Install Installer not working
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Jon Snow, Aug 12, 2022.
  1. Jon Snow
    Jon Snow Active Member
    933
    192
    9:29 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Actually, is this correct?
    nprestart
    Redirecting to /bin/systemctl restart nginx.service
    Redirecting to /bin/systemctl restart php-fpm.service
  2. Jon Snow
    933
    192
    9:29 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    systemctl status nginx.service
    ● nginx.service - Centmin Mod NGINX Server
       Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; vendor preset: disabled)
      Drop-In: /etc/systemd/system/nginx.service.d
               └─failure-restart.conf, openfileslimit.conf
       Active: active (running) since Fri 2022-08-12 09:04:15 UTC; 31s ago
      Process: 54939 ExecStop=/bin/sh -c /bin/kill -s TERM $(/bin/cat /usr/local/nginx/logs/nginx.pid) (code=exited, status=0/SUCCESS)
      Process: 54944 ExecStart=/usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf (code=exited, status=0/SUCCESS)
      Process: 54943 ExecStartPre=/usr/local/sbin/nginx -t (code=exited, status=0/SUCCESS)
     Main PID: 54946 (nginx)
       CGroup: /system.slice/nginx.service
               ├─54946 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
               └─54947 nginx: worker process
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com systemd[1]: Stopped Centmin Mod NGINX Server.
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com systemd[1]: Starting Centmin Mod NGINX Server...
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com nginx[54943]: nginx: the configuration file /usr/local/nginx/conf/nginx.conf syntax is ok
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com nginx[54943]: nginx: configuration file /usr/local/nginx/conf/nginx.conf test is successful
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com systemd[1]: Failed to parse PID from file /usr/local/nginx/logs/nginx.pid: Invalid argument
    Aug 12 09:04:15 xxx-xx-xxx-xxx.ip.linodeusercontent.com systemd[1]: Started Centmin Mod NGINX Server.
    60,063
    12,574
    10:29 AM
    Could just of been temp github and pecl.php.net connectivity issues.
    yes :)
    60,063
    12,574
    10:29 AM
    Seems other folks reporting pecl.php.net slowness or downtime. I added a 60 second timeout to pecl.php.net downloads in updated 124.00stable and 130.00beta01 to see if we can wait out the response.
    https://stackoverflow.com/questions...or-channel-pecl-php-net-connection-to-ssl-pec
    Might be the long term solution to download via github source for each pecl.php.net download but then if github has network issues, then it's the same :)
