Letsencrypt Is there any problems having both IPV4 and IPV6 dns records for Let's Encrypt?
Discussion in 'Add Ons' started by pamamolf, May 20, 2021.
    4,022
    421
    2:43 AM
    Nginx-1.17.x
    Hello
    I don't remember why but i have on my notes to not use an IPV6 when using Let's Encrypt...
    Is there any problems having both IPV4 A and IPV6 AAAA dns records on Cloudflare for Let's Encrypt?
    Can i do a test to be sure that it will updated without any issues when is time to do so?
    Thanks in advance !
    50,473
    11,663
    9:43 AM
    There shouldn't be a problem as long as your origin server also supports IPv6
  3. pamamolf
    4,022
    421
    2:43 AM
    Nginx-1.17.x
    At Centminmod side i have enabled ipv6 and when i check using ifconfig i can see on my eth0 an ipv6 address....
    Is that enough or should i check something else also?
    Thanks in advance !
