Nginx Is it better to add an exeption for 127.0.0.1 for autoprotect rules?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by pamamolf, Aug 28, 2016.
    59,718
    3:04 AM
    hmm that would make it difficult to filter just for upload directory
    i updated 123.09beta01's tools/autoprotect.sh with a custom rule fix for this let me know if it works
  2. pamamolf
    4,127
    8:04 PM
    Yes it works now :)
    59,718
    3:04 AM
    great.. i think i might have come up with a smarter way for autoprotect.sh, check .htaccess for deny from all but also filter out 'Order allow' and then check if there is any existence of 'allow' in in the .htaccess and if there is just deny php, pl, cgi extension files but allow css and js files.
  4. pamamolf
    4,127
    8:04 PM
    I think also this one (from opencart) is not correct:
    Options +SymLinksIfOwnerMatch
    # Prevent Directoy listing
    Options +Indexes
    # Prevent Direct Access to files
    <FilesMatch "\.(tpl|ini|log)">
    Order deny,allow
    Deny from all
    </FilesMatch>
    And i got for this:
    location ~* ^/ { allow 127.0.0.1; deny all; }
    If i am not wrong it should limit only tpl|ini|log files and not all ?
    59,718
    3:04 AM
    what directory is that for ? deny all can still be valid if you don't need any other files from that directory i.e. css, js or images
  6. pamamolf
    4,127
    8:04 PM
    Also do you recommend me to replace this custom rule:
       location ~^(/uploads/).*(\.php)$ {
            deny     all;
    with this one:
    location ~ ^/uploads/ {
      location ~ ^/uploads/(.*)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
  7. pamamolf
    4,127
    8:04 PM
    It is from:
    /home/nginx/domains/domain.com/public/
    59,718
    3:04 AM
    the aim is for tools/autoprotect.sh to run and generate the correct rule
    both of those should be fine
    hmm that's a tricky one if it's in web root
  9. pamamolf
    4,127
    8:04 PM
    That's what i thought when i saw it :)
    59,718
    3:04 AM
  11. dorobo
    dorobo Active Member
    420
    104
    1:04 AM
    latest
    latest
    How do I stop autoprotect from sending me emails?
    is it ok to change the cron line from this
    /usr/local/src/centminmod/tools/autoprotect.sh 2>/dev/null
    to this
    /usr/local/src/centminmod/tools/autoprotect.sh >/dev/null 2>&1
    59,718
    3:04 AM
    yup - the emails do serve a purpose if you regularly read them you may find .htaccess files you need to account for in your nginx vhost properly
  13. negative
    negative Active Member
    415
    50
    8:04 PM
    1.9.10
    10.1.11
    Ah, today our nginx webserver was down due that autoprotect.sh because of i was added manually the internal_data directory deny permissions so it did duplicated and nginx was down, i fix that after about 15 min :)
    So, we don't need any custom security rules to nginx conf files of wordpress and xenforo websites, right?
    59,718
    3:04 AM
    maybe not if autoprotect.sh covered it properly but if you already covered it as per setup at Nginx Rewrites for Xenforo Friendly Urls - CentminMod.com LEMP Nginx web stack for CentOS then i can see why it could conflict. In such case just add the .autoprotect-bypass file as per Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community to internal_data directory
    what does your /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf contain now ?
    59,718
    3:04 AM
    what did you specifically add and where did you add it ?
  16. negative
    415
    50
    8:04 PM
    1.9.10
    10.1.11
    My domain.com.conf was including that as your xenforo nginx install guide
            location /internal_data/ {
            internal;
            allow 127.0.0.1;
            allow YOURIPADDRESS;
            deny all;
            location /library/ {
            internal;
            allow 127.0.0.1;
            deny all;
    But, after autoprotect.sh installed and run on our side (it did auto install while centmin updates i think), it crashed suddenly i don't understand. I didn't login the ssh or restart nginx but it happen itself. Probably when run the autoprotect.sh cron.
