Installed Fresh Centos 7, 123.09beta01, nginx 1.19.3 , php 7.4.11 Xcache problem?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by johnnyc, Oct 22, 2020.
  1. johnnyc
    johnnyc Member
    41
    2:57 PM
    • CentOS Version: i.e. CentOS 6 32bit or 64bit / CentOS 7 64bit ?
    • Centmin Mod Version Installed: i.e. 123.09beta01
    • Nginx Version Installed: i.e. 1.19.3
    • PHP Version Installed: i.e. 7.4.11
    • MariaDB MySQL Version Installed: i.e. not sure, installed today oct 20,2020
    • When was last time updated Centmin Mod code base ? : i.e. run centmin.sh menu option 23 submenu option 2 or cmupdate command
      Post output in CODE tags.
    I said NO to zend cache (this is a Wordpress server), and I said Yes to xcache, it causes some problems, Xcache 3.2 was not installed because no file was found on lighttpd.net server, is Xcache not compatible with php 7.4.11? I tried to replace with APC and it said APC was not compatbile with php 7.4, told me to use Zend optimizer instead (which supposedly is Not compatible with wordpress sites.
    So what is the correct cache to use with wordpress 5.5.1 on php 7.4.11?
    55,158
    12,249
    5:57 AM
    Yeah for best performance Zend Opcache is usually recommended and for compatibility reasons. I'll have to revisit the APC and XCache routines to see about either updating them or removing them as I haven't used the in almost 8 years now !
  3. pamamolf
    4,100
    428
    10:57 PM
    Nginx-1.26.x
    Hello
    For my case removing APC and Xcache and adding on the main menu the Redis installation it will be much better !
    Thank you
  4. redbird
    redbird Member
    90
    15
    Web
    5:57 AM
    How do I remove xcache completely as after recompiling php it's asking to re-install xcache but it's not available anymore (errror 404)?
    55,158
    12,249
    5:57 AM
    You should be able to just run centmin.sh menu option 12, submenu option 1 or 2
  6. redbird
    redbird Member
    90
    15
    Web
    5:57 AM
    Option 12 is Zendcache not xcache
    Xcache is option 8. All it does is trying to reinstall xcache which is unavailable:
    Enter option [ 1 - 24 ] 8
    * Installing XCache
    Download xcache-3.2.0.tar.gz ...
    Initializing download: https://xcache.lighttpd.net/pub/Releases/3.2.0/xcache-3.2.0.tar.gz
    HTTP/1.0 404 Not Found
    Error: xcache-3.2.0.tar.gz download failed.
    check Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    How do I manually remove xcache and make sure php does not try to load this extension?
    55,158
    12,249
    5:57 AM
    when you run centmin.sh menu option 12 to install Zend Opcache, it automatically removes Xcache. Zend Opcache is the recommended optimal Zend Opcache replacement for Xcache.
  8. redbird
    redbird Member
    90
    15
    Web
    5:57 AM
    oh ok, got you. The thing is, this is a staging server where we don't need any caching
    55,158
    12,249
    5:57 AM
    Then you can disable Zend Opcache from loading the extension via custom .ini settings.
    For custom php settings read centminmod.com/phpfpm.html#customphpini. You might want to create /etc/centminmod/php.d/b_customphp.ini to override centmin mod defaults at /etc/centminmod/php.d/a_customphp.ini and restart PHP-FPM. Such changes will persist when doing centmin mod upgrades.
    Also outlined in Getting Started Guide Step 17
    So specifically for zendopcache.ini you want to override it with a file you create named alphabetically listed after it i.e. zz_zendoptcache.ini
    copy and make /etc/centminmod/php.d/zz_zendopcache.ini
    cp -a /etc/centminmod/php.d/zendopcache.ini /etc/centminmod/php.d/zz_zendopcache.ini
    edit /etc/centminmod/php.d/zz_zendopcache.ini and comment out the zend_extension load line with semi-colon in front
    ;zend_extension=opcache.so
    then restart php-fpm service
    service php-fpm restart
    or via command shortcut
    fpmrestart
    If you want to re-enable Zend Opcache, just either delete /etc/centminmod/php.d/zz_zendopcache.ini and then restart PHP-FPM service again.
