Nginx Is it possible to get Xenforo to use Nginx memcached module?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by jeffwidman, Apr 25, 2015.
  1. jeffwidman
    jeffwidman Active Member
    152
    27
    7:55 AM
    Xenforo support Memcache, but the way it currently works, the request comes into Nginx, then Nginx spawns PHP process via PHP-FPM, then that PHP process talks to Memcache.
    However, Nginx has a built-in Memcached module, so theoretically, it's possible to cut out the PHP process middleman.
    Does anyone know if this is possible for Xenforo?
    I know on Wordpress it's possible using the WP-FPPC cache... when set to use NginxMemcached as a backend, it's going to be faster than WP-Supercache which skips the PHP process, but is slowed down by caching to disk rather than caching to memory.
    49,891
    11,489
    12:55 AM
    no idea unless Zend framework supports it as that is what Xenforo is based on
  3. rdan
    1,354
    10:55 PM
    Not really :)
    XenForo code is not based on ZendF.
    Just using some of it's library but really not based on.
    49,891
    11,489
    12:55 AM
    oh correction then :)
