Upgrade Nginx Is there any problem for switch nginx to 1.14 from 1.13 ?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by negative, May 16, 2018.
  1. negative
    negative Active Member
    277
    8:16 PM
    1.9.10
    10.1.11
    I saw the new version of nginx today so can i switch that 1.14 version without any problem? I'm running 1.13.12 now. We are running xenforo.
    I just want to learn it before upgrade, i worry about new compatibility before upgrading so asking to you
    Thanks.
    • Nginx Version Installed: i.e. 1.13.12
    • PHP Version Installed: i.e. 7.1.17
    • Persistent Config:
      POSTGRESQL=y
      PHPFINFO=y
      NGINX_PAGESPEED=n
      NGINX_GEOIP=n
      PHPIONCUBE='y'
      PHPIMAGICK='y'
    39,820
    8,782
    3:16 AM
    Centmin Mod always tries to use latest Nginx mainline branch which is currently at 1.13.12 while latest Nginx stable is 1.14.0. As stated at Nginx - [nginx-announce] nginx-1.14.0 usually, when latest stable 1.14.0 is released, Nginx bumps 1.13.12 to 1.15.0 for mainline but this time they haven't as yet. Probably because right now at this stage Nginx 1.13.12 is same code as 1.14.0 so either of them works in Centmin Mod Nginx - especially on 123.09beta01 which takes advantage of latest Nginx mainline features.
  3. negative
    277
    8:16 PM
    1.9.10
    10.1.11
    So, we are happy with 1.13.x version until 1.15 is released :) Thanks.
  4. negative
    277
    8:16 PM
    1.9.10
    10.1.11
    is it time to upgrade 1.14.0 now ?
    or should i go directly to 1.15.0 ?
  5. Sunka
    Sunka Well-Known Member
    1,100
    298
    Rijeka, Croatia
    7:16 PM
    Nginx 1.15.8
    MariaDB 10.3.12
  6. rdan
    1,085
    1:16 AM
    (y)
    39,820
    8,782
    3:16 AM
    1.15.0 is where you want to be
