IP.Board IPB v4.1.x Files
Discussion in 'Forum software usage' started by Jimmy, Nov 9, 2015.
  1. Ahmad
    Ahmad Active Member
    209
    80
    11:41 PM
    1.9.9
    10.1.10
    Yup, he has to adapt the rules to account for the subdir which I have done and no problems at all except for this one but with the rule I wrote it works just fine.
  2. Jimmy
    5:41 PM
    I guess my biggest question if the correct way to write the rule
    or
    If the first way is the correct way then I want to change the rest of the rules in the vhost file. I want this vhost to work for everyone. :)
  3. Ahmad
    Ahmad Active Member
    209
    80
    11:41 PM
    1.9.9
    10.1.10
      listen 443 ssl http2;
      server_name domain.com;
      ssl_dhparam /usr/local/nginx/conf/ssl/domain.com/dhparam.pem;
      ssl_certificate  /usr/local/nginx/conf/ssl/domain.com/domain.com.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/domain.com/domain.com.key;
      include /usr/local/nginx/conf/ssl-include.conf;
      # Mozilla Recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA:!DES-CBC3-SHA;
      ssl_prefer_server_ciphers  on;
      add_header Strict-Transport-Security "max-age=31536000; includeSubdomains;";
      add_header  X-Content-Type-Options "nosniff";
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver 8.8.8.8;
      ssl_stapling on;
      ssl_stapling_verify on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/domain.com/ssl-trusted.crt;
      # include /usr/local/nginx/conf/pagespeed.conf;
      # include /usr/local/nginx/conf/pagespeedhandler.conf;
      # include /usr/local/nginx/conf/pagespeedstatslog.conf;
      # Limit Connections Per IP Address
      #limit_conn limit_per_ip 16;
      # ssi on
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=60m;
      location ~ (?:^|/)\. {
          deny all;
          try_files     $uri $uri/ /index.php;
      location ~^(/page/).*(\.php)$ {
      # Mask fake admin directory
      location ~^/forum/admin/(.*)$ {
          deny all;
      # IP.Board PHP/CGI Protection
      location ~^(/forum/uploads/).*(\.php)$ {
          deny  all;
      location ~^(/forum/system/).*(\.php)$ {
          deny  all;
      location ~^(/forum/datastore/).*(\.php)$ {
          deny  all;
      location ~^(/forum/plugins/).*(\.php)$ {
          deny  all;
      location ~^(/forum/applications/cms/).*(\.php)$ {
          deny  all;
      location ~^(/forum/applications/core/).*(\.php)$ {
          deny  all;
      location ~^(/forum/applications/forums/).*(\.php)$ {
          deny  all;
      location ~^(/forum/applications/nexus/).*(\.php)$ {
          deny  all;
      # Allow access to imageproxy
      location ^~ /forum/applications/core/interface/imageproxy/imageproxy.php {
          allow  all;
      # Allow access to JS file
      location ^~ /forum/applications/core/interface/js/js.php {
          allow  all;
    This is how my config looks, forum is installed in forum subdir, one extra thing to note is that I have IP.Pages installed at the root. You cannot make one config file for everyone, unfortunately. They will need to adopt a few things.
  4. Jimmy
    5:41 PM
    Yea, I guess everyone is going to have their own setup. I'll modify the OP to reflect your changes / additions.
  5. Jimmy
    5:41 PM
    I'm trying to figure out what cloudflare setting I should put in what file? I'm reading this page Nginx Cloudflare & Incapsula (reverse proxy HttpRealIpModule) - CentminMod.com LEMP Nginx web stack for CentOS
    Do I put this information in both the nginx.conf and the newdomain.com.conf file(s)?
    # Cloudflare
    # IPv4
    set_real_ip_from 103.21.244.0/22
    set_real_ip_from 103.22.200.0/22
    set_real_ip_from 103.31.4.0/22
    set_real_ip_from 104.16.0.0/12
    set_real_ip_from 108.162.192.0/18
    set_real_ip_from 141.101.64.0/18
    set_real_ip_from 162.158.0.0/15
    set_real_ip_from 172.64.0.0/13
    set_real_ip_from 173.245.48.0/20
    set_real_ip_from 188.114.96.0/20
    set_real_ip_from 190.93.240.0/20
    set_real_ip_from 197.234.240.0/22
    set_real_ip_from 198.41.128.0/17
    set_real_ip_from 199.27.128.0/21
    # IPv6
    set_real_ip_from 2400:cb00::/32
    set_real_ip_from 2405:8100::/32
    set_real_ip_from 2405:b500::/32
    set_real_ip_from 2606:4700::/32
    set_real_ip_from 2803:f800::/32
    real_ip_header CF-Connecting-IP;
    Where do I put this?
    set_real_ip_from yourreverseproxyip;
    real_ip_header X-Forwarded-For;
    Looking at your "For Cloudflare:" examples, one contains the ips and the other contains the 2 lines of code above. I'm confused.
