Index column size too large. The maximum column size is 767 bytes
Discussion in 'System Administration' started by Jon Snow, Oct 6, 2022.
  1. Jon Snow
    Jon Snow Active Member
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Query Monitor is giving me the following error when trying to use a Wordpress plugin's optimization feature to remove unused CSS. The site functions normally, it's just that I don't believe the feature is working and this is logged in Query Monitor.
    This is a $5/$10 Linode VPS.
    How can I fix this?
    50,481
    11,664
    2:09 AM
    What's your MariaDB database's default characterset and collation? Must be that the Wordpress plugin database schema doesn't account for InnoDB has a maximum index length of 767 bytes when using utf8mb4 characterset and/or is using COMPACT/REDUNDANT row format for InnoDB table
    see
  3. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    It's showing the same result for me from the post:
    egrep 'format|large' /etc/my.cnf | uniq
    innodb_large_prefix=1
    innodb_file_format = Barracuda
    # binlog_format=ROW
    What's the command to check this if I don't have phpMyAdmin installed?
    50,481
    11,664
    2:09 AM
    SSH command to check and filter MariaDB MySQL relevant variables
    mysqladmin var | egrep -i '\| character_|\| collation|file_format|large_prefix|row_format' | tr -s ' '
  5. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    This is the results:
    | character_set_client | utf8 |
    | character_set_connection | utf8 |
    | character_set_database | utf8 |
    | character_set_filesystem | binary |
    | character_set_results | utf8 |
    | character_set_server | utf8 |
    | character_set_system | utf8 |
    | character_sets_dir | /usr/share/mysql/charsets/ |
    | collation_connection | utf8_general_ci |
    | collation_database | utf8_general_ci |
    | collation_server | utf8_general_ci |
    | innodb_default_row_format | compact |
    | innodb_file_format | Barracuda |
    | innodb_file_format_check | ON |
    | innodb_file_format_max | Antelope |
    | innodb_large_prefix | ON |
    50,481
    11,664
    2:09 AM
    So your MariaDB defaults use utf8 character set so shouldn't be subject to InnoDB maximum index length of 767 bytes. However, individual databases/tables or web app scripts can choose to create database/tables with utf8mb4 character set which will trigger/hit InnoDB maximum index length of 767 bytes. So you need to check with Wordpress plugin author/developer to see if their created tables are utf8mb4 or utf8 based and adjust table InnoDB lengths appropriately. My 1st reply in this thread has 2 links you can pass onto the Wordpress plugin author/developer.
    edit: though looks like author is dismissing it as a problem on his side [Index column size too large. The maximum column size is 767 bytes.]
    When did you install Query Monitor plugin? If it was ages ago, you can try uninstalling plugin and re-installing to see if the database table for it gets updated.
    Centmin Mod is provide as is, so short of scripted related bugs or issues, any further optimisation to the web stack components - nginx, php-fpm, mariadb mysql, csf firewall etc or web app specific configurations are left to the Centmin Mod user to deal with. So I do not provide any free support for such with dealing with utf8/utf8mb4 and max key index prefix limits.
  7. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    In Health Check via Wordpress, it says:
    Database charset    utf8mb4
    So there is a limitation according to your post.
    How do you suggest I increase the limit on CMM and is it safe to do? Or do you have another recommendation?
    50,481
    11,664
    2:09 AM
    The solution involves modifying your database table structure for InnoDB indexes with >767 bytes or changing database table's row format. The links I provided above also link to official documentation for such as well. If you aren't sure how to do it, I'd recommend hiring someone to do it as that person would be able to access your server to have a better idea of the scope of changes needed.
    I'd be wary of forum/online suggested commands/changes as they won't know the full scope of your database structure and it's potential impact. If you did have to test such changes, you can do a full MySQL database backup first and/or do changes on a test copy of your MySQL database.
  9. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    I just have to set this:
    innodb_file_format=BARRACUDA
    innodb-file-per-table=ON
    innodb-large-prefix=ON
    innodb_default_row_format = 'DYNAMIC'
    In etc/my.cnf, I already see
    These two have a dash in the suggested solution instead of an underscore in the Centminmod My CNF file:
    # innodb settings
    innodb_file_per_table = 1
    And there's no:
    Would I just have to add the last 3 lines from the suggested solution and restart MariaDB?
    Last three lines:
    Would these changes be reverted with updates?
    I'm assuming innodb_large_prefix is a different variable to innodb-large-prefix.
    50,481
    11,664
    2:09 AM
    The /etc/my.cnf changes only work for newly created MySQL database tables not existing - hence why I said you need to modify your database tables affected by this.
    What's output for command
    grep -C3 -n innodb_default_row_format  /etc/my.cnf
    as each version section should have that by default already
    165-log_slow_filter =admin,filesort,filesort_on_disk,full_join,full_scan,query_cache,query_cache_miss,tmp_table,tmp_table_on_disk
    166-
    167-[mariadb-10.1]
    168:innodb_default_row_format = dynamic
    169-innodb_file_per_table = 1
    170-
    171-## wsrep specific
    206-
    207-[mariadb-10.2]
    208-#innodb_file_format = Barracuda
    209:innodb_default_row_format = dynamic
    210-innodb_file_per_table = 1
    211-
    212-## wsrep specific
    253-
    254-[mariadb-10.3]
    255-#innodb_file_format = Barracuda
    256:innodb_default_row_format = dynamic
    257-innodb_file_per_table = 1
    258-
    259-## wsrep specific
  11. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    It's for a new table so that's the aim.
    It's blank.
  12. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    On one of my newer servers:
    166-
    167-[mariadb-10.3]
    168-#innodb_file_format = Barracuda
    169:innodb_default_row_format = dynamic
    170-innodb_file_per_table = 1
    171-
    172-## wsrep specific
    Barracuda is commented out.
    Is there a difference between innodb-file-per-table and innodb_file_per_table?
    50,481
    11,664
    2:09 AM
    variables in my.cnf should use underscores
    10.3+ higher deprecate that variable for innodb_file_format as new versions of MariaDB 10.3+ are by default using Barracuda already
    I suggest you compare newer Centmin Mod server's /etc/my.cnf to the one with blank output for that command and see what you need to re-add to [mariadb-10.3] section. Again that only helps newly created MySQL database tables not your existing ones.
  14. Jon Snow
    708
    147
    1:09 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    What if I'm still on 10.1? Should I upgrade to 10.3?
    It's blank for 10.1.
    50,481
    11,664
    2:09 AM
    I'd upgrade to MariaDB 10.3 via centmin.sh menu option 11
