option 24 and I get (on the third load)
    [12:19][root@ns540718.ip-192-99-15.net tracy]# centmin
    This happens if I am under my normal user profile or if I have issued a sudo su.
    54,389
    12,198
    1:20 AM
    cheers bug found and fixed in latest 140.00beta01 update
    if you run cmupdate should pull the fix down
  3. Tracy Perry
    280
    118
    Texas
    9:20 AM
    1.21.6
    MariaDB 10.3.36
    I check regularly and saw an updated out and ran and the issue is no longer present.
    Thanks for the quick fix!