    UPDATE
    I think I read the use of the two line one above wrong - I'm not using a load balancer so I just need to know if I need to add the Cloudflare to both the nginx.conf and the domainname.com.conf files?
    UPDATE 2
    After reading it a second time, it looks like I'm supposed to put the ips in both files.
    Thanks!
    59,732
    7:41 AM
    really only domain's nginx vhost file's server {} context but unless you have ALL other sites on server hosted and protected by cloudflare then nginx.conf is easier
    revised text
    Also updated article at centminmod.com/nginx_configure_cloudflare.html with latest ipv4 and ipv6 address and a note to emphasize checking the maintained ip list to make adjustments
  7. Jimmy
    5:41 PM
    So, if every site is using Cloudflare I could just put it in the nginx.conf and omit it from the domain specific vhost files?
  8. rdan
    5:41 AM
    If you want to preserve visitors IP, I recommend you do it on PHP side/CMS option/config.php.
    And remove all those overhead from Nginx :).
  9. Jimmy
    5:41 PM
    Sounds like a plan, now I just have to figure out how to do that. Is that something to add to the php conf files or a CMS/software specific file?
    59,732
    7:41 AM
    nginx has less overhead than via php ;)
    yes technically that should do it, you can verify by checking your nginx site's respective access_logs to see what ip is logged as well as if your web apps have user ip logging verify there
    also you can use include files in nginx so only need one file to include and change across all nginx vhosts
    include /usr/local/nginx/conf/csfips.conf;
    then add the settings to /usr/local/nginx/conf/csfips.conf
  11. Jimmy
    5:41 PM
    59,732
    7:41 AM
  13. Ahmad
    Ahmad Active Member
    209
    80
    11:41 PM
    1.9.9
    10.1.10
    Just a heads up. Be careful when using
        location ~^(/applications/blog/).*(\.php)$ {
            deny     all;
        location ~^(/applications/calendar/).*(\.php)$ {
            deny     all;
        location ~^(/applications/chat/).*(\.php)$ {
            deny     all;
        location ~^(/applications/cms/).*(\.php)$ {
            deny     all;
        location ~^(/applications/core/).*(\.php)$ {
            deny     all;
        location ~^(/applications/downloads/).*(\.php)$ {
            deny     all;
        location ~^(/applications/forums/).*(\.php)$ {
            deny     all;
        location ~^(/applications/gallery/).*(\.php)$ {
            deny     all;
        location ~^(/applications/nexus/).*(\.php)$ {
            deny     all;
    Seems like more files than only imageproxy and the JS files needs to be accessible directly.
    E.g. for nexus, the billing API's need to be accessible.
    It seems like only files that are in the interface folder(s) need to be direct accessible so something like access to
    location ~^(/applications/*/interface/).*(\.php)$ {
      allow all;
    should work fine, I have not tested it however.
  14. Jimmy
    5:41 PM
    You think I should remove those? If I do, you see any security issues?
  15. Ahmad
    Ahmad Active Member
    209
    80
    11:41 PM
    1.9.9
    10.1.10
    Either remove them or try adding the location I mentioned above.
    Security issue, I don't think so as IPS already checks in the files if it is being accessed directly and does not execute the script if it is not permitted.
  16. Jimmy
    5:41 PM
    Sounds good. I'll remove the ones you have listed above and include the location block you included.
    59,732
    7:41 AM
    i believe he doesn't say remove the ones listed but add the extra allow location to those (position above those listed)
  18. Ahmad
    Ahmad Active Member
    209
    80
    11:41 PM
    1.9.9
    10.1.10
    Yep either add the location I mentioned OR remove the ones listed.
  19. Jimmy
    5:41 PM
    Which way do you think is better?
    59,732
    7:41 AM
    i'd add the location and keep existing location context restrictions to lock things down
