Nginx Is it better to add an exeption for 127.0.0.1 for autoprotect rules?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by pamamolf, Aug 28, 2016.
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Hi
    I am just wondering if it is better Centminmod to add automatically at :
    /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
    a rule for everything that is blocking to allow 127.0.0.1 ?
    I think that will solve many problems with plugins/addos .....
    55,811
    12,272
    11:47 PM
    probably but is it needed ? you ran into any examples where this is required ?
  3. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    After having some issues with many addons i give up and i am just disabling it always....
    I know that i should try to fix them but there was so many that was not able to access some folders so i just think that this rule may help a lot !
    55,811
    12,272
    11:47 PM
    for what wordpress ?
  5. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    IPB forum...
    55,811
    12,272
    11:47 PM
    just remember nginx doesn't support .htaccess so if author of addon intended for a directory to have .htaccess with deny from all, that directory is meant to be private and not publicly accessible - so it is a security issue unless you have specific nginx equivalent deny rules added yourself.
    autoprotect.sh is meant to plug those potential security holes in 123.09beta01
  7. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Ok so it will be great if autoprotect allow 127.0.0.1 access on every block as default !!!! :)
    55,811
    12,272
    11:47 PM
    just updated centmin mod 123.09beta001 for allow 127.0.0.1
    so update via centmin.sh menu option 23 submenu option 2 and then re-run manually tools/autoprotect.sh
    /usr/local/src/centminmod/tools/autoprotect.sh
    55,811
    12,272
    11:47 PM
    also if you can post output for the generated autoprotect include file /usr/local/nginx/conf/autoprotect/yourdomain.com/autoprotect-yourdomain.com.conf would help to see what IPB directories are being picked up for 'deny from all' .htaccess files
    just like @Colin report for IPB which was resolved IP.Board - Query on autoprotect + IPB forums | Centmin Mod Community
  10. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Sure now i will enable it again and post back if i have any issues :)
  11. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Found one issue :)
    # /home/nginx/domains/domain.com/public/uploads
    location ~* ^/uploads/ { allow 127.0.0.1; deny all; }
    /home/nginx/domains/domain.com/public/uploads/.htaccess content:
    #<ipb-protection>
    <Files ~ "^.*\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)">
        Order allow,deny
        Deny from all
    </Files>
    #</ipb-protection>
    Site looks like having broken css when i enable the include for autoprotect and it has only this rule inside.
    When i disable it all working great :)
    55,811
    12,272
    11:47 PM
    did you re-run updated tools/autoprotect.sh ?
    your problem should of been taken care of by previous fix from @Colin's thread at IP.Board - Query on autoprotect + IPB forums | Centmin Mod Community
    55,811
    12,272
    11:47 PM
    looks like your IPB .htaccess differs from @Colin's at IP.Board - Query on autoprotect + IPB forums | Centmin Mod Community as the updated fixed tools/autoprotect.sh is also looking for Header set line to trigger the custom rule
    #<ipb-protection>
        Order allow,deny
        Deny from all
    </Files>
    <Files ~ "^.*\.(ipb)$">
    Header set Content-Disposition attachment
    </Files>
    #</ipb-protection>
  14. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    I just update Centminmod and run:
    so yes i re run it....
    I can see that it looks like the same and that you have a fix for it but it doesn't work for me :(
    55,811
    12,272
    11:47 PM
    It doesn't work as autoprotect.sh also looks for Header set in .htaccess for ipb-protection filtered files. Seems your .htaccess in upload doesn't have the Header set part
  16. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Is there a way to got a fix for this?
    I can add manually the missing header line so it can trigger it but maybe i will get another similar .htaccess and get the same issue.....
    It seems that i missing three lines :
    </Files>
    55,811
    12,272
    11:47 PM
    if you can provide contents of all .htaccess picked up by autoprotect.sh in generated autoprotect include file /usr/local/nginx/conf/autoprotect/yourdomain.com/autoprotect-yourdomain.com.conf - i can probably get custom rules added
  18. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    Don't know why but i got only this one....
    55,811
    12,272
    11:47 PM
    is IPB upload folder always named /upload ? or can it change ?
  20. pamamolf
    4,101
    428
    4:47 PM
    Nginx-1.26.x
    You can change it to any folder but 99% of the installations use the default...as i do.
    Maybe i delete the .htaccess from there but i wil check it later.....
    looking to fix the current issue at the moment....if possible