    59,718
    3:04 AM
    strange indeed
    the internal_data and library directores do have a .htaccess file by xenforo with
    Order deny,allow
    Deny from all
    So autoprotect.sh will catch it but yes it would cause problems with xenforo ! Need figure that one out :)
    for now just add a .autoprotect-bypass file into both internal_data and library directories and re-run tools/autoprotect.sh to bypass it
  18. negative
    415
    50
    8:04 PM
    1.9.10
    10.1.11
    My autoprotect domain file including them:
    # /home/xxxx/public/assets/cms/plugins/filemanager/config
    location ~* ^/assets/cms/plugins/filemanager/config/ { allow 127.0.0.1; deny all; }
    # https://community.centminmod.com/posts/35394/
    # /home/xxxx/public/forum/library
    location /forum/library/ {
      location ~ ^/forum/library/(.+/)?(.+)\.(js)$ { allow all; expires 30d; }
      location ~ ^/forum/library/(.+/)?(.+)\.(css)$ { allow all; expires 30d; }
      location ~ ^/forum/library/(.+/)?(.+)\.(gif|jpe?g|png|webp|eot|svg|ttf|woff|woff)$ { allow all; expires 30d; }
      location ~ ^/forum/library/(.+/)?(.+)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
    # /home/xxx/public/forum/internal_data
    location /forum/internal_data/ {
      location ~ ^/forum/internal_data/(.+/)?(.+)\.(js)$ { allow all; expires 30d; }
      location ~ ^/forum/internal_data/(.+/)?(.+)\.(css)$ { allow all; expires 30d; }
      location ~ ^/forum/internal_data/(.+/)?(.+)\.(gif|jpe?g|png|webp|eot|svg|ttf|woff|woff)$ { allow all; expires 30d; }
      location ~ ^/forum/internal_data/(.+/)?(.+)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
    # /home/xxx/public/forum/install/templates
    location /forum/install/templates/ {
      location ~ ^/forum/install/templates/(.+/)?(.+)\.(js)$ { allow all; expires 30d; }
      location ~ ^/forum/install/templates/(.+/)?(.+)\.(css)$ { allow all; expires 30d; }
      location ~ ^/forum/install/templates/(.+/)?(.+)\.(gif|jpe?g|png|webp|eot|svg|ttf|woff|woff)$ { allow all; expires 30d; }
      location ~ ^/forum/install/templates/(.+/)?(.+)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
    # /home/xxx/public/forum/install/data
    location /forum/install/data/ {
      location ~ ^/forum/install/data/(.+/)?(.+)\.(js)$ { allow all; expires 30d; }
      location ~ ^/forum/install/data/(.+/)?(.+)\.(css)$ { allow all; expires 30d; }
      location ~ ^/forum/install/data/(.+/)?(.+)\.(gif|jpe?g|png|webp|eot|svg|ttf|woff|woff)$ { allow all; expires 30d; }
      location ~ ^/forum/install/data/(.+/)?(.+)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
    Problem was, nginx says internal_data location was duplicate entry so it didn't restart. After i delete these lines from domain.com.conf, everything was fixed.
            internal;
            allow 127.0.0.1;
            deny all;
            internal;
            allow 127.0.0.1;
            deny all;
    But i shocked that, problem was occured suddenly. Probably was your autoprotect cron was runned itself :)
    59,718
    3:04 AM
    I'd leave your custom vhost added originally settings and bypass autoprotect.sh instead. So if you installed Xenforo at /home/nginx/domains/domain.com/public, add .autoprotect-bypass files to Xenforo directories as follows.
    SSH commands to just create empty .autoprotect-bypass files to exclude from tools/autoprotect.sh
    touch /home/nginx/domains/domain.com/public/library/.autoprotect-bypass
    touch /home/nginx/domains/domain.com/public/internal_data/.autoprotect-bypass
    touch /home/nginx/domains/domain.com/public/install/data/.autoprotect-bypass
    touch /home/nginx/domains/domain.com/public/install/templates/.autoprotect-bypass
    updated Xenforo setup with this info too Nginx Rewrites for Xenforo Friendly Urls - CentminMod.com LEMP Nginx web stack for CentOS
  20. negative
    415
    50
    8:04 PM
    1.9.10
    10.1.11
    But, how about the bypass the autoprotect.sh rules?
    I think they works like standart xenforo rules already, isn't it ? So, i don't need custom modifications on my domain.com.conf. Autoprotect.sh securing everything already.
